Meanings about DSP2803x_Headers_nonBIOS.cmd
I'm wondering about the meanings of these declarations in DSP2803x_Headers_nonBIOS.cmd:
/*** PIE Vect Table and Boot ROM Variables Structures ***/
  UNION run = PIE_VECT, PAGE = 1
      PieVectTableFile
      GROUP
         EmuKeyVar
         EmuBModeVar
         FlashCallbackVar
         FlashScalingVar
And following the above decleration is the memory map for register structures.
I wonder what does "UNION" keyword mean? And keyword "run" as well?
Are there any mannul for CMD files that I can refered to?
          PieVectTableFile
          GROUP
             EmuKeyVar
             EmuBModeVar
             FlashCallbackVar
             FlashScalingVar
    The command files are described in the assembler reference manual www.ti.com/lit/spru513
    Cheers
    Lori
  • Hi, Lori:
    Thank you for your useful information.
    I found in spru513:
    "A NOLOAD section differs from a normal output section in one respect: its contents, relocation information, and line-number information are not placed in the output module. The linker allocates space for the section, and it appears in the memory-map listing."
    And in official cmd file "F28035.cmd", the IQMathTables section are set as NOLOAD type.
    I wonder if "its contents, relocation information, and line-number information are not placed in the output module", why should it be assembled in the output module? (especially that the contents is also not placed?)
    Hi, Lori:
    I found in spru513:
    Those tables are in the ROM of the device.  If you use them you need to know where they are - thus the address can be included.  The tables are in ROM so they do not need to be loaded by the application since they already exist.
  • Hallo, Lori:
    Thanks for your reply, understood now.
    And last question is :
    In F28035.cmd, in MEMORY definition, it defines 3 memory sectors ---- IQTABLES, IQTABLES2, IQTABLES3. And in SECTIONS definition, it puts 3 data sections into the 3 memory sectors mentioned above, the 3 sections are IQmathTables, IQmathTables2, IQmathTables3.
    Are these 3 data sections defined in IQMath library? Cause I didn't find there definitions.
    Yes - what they contain and how to access them in the ROM is described in the IQmath documentation.
    Cheers
    Lori
