When will CCS and Uniflash be updated to support the Concerto F28M36P53C2 parts? I can program with the existing tools, but they give a warning since the flash is smaller on the P53 than the P63.
Here are the warnings from CCS (similar in Uniflash):
M3: Flash Programmer: Warning: The configured device (F28M36P63C2), does not match the detected device (F28M36P53C2). Flash Programming operations could be affected. Please consider modifying your target configuration file.
M3: GEL Output: Watchdog Timers Enabled
M3: GEL Output: UARTs Enabled
C28x: Flash Programmer: Warning: The configured device (F28M36P63C2), does not match the detected device (F28M36P53C2). Flash Programming operations could be affected. Please consider modifying your target configuration file.
Nelson
