Other Parts Discussed in Thread: CONTROLSUITE
Dear Community
I'm in charge of a project in which we are planning to use a Digital Signal Controller for Field Oriented Control of 3 - Phase induction motors. I've already use the TMDSPREX28335 board before and I had trouble using the DMC (Digital Motor Control) library. I need to know if this library is supported by the Delfino F28335 or if is not which delevoper's kit would you recommend. I've read in forums that the DMC library is intended to be use with fixed-point processors.
Thanks in advance
Matías Eze
