LAUNCHXL-F28379D: sysconfig (1.16.1+2960) unable to chose FreeRTOS tab in Ubuntu 18.04.6 LTS
Part Number: LAUNCHXL-F28379D
Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
Hi I am using a LAUNCHXL-F28379D to develop a FreeRTOS application.
My IDE is code composer Version: 12.3.0.00005  and I am using C2000 ware 4.3 on an Ubuntu system. (Ubuntu 18.04.6 LTS) and sysconfig version 1.16.1.
I have noticed that when i try to add a a FREERTOS configuration from the sysconfig tab in the project in code composer I get the following error and I cant build the project as well. I have tested the same project on windows machine.
Unable to render selection
Error: Default value is not an absolute path.
    at new l (file:///home/amd/ti/sysconfig_1.16.1/dist/webpack:/src/pinmux/services/objectManagers/configurables/localFileTextConfigurableMgr.ts:22:10)
    at Object.createMetaContentConfigurableMgr (file:///home/amd/ti/sysconfig_1.16.1/dist/webpack:/src/pinmux/services/objectManagers/configurables/configurable.ts:114:4)
    at O.createMetaContentConfigurableMgr (file:///home/amd/ti/sysconfig_1.16.1/dist/webpack:/src/pinmux/services/objectManagers/moduleInstance.ts:875:10)
    at iteratee (file:///home/amd/ti/sysconfig_1.16.1/dist/webpack:/src/pinmux/services/objectManagers/moduleInstance.ts:869:57)
    at baseMap (file:///home/amd/ti/sysconfig_1.16.1/dist/webpack:/node_modules/lodash/lodash.js:653:23)
    at Function.map (file:///home/amd/ti/sysconfig_1.16.1/dist/webpack:/node_modules/lodash/lodash.js:9621:51)
    at O.addMetaContentConfigurableMgrs (file:///home/amd/ti/sysconfig_1.16.1/dist/webpack:/src/pinmux/services/objectManagers/moduleInstance.ts:869:30)
    at O.initMetaConfigurables (file:///home/amd/ti/sysconfig_1.16.1/dist/webpack:/src/pinmux/services/objectManagers/moduleInstance.ts:913:8)
    at Function.createInstanceImpl (file:///home/amd/ti/sysconfig_1.16.1/dist/webpack:/src/pinmux/services/objectManagers/moduleInstance.ts:137:11)
    at Function.createInstance (file:///home/amd/ti/sysconfig_1.16.1/dist/webpack:/src/pinmux/services/objectManagers/moduleInstance.ts:1141:28)
I have faced the same error when running from a standalone sysconfig in Ubuntu.
for the time being a have shifted to windows system.
  • I know we have tested this on Windows. do we have ubuntu support?
    Apologies for the late response. I missed this notification from E2E.
    We had it tested on Windows only. The default path for external FreeRTOS installation was set to window specific path.
    As a workaround, could you replace your C:\Work\Git\kernel-tool-release\.meta\freertos_tool\FREERTOS.syscfg.js with the attached file?
    "use strict";
    /*global exports, system*/
    let Common   = system.getScript("/driverlib/Common.js");
    let Pinmux   = system.getScript("/driverlib/pinmux.js");
    let CMDCommon = system.getScript("/kernel/freertos_tool/FREERTOSCommon.js");
    /* Intro splash on GUI */
    let longDescription = `FreeRTOS Configuration Tool
    For more information on the tool visit:
    var config = [
        // Folder select
            displayName: "Use External FreeRTOS Install",
            default: false,
            onChange: (inst, ui)=>{
                ui.freertosPath.hidden = !inst.useExternalInstall
            displayName: "FreeRTOS Install Path",
            default: "",
            fileFilter: ".*",
            hidden: true,
            pickDirectory: true,
            displayName: "FreeRTOS Configuration",
            collapsed: true,
            config: [
            displayName: "Kernel Configuration",
            collapsed: false,
            config: [
                    displayName: "CPU Clock Hz",
                    description: "",
                    default: 100000000,
                    displayName: "Tick Rate Hz",
                    description: "",
                    default: 1000,
                    displayName: "Max Priorities",
                    description: "",
                    default: 16,
                    displayName: "Minimal Stack Size",
                    description: "",
                    default: 128,
                    displayName: "Max Task Name Length",
                    description: "",
                    default: 10,
                    displayName: "Queue Registry Size",
                    description: "",
                    default: 10,
                    displayName: "Task Notification Array Entries",
                    description: "",
                    default: 3,
                    displayName: "Use Preemption",
                    description: "",
                    default: true,
                    displayName: "Use Time Slicing",
                    description: "",
                    default: true,
                    displayName: "Use Port Optimised Task Selection",
                    description: "",
                    default: false,
                    displayName: "Use Tickless Idle",
                    description: "",
                    default: false,
                    displayName: "Use 16 Bit Ticks",
                    description: "",
                    default: false,
                    displayName: "Idle Should Yield",
                    description: "",
                    default: false,
                    displayName: "Use Task Notifications",
                    description: "",
                    default: true,
                    displayName: "Use Mutexes",
                    description: "",
                    default: false,
