Other Parts Discussed in Thread: CONTROLSUITE
// TI File $Revision: /main/2 $
// Checkin $Date: Thu Jan 6 15:14:02 2011 $
// This software is licensed for use with Texas Instruments C28x
// family DSCs. This license was provided to you prior to installing
// the software. You may review this license by consulting a copy of
// the agreement in the doc directory of this library.
// Copyright (C) 2010-2011 Texas Instruments, Incorporated.
// All Rights Reserved.
System Name: 16 bit Fixed Point FIR Filter - Fixed Point DSP Library
File Name: fir16d.c
Description: Primary System file for demonstrating the FIR Filter
Originator: Yu Cai (ASP) - Texas Instruments
Target dependency: C28x
Description:
This module shows how to implement 16 bit FIR filter by calling optimized
16 bit fir function. The header structure of 16 bit filter is shown
as follows:
typedef struct {
long *coeff_ptr;
long * dbuffer_ptr;
int cbindex;
int order;
int input;
int output;
void (*init)(void *);
void (*calc)(void *);
}FIR16;
Users can also use default templates defined within fft.h to intialize the FIR16
header structure.
FIR16 fir= FIR16_DEFAULTS;
For design user specified FIR coefficients, MATLAB Filter Design and Analysis Tool
(FDATool) is needed to design a filter and generate coefficients header file. For
details, please refer to Fixed Point DSP library manual.
Watch Variables:
coeff_ptr Coefficients buffer pointer
dbuffer_ptr Delay buffer pointer
cbindex Circular buffer pointer
input Input data (Q15)
sigIn Input data buffer (Q15)
output Output data (Q15)
sigOut Output data buffer (Q15)
// $TI Release: C28x Fixed Point Library v1.01 $
// $Release Date: January 11,2011 $
#include "DSP28x_Project.h"
#include <fir.h>
#include "math.h"
#include "float.h"
/* Filter Symbolic Constants */
#define FIR_ORDER 51
#define SIGNAL_LENGTH 100
/* Create an Instance of FIRFILT_GEN module and place the object in "firfilt" section */
#pragma DATA_SECTION(fir, "firfilt");
#pragma DATA_SECTION(fir1, "fir1filt");
FIR16 fir1= FIR16_DEFAULTS;
/* Define the Delay buffer for the 50th order filterfilter and place it in "firldb" section */
#pragma DATA_SECTION(dbuffer,"firldb"); // Delay buffer alignment
long dbuffer[(FIR_ORDER+3)/2];
#pragma DATA_SECTION(dbuffer,"fir1ldb"); // Delay buffer alignment
long dbuffer1[(FIR_ORDER+3)/2];
#pragma DATA_SECTION(sigIn, "sigIn"); // Input/output buffer alignment
#pragma DATA_SECTION(sigOut, "sigOut");
int sigIn[SIGNAL_LENGTH];
int sigOut[SIGNAL_LENGTH];
#pragma DATA_SECTION(sigIn1, "sigIn1"); // Input/output buffer alignment
#pragma DATA_SECTION(sigOut1, "sigOut1");
int sigIn1[SIGNAL_LENGTH];
int sigOut1[SIGNAL_LENGTH];
/* Define Constant Co-efficient Array and place the
.constant section in ROM memory */
#pragma DATA_SECTION(coeff, "coefffilt"); // Coefficients buffer alignment
long const coeff[(FIR_ORDER+3)/2];
#pragma DATA_SECTION(coeff1, "coeff1filt"); // Coefficients buffer alignment
long const coeff1[(FIR_ORDER+3)/2];
int FIR16_LPF_TEST[FIR_ORDER+1]; // Temporary buffer for adjust odd order FIR
int FIR16_LPF_TEST1[FIR_ORDER+1]; // coefficients
float RadStep = 0.1963495408494f;
float Rad = 0.0f;
float RadStep1 = 0.1963495408494f;
float Rad1 = 0.0f;
/* Finter Input and Output Variables */
int xn,yn;
int an,bn;
void main()
unsigned long i;
int *p;
int *q;
int FIR_ORDER_REV;
InitSysCtrl();
DINT;
InitPieCtrl();
IER = 0x0000;
IFR = 0x0000;
InitPieVectTable();
EINT; // Enable Global interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
p=(int *)coeff;
q=(int *)coeff1;
FIR_ORDER_REV=FIR_ORDER;
// FIR16_LPF_TEST initialization
//This buffer is only used to adjust odd order FIR filter to even order.
