As in F28069 with ECAN, MSGID and RTR can be got easily.
But in the F280049 with DCAN is different.
How could I set my MSGID and RTR bit like F28069?
I need to deal with the remote frame in the next situations:
1、interrupt same as a data frame, and there is an RTR bit to indicate that a remote frame is received, and then I will answer the message with a data frame manually.
2、I need to trasmit an remote frame to slave node, how to deal with it. In TRM, just said
27.11.2 Configuration of a Transmit Object for Remote Frames
It is not necessary to configure transmit objects for the transmission of remote frames. Setting TxRqst for
a receive object will cause the transmission of a remote frame with the same identifier as the data frame
for which this receive object is configured.
My main quetions are:
How to get/set a RTR bit? How to transmit a remote frame?
