TMS320F28377D: Time delay between IPCSTS and IPCFLG registers.
Part Number: TMS320F28377D
I have set one IPC flag bit[30] from CPU1 using IPCSET register then respected CPU1's IPCFLG[30] and CPU2's IPCSTS[30] were set but I have a query that what is the time delay occurred between these flag modifications.
-I have configured both CPUs at same clock rate.
-If different time clock rates what will be happen(Not done,but small query)
  • Hi
    IPCFLG and IPCSTS bits will be set with-in couple of cycles after write  (not long delay). If you are looking for exact cycles then I need to check with our design team.
    On this device, CPU1 and CPU2 clock frq are always same.
    Vivek Singh
