Hello:
I'm using the PinMux utillity. When I save the configuration it does not save the full configuration. It does not save the Locked Status, the HB configurationand the McBSP.
Any updates or fixes? I'm using it for the concerto.
regards Arye
Hello:
regards Arye
Hello : I have not received yet an answer to this question!!!!
regards Arye
Arye,
Unfortunately we are not planning on updating the base functionality of the current tool. We are looking at creating a new tool that is easier to maintain but I regret that likely will not be ready in such a time to be of use for you.
Lori
If this new tool is still in the concept stage, I would like to suggest:
- adding pin numbers to the display (so the user can select groups of inputs on the same side of the chip),
- space to save and reload user comments on assigned pins,
- space to save and reload user entered netnames,
- ability to sort by columns (like pin numbers versus GPIO, or user entered netnames)
- supporting selecting analog pins that can be used as other IO like, AIO or comparators, and having the ".h" generator the registers for these features too.
