TMS320F28069: cannot read and write flash sector C
Part Number: TMS320F28069
Hi team
CCS report error when program the flash:
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/171/default-_2800_3_2900_.jfif
if they try to erase and read the corresponding flash region with uniflash, it shows:
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/171/default-_2800_4_2900_.jfif
is there any workaround to make the flash work properly again?
Joe
  • Joe,
    In Uniflash, in the Settings and Utilities tab if you scroll all the way down, you should see a "depletion recovery" button.  You can run this to see if this will fix the flash issue.  I believe this can also be invoked as part of the flash API in your code to do the same thing.
    If depletion recovery does not fix the issue; there is not an alternative but to replace the device.
    Matthew
