Does SFRA work on any converter design or only on TI reference boards?
Other Parts Discussed in Thread: SFRA
Hi there,
I have designed and built a dc dc converter and I am controlling it using TMDSCNCD28377D. I am wondering if I can use the SFRA tool to measure some of the frequency responses of interest in my converter?
or does the SFRA tool only work on Texas instruments reference designs?
Thank you
Leo
  • Hi Leo,
    You should be able to use the SFRA tool for your system. Please refer to the SFRA library documentation that describes how to incorporate that code in your software correctly. You can also refer to any TI reference software that supports SFRA.
    Hrishi
  • Thanks Hrishi, sorry for my question but I am new to this tool. DO you know, if I need to create a stand alone CCS project to run the SFRA tool? or can I merge the SFRA code provided in the guide SPRUHZ5A in my current project code?
    Thanks so much
    Leo
  • Leo,
    Please follow the SFRA library documentation to correctly add SFRA code to your project. You should be able to use the SFRA GUI with your project.
    Hrishi
  • Hello Hrishi,
    Thanks for your answer. So I need to add the lines of code I found in the guide SPRUHZ5A inside my code ISR routine? i.e. from SPRUHZ5A
    (b) Using SFRA in open loop to get plant(H) frequency response:
                interrupt void PWM_ISR(void)
                //Read ADC and computer Fbk Value
                Vout1_Read = (float32)Vout1R/(4096.0);
                 //Add SFRA injection into the duty cycle for the open loop converter
                 Duty_pu=SFRA_F_INJECT(Duty_pu_DC);
                 //Update PWM value
                 EPwm1Regs.CMPA.half.CMPA=((long)(BUCK_PWM_PERIOD))* Duty_pu;
                 SFRA_F_COLLECT(&Duty_pu,&Vout1_Read);
    What I need to understand is what the function below does:
    Thanks for your help again,
    Leo