                    displayName: "Use Recursive Mutexes",
                    description: "",
                    default: false,
                    displayName: "Use Counting Semaphores",
                    description: "",
                    default: false,
                    displayName: "Use Queue Sets",
                    description: "",
                    default: false,
                    displayName: "Enable Backward Compatibility",
                    description: "",
                    default: false,
                    displayName: "Record Stack High Address",
                    description: "",
                    default: false,
            displayName: "Memory Configuration",
            collapsed: false,
            config: [
                    displayName: "Support Static Allocation",
                    description: "",
                    default: true,
                    displayName: "Support Dynamic Allocation",
                    description: "",
                    default: true,
                    displayName: "Application Allocated Heap",
                    description: "",
                    default: true,
                    displayName: "Stack Allocation From Separate Heap",
                    description: "",
                    default: false,
                    displayName: "Total Heap Size",
                    description: "",
                    default: 1024,
            displayName: "Hook/Callback Configuration",
            collapsed: false,
            config: [
                    displayName: "Use Idle Hook",
                    description: "",
                    default: false,
                    displayName: "Use Tick Hook",
                    description: "",
                    default: false,
                    displayName: "Check For Stack Overflow",
                    description: "",
                    default: false,
                    displayName: "Use Malloc Failed Hook",
                    description: "",
                    default: false,
                    displayName: "Use Daemon Task Startup Hook",
                    description: "",
                    default: false,
            displayName: "Statistics Configuration",
            collapsed: false,
            config: [
                    displayName: "Generate Run Time Stats",
                    description: "",
                    default: false,
                    displayName: "Use Trace Facility",
                    description: "",
                    default: false,
                    displayName: "Use Stats Formatting Functions",
                    description: "",
                    default: false,
            displayName: "Co-routine Configuration",
            collapsed: false,
            config: [
                    displayName: "Use Co-Routines",
                    description: "",
                    default: false,
                    displayName: "Max Co-Routine Priorities",
                    description: "",
                    default: 0,
            displayName: "Software Timer Configuration",
            collapsed: false,
            config: [
                    displayName: "Use Timers",
                    description: "",
                    default: false,
                    displayName: "Timer Task Priority",
                    description: "",
                    default: 3
                    displayName: "Timer Queue Length",
                    description: "",
                    default: 10
                    displayName: "Timer Task Stack Depth",
                    description: "",
                    default: 0
            displayName: "FreeRTOS Optional API Include",
            description: "Include optional APIs",
            collapsed: false,
            config: [
                    displayName: "vTaskPrioritySet",
                    description: "",
                    default: false
                    displayName: "uxTaskPriorityGet",
                    description: "",
                    default: false
                    displayName: "vTaskDelete",
                    description: "",
                    default: false
                    displayName: "vTaskSuspend",
                    description: "",
                    default: true
                    displayName: "xResumeFromISR",
                    description: "",
                    default: false
                    displayName: "vTaskDelayUntil",
                    description: "",
                    default: true
                    displayName: "vTaskDelay",
                    description: "",
                    default: true
                    displayName: "xTaskGetSchedulerState",
                    description: "",
                    default: false
                    displayName: "xTaskGetCurrentTaskHandle",
                    description: "",
                    default: false
                    displayName: "uxTaskGetStackHighWaterMark",
                    description: "",
                    default: false
                    displayName: "xTaskGetIdleTaskHandle",
                    description: "",
                    default: false
                    displayName: "eTaskGetState",
                    description: "",
                    default: false
                    displayName: "xEventGroupSetBitFromISR",
                    description: "",
                    default: false
                    displayName: "xTimerPendFunctionCall",
                    description: "",
                    default: false
