Hello support team,
We are testing SCI mode in SCI/LIN module and found following behaviour
we cannot send anything about 900µs after the frame header. Although TXRDY is bit high, the data in SCITD is not sent out.
For a simple description I send a byte 0x55 every 1ms with timer 0 interrupt:
Legend: blue: LIN, red: Tx, yellow: Rx green: test pin after while (! LinaRegs.SCIFLR.bit.TXRDY);
- Without data on the Rx. All good. Byte 0x55 is sent every 1ms. OK
- Data on the Rx:
- In the frame header, TXRDY is high ???, Tx data is not sent (still OK)
- After the frame header (between 2 cursors / rulers, approx. 950µs) Tx data is also not sent, although the TXRDY bit is already high (on the 1st ruler) ???
Code init
EALLOW;
/* Reset LIN/SCI module */
LinaRegs.SCIPIO0.bit.RXFUNC = 0u;
LinaRegs.SCIPIO0.bit.TXFUNC = 0u;
LinaRegs.SCIGCR0.bit.RESET = 0u;
LinaRegs.SCIGCR0.bit.RESET = 1u;
LinaRegs.SCIGCR1.bit.SWnRST = 0u; /* Enter Software Reset State */
/* Enable SCI communications mode */
LinaRegs.SCIGCR1.bit.TIMINGMODE = 1u;
LinaRegs.SCIGCR1.bit.LINMODE = 0u;
LinaRegs.SCIGCR1.bit.COMMMODE = 0u; /* Idle-line mode is used. */
LinaRegs.SCIGCR1.bit.STOP = 0u; /* 1 Stop bit */
LinaRegs.SCIGCR1.bit.PARITYENA = 0u; /* Disable parity check */
LinaRegs.SCIGCR1.bit.MBUFMODE = 0u; /* Disable multi-buffer mode */
LinaRegs.SCIGCR1.bit.CONT = 1u; /* Module set to complete operations when halted by debugger */
LinaRegs.SCIGCR1.bit.LOOPBACK = 0u; /* Disable Internal loopback for external communication */
LinaRegs.SCIFORMAT.bit.CHAR = 7u; /* Set character length as 8-bits */
LinaRegs.SCIFORMAT.bit.LENGTH = 0u; /* Set response field to 1 byte */
/* Enable TX and RX pin control functionality */
LinaRegs.SCIPIO0.bit.RXFUNC = 1u;
LinaRegs.SCIPIO0.bit.TXFUNC = 1u;
LinaRegs.BRSR.all = (BRSR_P | (BRSR_M << 24uL)); /* Set Baud Rate */
LinaRegs.SCIGCR1.bit.CLK_MASTER = 1u; /* Select the internal clock */
LinaRegs.SCICLEARINT.all = 0xFF0023D2U; /* !< Diasble all interrupts */
LinaRegs.SCISETINT.bit.SETRXINT = 1u; /* Enable Rx Int */
LinaRegs.SCISETINT.bit.SETFEINT = 1u; /* Set framing-error interrupt */
LinaRegs.SCISETINT.bit.SETOEINT = 1u; /* Set overrun-error interrupt */
LinaRegs.SCISETINT.bit.SETPEINT = 1u; /* Set parity interrupt */
LinaRegs.SCISETINT.bit.SETBRKDTINT = 1u; /* Set break-detect interrupt */
/* Enable transmit and receive */
LinaRegs.SCIGCR1.bit.TXENA = 1u;
LinaRegs.SCIGCR1.bit.RXENA = 1u;
/* Finally exit SW reset and enter LIN ready state */
LinaRegs.SCIGCR1.bit.SWnRST = 1u;
IER |= M_INT8; /* Enable CPU which is connected to CPU */
PieCtrlRegs.PIEIER8.bit.INTx9 = 1u; /* Enable PIE Group 8 interrupt 9 */
PieVectTable.LINA_0_INT = &lin_ISR; /* Map ISR functions */
/* Enable global interrupt lines and clear status to known value */
LinaRegs.LIN_GLB_INT_EN.bit.GLBINT0_EN = 1u;
LinaRegs.LIN_GLB_INT_CLR.bit.INT0_FLG_CLR = 1u;
EDIS;
Code Lin Interrupt
volatile u32 statusReg;
volatile u16 dummy_data;
statusReg = LinaRegs.SCIFLR.all;
dummy_data = (l_u8)LinaRegs.SCIRD.bit.RD;
// Clear module interrupt flag and global interrupt flag for line 0
LinaRegs.SCIFLR.all = 0xFFFFFFFFuL;
/* Acknowledge this interrupt to receive more interrupts from same group */
PieCtrlRegs.PIEACK.all = PIEACK_GROUP8;
code timer interrupt
while(!LinaRegs.SCIFLR.bit.TXRDY);
GpioDataRegs.GPATOGGLE.bit.GPIO31 = 1;
LinaRegs.SCITD.bit.TD = 0x55;
/* Acknowledge this interrupt to receive more interrupts from group 1 */
PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
