there are some issues as below when I imported the project which under motor_ware example into CCS5.4 to build.
anybody know how to resolve it? thanks very much......
'Invoking: C2000 Linker'
"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/bin/cl2000" -v28 -ml -mt --cla_support=cla0 --float_support=fpu32 --vcu_support=vcu0 -O3 -g --define=FAST_ROM_V1p6 --diag_warning=225 --display_error_number -z --stack_size=0x300 -m"proj_lab06b.map" --warn_sections -i"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/lib" -i"C:/ti/ccsv5/tools/compiler/c2000_6.1.3/include" --reread_libs --disable_pp --diag_suppress=16002 --rom_model -o "proj_lab06b.out" "./wdog.obj" "./user.obj" "./traj.obj" "./timer.obj" "./svgen.obj" "./pwr.obj" "./pwm.obj" "./proj_lab06b.obj" "./pll.obj" "./pie.obj" "./pid.obj" "./park.obj" "./osc.obj" "./offset.obj" "./ipark.obj" "./gpio.obj" "./flash.obj" "./filter_fo.obj" "./drv.obj" "./ctrl.obj" "./cpu.obj" "./clk.obj" "./clarke.obj" "./adc.obj" -l"libc.a" "C:/ti/motorware/motorware_1_01_00_08/sw/modules/fast/lib/32b/f28x/f2806x/2806xRevB_FastSpinROMSymbols.lib" "C:/ti/motorware/motorware_1_01_00_08/sw/modules/iqmath/lib/f28x/f2806x/IQmath.lib" "C:/ti/motorware/motorware_1_01_00_08/sw/modules/spintac/lib/32b/SpinTAC.lib" "C:/ti/motorware/motorware_1_01_00_08/sw/ide/ccs/cmd/f2806x/f28069M_ram_lnk.cmd"
error #16008-D: file
<Linking>
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_initCtrl
_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
revision "C28FPU32" specified in a previous file or on the command line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_runTraj_
revision "C2700" specified in a previous file or on the command line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_setEstPa
rams_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
ISA revision "C2700" specified in a previous file or on the command line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_setupCtr
l_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_setupEst
IdleState_tmp.obj>" specifies ISA revision "C2800", which is not compatible
with ISA revision "C2700" specified in a previous file or on the command
line
OnLineState_tmp.obj>" specifies ISA revision "C2800", which is not
compatible with ISA revision "C2700" specified in a previous file or on the
command line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_setupTra
j_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_setUserM
otorParams_tmp.obj>" specifies ISA revision "C2800", which is not compatible
line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_doCurrent
Ctrl_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_doSpeedCt
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_genOutput
Limits_Pid_Id_tmp.obj>" specifies ISA revision "C2800", which is not
command line
Limits_Pid_Iq_tmp.obj>" specifies ISA revision "C2800", which is not
command line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_get_krpm_
to_pu_sf_tmp.obj>" specifies ISA revision "C2800", which is not compatible
line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getAngle_
pu_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getFlux_V
pHz_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getFm_pu_
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getFullSc
aleCurrent_tmp.obj>" specifies ISA revision "C2800", which is not compatible
line
aleInductance_tmp.obj>" specifies ISA revision "C2800", which is not
command line
aleVoltage_tmp.obj>" specifies ISA revision "C2800", which is not compatible
line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getIab_pu
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getIdRate
d_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getLs_coa
rse_max_pu_tmp.obj>" specifies ISA revision "C2800", which is not compatible
line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getLs_d_H
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getLs_q_H
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getMaxCur
rentSlope_pu_tmp.obj>" specifies ISA revision "C2800", which is not
command line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getOneOve
rDcBus_pu_tmp.obj>" specifies ISA revision "C2800", which is not compatible
line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getRr_Ohm
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getRs_Ohm
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getSpeed_
krpm_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getState_
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getTorque
_lbin_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_isError_t
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_isIdle_tm
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_isLockRot
or_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_isMotorId
entified_tmp.obj>" specifies ISA revision "C2800", which is not compatible
line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_isOnLine_
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_run_tmp.o
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setFlag_e
nableForceAngle_tmp.obj>" specifies ISA revision "C2800", which is not
command line
nableRsRecalc_tmp.obj>" specifies ISA revision "C2800", which is not
command line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setId_ref
_pu_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setIdle_a
ll_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setIdle_t
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setIq_ref
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setLs_d_p
u_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setLs_q_p
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setLs_qFm
t_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setMaxCur
command line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setRs_pu_
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_updateId_
ref_pu_tmp.obj>" specifies ISA revision "C2800", which is not compatible
line
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_updateSta
te_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_useZeroIq
_ref_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
th.lib<IQ24cosPU.obj>" specifies ISA revision "C2800", which is not
command line
th.lib<IQ24sinPU.obj>" specifies ISA revision "C2800", which is not
command line
th.lib<IQ24sqrt.obj>" specifies ISA revision "C2800", which is not
command line
th.lib<IQ30toF.obj>" specifies ISA revision "C2800", which is not compatible
line
th.lib<IQmathTables.obj>" specifies ISA revision "C2800", which is not
command line
<spintac_version.obj>" specifies ISA revision "C2800", which is not
command line
<spintac_vel_plan.obj>" specifies ISA revision "C2800", which is not
command line
<spintac_vel_move.obj>" specifies ISA revision "C2800", which is not
command line
<spintac_vel_id.obj>" specifies ISA revision "C2800", which is not
command line
<spintac_vel_ctl.obj>" specifies ISA revision "C2800", which is not
command line
"C:\ti\ccsv5\tools\compiler\c2000_6.1.3\lib\rts2800_fpu32.lib<fs_cmp.obj>"
specifies ISA revision "C28FPU32", which is not compatible with ISA revision
"C:\ti\ccsv5\tools\compiler\c2000_6.1.3\lib\rts2800_fpu32.lib<fs_tol.obj>"
"C:\ti\ccsv5\tools\compiler\c2000_6.1.3\lib\rts2800_fpu32.lib<l_div.obj>"
"C:\ti\ccsv5\tools\compiler\c2000_6.1.3\lib\rts2800_fpu32.lib<l_tofd.obj>"
"C:\ti\ccsv5\tools\compiler\c2000_6.1.3\lib\rts2800_fpu32.lib<l_tofs.obj>"
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__s0_calc_tmp.o
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__s0_conf_tmp.o
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__s2_calc_tmp.o
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__s4_calc_tmp.o
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__s4_conf_tmp.o
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__s4_reset_tmp.
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__s8_calc_tmp.o
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__s8_cfg_tmp.ob
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__s8_get_tmp.ob
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__s8_reset_tmp.
06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__spintac_rom_v
er_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
th.lib<IQ20div.obj>" specifies ISA revision "C2800", which is not compatible
line
th.lib<IQ24div.obj>" specifies ISA revision "C2800", which is not compatible
line
error #10010: errors encountered during linking; "proj_lab06b.out" not built
>> Compilation failure
gmake: *** [proj_lab06b.out] Error 1
gmake: Target `all' not remade because of errors.
**** Build Finished ****