for(i=0;i<sizeof(FIR16_LPF32_TEST);i++)
FIR16_LPF_TEST[i]=FIR16_LPF32_TEST[i]; //Put coefficients into FIR16_LPF_TEST buffer
FIR16_LPF_TEST1[i]=FIR16_LPF32_TEST[i]; //Put coefficients into FIR16_LPF_TEST buffer
if(FIR_ORDER_REV%2!=0) // If ODD Order FIR
FIR16_LPF_TEST[FIR_ORDER_REV]=0; // Added one zero to the end of the coefficient
FIR_ORDER_REV=FIR_ORDER_REV+1; // order=order+1; order now becomes even number
FIR16_LPF_TEST1[FIR_ORDER_REV]=0; // Added one zero to the end of the coefficient
/* FIR Generic Filter Initialisation */
fir.order=FIR_ORDER_REV;
fir.dbuffer_ptr=dbuffer;
fir.coeff_ptr=(long *)coeff;
fir.init(&fir);
fir1.order=FIR_ORDER_REV;
fir1.dbuffer_ptr=dbuffer1;
fir1.coeff_ptr=(long *)coeff1;
fir1.init(&fir1);
//Clean up coeff buffer
for(i=0;i<FIR_ORDER_REV*2;i=i+2)
*(p+i)=0;
*(p+i+1)=0;
*(q+i)=0;
*(q+i+1)=0;
//Clean up delay buffer
for(i=0;i<FIR_ORDER_REV*2;i=i+1)
dbuffer[i]=0;
dbuffer1[i]=0;
//Reorganize coefficient table
//If user would like to reorgainze the order of the coefficients outside this
//project, for example, in matlab and stored the reorganized coefficients in
//header file beforehand, this part is not necessarily.
//More details, please refer to Fixed Point DSP library manual
for(i=0;i<FIR_ORDER_REV;i=i+2)
*(p+FIR_ORDER_REV-i-2)=FIR16_LPF_TEST[i/2];
*(p+FIR_ORDER_REV-i-1)=FIR16_LPF_TEST[i/2+FIR_ORDER_REV/2];
*(q+FIR_ORDER_REV-i-2)=FIR16_LPF_TEST1[i/2];
*(q+FIR_ORDER_REV-i-1)=FIR16_LPF_TEST1[i/2+FIR_ORDER_REV/2];
// Generate sample waveforms:
Rad = 0.0f;
for(i=0; i < SIGNAL_LENGTH; i++)
sigIn[i] =0; //
sigOut[i] =0;
sigIn1[i] =0; //
sigOut1[i] =0;
//FIR calculation
xn=(int)(32768*(sin(Rad) + cos(Rad*2.3567))/2); //Q15
sigIn[i]=xn;
fir.input=xn;//0.5 Q15 format
fir.calc(&fir);
yn=fir.output;
sigOut[i]=yn;
Rad = Rad + RadStep;
an=(int)(32768*(sin(Rad1) + cos(Rad1*2.3567))/2); //Q15
sigIn1[i]=an;
fir1.input=an;//0.5 Q15 format
fir1.calc(&fir1);
bn=fir1.output;
sigOut1[i]=bn;
Rad1 = Rad1 + RadStep1;
while(1)
} /* End: main() */
first problem is warning: creating output section "fir1filt" without a SECTIONS specification
i modified the 28335_RAM_link.cmd to solve that
what i do is :
firldb align(0x100)> RAML1 PAGE = 0
firfilt : > RAML1 PAGE = 0
coefffilt align(0x100)>RAML2 PAGE = 0
sigIn : > RAML1 PAGE = 0
sigOut : > RAML2 PAGE = 0
fir1ldb align(0x100)> RAML1 PAGE = 0
fir1filt : > RAML1 PAGE = 0
coeff1filt align(0x100)>RAML2 PAGE = 0
sigIn1 : > RAML1 PAGE = 0
sigOut1 : > RAML2 PAGE = 0
copy the specifications
and then the warnings are gone
but the output is not right
the original
sigIn[SIGNAL_LENGTH] and sigOut[SIGNAL_LENGTH] output the right results
but the added ones sigIn1[SIGNAL_LENGTH] is same as sigIn[SIGNAL_LENGTH] and sigOut1[SIGNAL_LENGTH] is not right
asking for help, online
the file is attached
