How do I measure microseconds?
I am trying to measure, in microseconds, the time it takes for a segment of code to run but I am not sure what a good method/function is to use to do this.
I started with the example code Example_F2802xAdcTempSensor.c.
I have tried several different methods, the best of which is supposed to me using gettimeofday() which is located in <sys/time.h>.  However, <sys/time.h> does not exist.
Is there a different function or method I should use?  Or is there some way I can include this file?
Thank you very much for your help.
