Hi all,
I'm using the 28027_RAM_Ink.cmd as provided (I know this because I destroyed my last linker and had the re-install control suite to get a fresh copy) and need some help understanding whats going on...
preface:
using CCS V5.something
Dev board - F28027 launchPad
Working on a 'TestPad' for InstaSpin - Rotary Encoder/ Current Sense/PWM out & SPI OLED
I have 2 large-ish headers - X11 colours && Font
Initial Error:
Description Resource Path Location Type
<a href="file:/C:/ti/ccsv5/tools/compiler/dmed/HTML/10099.html">#10099-D</a> program will not fit into available memory. placement with alignment/blocking fails for section ".text" size 0xc53 page 0. Available memory ranges: 28027_RAM_lnk.cmd /InstaSPIN Bench line 114 C/C++ Problem
I figured immediately that the logical solution to this is to simply expand the memory allocated to .text, evidently not as simple as I thought. I changed these:
PRAML0 : origin = 0x008000, length = 0x000900
DRAML0 : origin = 0x008900, length = 0x000700
to this
PRAML0 : origin = 0x008000, length = 0x001000
DRAML0 : origin = 0x008900, length = 0x000600
which stopped all errors but now the play button is greyed out and there is no way to start the program???
After some investigation into the memory (sprs523j.pdf pg 16) I see that 0x00 9000 is reserved -doesn't make much sense since the original linker also had DRAML0 flowing into this region? It also shows another SARAM block at 0x3F8000, so I figured I would just move PRAML0 here since there is not much using it - such that the only thing difference in my 28027_RAM_lnk.cmd to the one provided in control suite is :
PRAML0 : origin = 0x3F8000, length = 0x001000
But unfortunately this results in the same problem - builds fine but the play button is greyed out////
Last resort, move PRAML0 to flash....
PRAML0 : origin = 0x3F0000, length = 0x005000
Success! -Interrupt still crashes the MCU for some reason, but that is a different matter.)
This is not ideal as I am doing a lot of debugging and erasing the flash sectors takes a lot of time....
Why did my original 'fix' not work? There is surely enough room in RAM for this - only just came up with this error when I added a 'draw box' routine....
CCS not flagging an error makes trouble shooting very painful - I may have some fundamental misunderstanding of the linker because this makes no sense to me.
Thanks in advance
