Other Parts Discussed in Thread: CONTROLSUITE
Hello All,
I am using Piccolo F28069U controller on a custom board with USB connector. I am using the USB bootloader provided in controlSUITE.
I have customized both bootloader code and DFUProg.exe. When I connect the USB cable and controller is in bootcode, device is detected and the driver is loaded by Windows.
But if I connect the USB cable when application code is running (where DFU runtime mmode is active), device is detected but driver is not loaded by Windows.
the New Hardware Found wizard tells that "Can not find the driver".
I tried lots of methods from changing the INF file to changing VID/PID of the device but I am totally lost.
any help will be greatly appreciated.
thank you,
Vishwanatha
