Hi
Could you please send us examples of BLDC/PMSM/Induction motor for TMS320F2812 which supports code composer studio(V5)?
Devi & Ragi
Hi
Devi & Ragi
Devi,
Although many customers still use the F281x, internally we do not use the F281x as much because we have released newer and more advanced devices (such as the Piccolo F2803x series). As a result, we don't have anything that uses the F281x in CCSv5. If this is a new project (and you don't already have the MCU/DSPs) I might recommend looking at our device portfolio.
However, we do have several old-ish motor control projects for the F281x series. See below. They were designed in a previous version of CCS (I think CCSv3.3), but they should be able to be imported into CCS5 using the menus in CCS5.
_______________________
The above files (and their links) are found within http://www.ti.com/product/TMS320F2812 under the "Software" heading.
Thank you,
Brett
Has anyone found a solution for migrating the example projects, such as the motor control example SPRC130, designed in CSS v3.3 to CSS v5 yet?
We have a lot of equipment that still uses the F2812 DSP and would like to continue development in CSS v5 or later.
The built in conversion of CSS v5.3 doesn't seem to work for many of the example projects... especially the ones that include IQMATH.
Chris