                    displayName: "xTaskAbortDelay",
                    description: "",
                    default: false
                    displayName: "xTaskGetHandle",
                    description: "",
                    default: false
                    displayName: "xTaskResumeFromISR",
                    description: "",
                    default: false
                    displayName: "vTaskCleanUpResources",
                    description: "",
                    default: false
    var moduleInstances = (inst) => {
        var mods = []
        mods.push({
            displayName: "User Tasks Configuration",
            moduleName: "/kernel/freertos_tool/task.js",
            //requiredArgs : {
            useArray: true,
            collapsed: true,
        mods.push({
            displayName: "Semaphores / Mutexes Configurations",
            moduleName: "/kernel/freertos_tool/semaphore.js",
            useArray: true,
            collapsed: true,
        mods.push({
            displayName: "Queues Configurations",
            moduleName: "/kernel/freertos_tool/queue.js",
            useArray: true,
            collapsed: true,
        mods.push({
            displayName: "Timers Configurations",
            moduleName: "/kernel/freertos_tool/timer.js",
            useArray: true,
            collapsed: true,
        mods.push({
            displayName: "Events Configurations",
            moduleName: "/kernel/freertos_tool/event.js",
            useArray: true,
            collapsed: true,
        mods.push({
            displayName: "Tick Timer",
            description: "The CPU Timer used for FreeRTOS tick (Configured as part of xPortStartScheduler function)",
            moduleName: "/driverlib/cputimer.js",
            requiredArgs: {
                $name              : "timer2",
                cputimerBase       : CPUTIMER_INSTANCE[2].name,
                enableInterrupt    : true,
                registerInterrupts : true,
                startTimer         : false,
                timerPeriod        : 100000,
                timerPrescaler     : 0,
                clockPrescaler     : "CPUTIMER_CLOCK_PRESCALER_1",
                clockSource        : "CPUTIMER_CLOCK_SOURCE_SYS",
                timerInt           : {
                    interruptHandler: "portTICK_ISR"
        return mods
    var CPUTIMER_INSTANCE = [
        { name: "CPUTIMER0_BASE", displayName: "CPUTIMER0"},
        { name: "CPUTIMER1_BASE", displayName: "CPUTIMER1"},
        { name: "CPUTIMER2_BASE", displayName: "CPUTIMER2"},
    function sharedModuleInstances (inst)
        var sharedModules = []
        // sharedModules = sharedModules.concat([{
        //     name: "tickTimer",
        //     displayName: "Tick Timer",
        //     description: "The CPU Timer used for FreeRTOS tick",
        //     moduleName: "/driverlib/cputimer.js",
        //     requiredArgs: {
        //         $name              : "timer2",
        //         cputimerBase       : CPUTIMER_INSTANCE[2].name,
        //         enableInterrupt    : true,
        //         registerInterrupts : true,
        //         startTimer         : false,
        return sharedModules;
    function onValidate(inst, validation)
        if(inst.USE_PORT_OPTIMISED_TASK_SELECTION == true)
            validation.logError(
                "Port optimized task selection is not supported!",inst,"USE_PORT_OPTIMISED_TASK_SELECTION");
        if(inst.APPLICATION_ALLOCATED_HEAP == false)
                "Application allocated heap should be enabled to avoid memory issues!", inst, "APPLICATION_ALLOCATED_HEAP");
        if(inst.SUPPORT_STATIC_ALLOCATION == true)
            validation.logInfo(
                "Update minimal stack size to update Idle task stack size!", inst, "MINIMAL_STACK_SIZE");
        if((inst.USE_TIMERS == true) && (inst.TIMER_TASK_STACK_DEPTH == 0))
                "Update timer task stack depth!", inst, "TIMER_TASK_STACK_DEPTH");
    // Define the common/portable base FreeRTOS
    var freeRTOSModule = {
        displayName         : "FREERTOS",
        description         : "FREERTOS",
        defaultInstanceName : "myFREERTOS",
        longDescription     : longDescription,
        maxInstances        : 1,
        moduleInstances     : moduleInstances,
        sharedModuleInstances: sharedModuleInstances,
        modules: (inst) => {
            var mods = []
            if (inst) {
                if (inst.useExternalInstall)
                    mods.push({
                        moduleName: "/kernel/freertos_tool/templates/c2000_freertos_source.c.dynamic.js",
                    mods.push({
                        moduleName: "/kernel/freertos_tool/templates/c2000_freertos_asm.asm.dynamic.js",
                else
                    mods.push({
                        moduleName: "/kernel/freertos_tool/templates/c2000_freertos_references.dynamic.js",
                return mods;
            return [];
        templates: {
            "/kernel/freertos_tool/templates/c2000_freertos.c.xdt" : "",
            "/kernel/freertos_tool/templates/c2000_freertos.h.xdt" : "",
            "/kernel/freertos_tool/templates/FreeRTOSConfig.h.xdt" : "",
            "/kernel/freertos_tool/templates/c2000_freertos.cmd.genlibs.xdt" : "",
            "/kernel/freertos_tool/templates/c2000_freertos.opt.xdt": ""
        config              : config,
        validate            : onValidate,
    exports = freeRTOSModule;
    We will update this in the next C2000ware release.
    Veena
