The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
CCS/TMS320F28379D: Verification failed. Password for the launchpad?
Part Number: TMS320F28379D
Other Parts Discussed in Thread: CONTROLSUITE, TIDA-010026
Hello Team,
I am trying to debug two F28379D launchpads but encounter a Verification failed. Please see below for detail. The top marking of the two is shown here. $4C 96AKDPW and $4C 92ATY6W.
I use another F28379D launchpad with IC top marking YFC-64AXXQW and have no problem debug and burn code to the launchpad.
May I know if you have password to unlock the two launchpads with IC top marking $4C 96AKDPW and $4C 92ATY6W?
C28xx_CPU1: GEL Output:
Memory Map Initialization Complete
C28xx_CPU1: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map.
C28xx_CPU1: File Loader: Verification failed: Values at address 0x0000000000086000 do not match Please verify target memory and memory map.
C28xx_CPU1: GEL: File: C:\TI\controlSUITE\device_support\F2837xD\v210\F2837xD_examples_Cpu1\TIDA-010026_Bit_Error_test_Master\ENC1-CPU1_FLASH\TIDA-010026_Bit_Error_Test_Master.out: a data verification error occurred, file load failed.
Thank you.
Ting
