Digikey says the part is no longer manufacturing (Obsolete). Could you please let me know from where I can get the equivalent/same part?
Can you pls reach out to Mitsubishi? Even if only alternate parts are available, they can suggest if any workarounds are needed to be done.
There is an alternate part from Mitsubishi, requiring minimal corrections to the board.
http://www.pwrx.com/pwrx/docs/pss20s71f6.pdf
Pin 20 , bottom of board remove pad to isolate connection from ground.
Do not install R1,R2,R3,D1,D2&D3 as these components are internal to the new IPM design
The part is active, but suppliers have back orders on this. Requires some shopping around.
Dear Ramesh,
The alternate part that you have suggested is not available in any website. Is there any other available alternative part?
Let me check and get back to you.
Karthik,
I searched with various vendors and the lead time is about 6-7 months. There is no other matching part that I can suggest at this time. You may try it locally with your vendors for any replacements, though i suspect even they may say the same.
