Part Number: F28M36P63C2
In the funktion SysCtlClockGet() the "fractional multiplier" is calculated from the calculated "integer multiplier".
The "fractional multiplier" must be calculated from the input value ulClockIn.
Here is the correct code:
unsigned long
SysCtlClockGet(unsigned long ulClockIn)
unsigned long ulClock;
//If the pll is enabled calculate its effect on the clock
if((HWREG(SYSCTL_SYSPLLCTL) &
(SYSCTL_SYSPLLCTL_SPLLEN | SYSCTL_SYSPLLCTL_SPLLCLKEN)) == 3)
//Calculate integer multiplier
ulClock = ulClockIn *
(HWREG(SYSCTL_SYSPLLMULT) & SYSCTL_SYSPLLMULT_SPLLIMULT_M);
//Calculate fractional multiplier
switch((HWREG(SYSCTL_SYSPLLMULT) & SYSCTL_SYSPLLMULT_SPLLFMULT_M) >>
SYSCTL_SYSPLLMULT_SPLLFMULT_S)
default:
case 0:
break;
case 1:
ulClock += ulClockIn / 4;
break;
case 2:
ulClock += ulClockIn / 2;
break;
case 3:
ulClock += (ulClockIn * 3) / 4;
break;
//Fixed divide by 2
ulClock = ulClock / 2;
//Divide clock by the system clock divider
switch(HWREG(SYSCTL_SYSDIVSEL) & SYSCTL_SYSDIVSEL_SYSDIVSEL_M)
default:
case 0:
break;
case 1:
ulClock /= 2;
break;
case 2:
ulClock /= 4;
break;
case 3:
ulClock /= 8;
break;
//Divide clock by the M3 clock divider
switch(HWREG(SYSCTL_M3SSDIVSEL) & SYSCTL_M3SSDIVSEL_M)
default:
case 0:
break;
case 1:
ulClock /= 2;
break;
case 2:
ulClock /= 4;
break;
return ulClock;
