Other Parts Discussed in Thread: CONTROLSUITE
Is there a way I can use the InstaSpin-Motion Position control and link it to a DC motor with encoder?
Forward control often output voltage command which will be converted to pwm duty.
You can not use the Rs calculation function of FAST to measure DC motor resistance directly, because the PWM mode is different.
I see no reason why it wouldn't work. As Chris & others have said, it would be a simple matter of changing the torque side of the motor control.
