Hello
Is any CCS shortcut to switch between build configurations?
Thanks.
Hello
Thanks.
Ron,
Your attachment did not come through but I assume you are asking about setting a shortcut for the action of choosing a build configuration from menu Project->Build Configurations->Set Active. If so, I don't believe that action is available as a single command to which a keyboard shortcut can be assigned. You can find the commands that can be assigned a key binding under Windows->Preferences->General->Keys.
Thanks for replay.
Indeed that what I meant.
AartiG said:If so, I don't believe that action is available as a single command to which a keyboard shortcut can be assigned.
If so, it may will be a good advice to add that in next version of CCS.
Similar to existing shortcut of CTRL+F8 to switch perspectives...
Thanks.
