CCS/TMS320F280049M: TMS320F280049: How to set "Zero Boot Mode Select Pins"
Part Number: TMS320F280049M
Dear TI team,
The document sprui33a.pdf  (TMS320F28004x_Technical Reference Manual) section 4.3.3.1 Zero Boot Mode Select Pins
Please let me know how to configure it as below (section 4.3.3.1 Zero Boot Mode Select Pins), I want to boot to flash without any external pull-up pin.
1. Program the BOOTPIN_CONFIG location in OTP as follows:
• Set BOOTPIN_CONFIG.BMSP0 to 0xFF
• Set BOOTPIN_CONFIG.BMSP1 to 0xFF
• Set BOOTPIN_CONFIG.BMSP2 to 0xFF
• Set BOOTPIN_CONFIG.KEY to 0x5A for boot ROM to treat these register bits as valid.
2. Program the BOOTDEF location options for the device. This essentially sets up a device-specific boot
mode table.
• Set BOOTDEF.BOOTDEF0 to 0x03 for booting to flash with a boot mode value of 0
• Optionally: Set BOOTDEF.BOOT_DEF0_ALT_OPTIONS to a different value to switch to one of the
available flash entry point alternatives.
  • Shih,
    1) Program USER OTP address 0x7800C = 0xFFFF & Program USER OTP address 0x7800D = 0x5AFF
    2) Program USER OTP address 0x7801C = 0xFF03
    Manoj
  • Dear Manoj,
    Please help check my step as below (add by me), this function the same not work:
    1. Add code in .asm file
    * Function: codestart section
    * Description: Branch to code starting point
    .sect "codestart"
    .sect "OTP_KEY" ; add by me
    .int 0x5AFF ; add by me
    .sect "OTP_BMODE" ; add by me
    .int 0xFFFF ; add by me
    .sect "OTP_Boot" ; add by me
    .int 0xFF03 ; add by me
    code_start:
    2. Add code in .cmd file
    MEMORY
    PAGE 0 :
    /* BEGIN is used for the "boot to Flash" bootloader mode */
    BEGIN : origin = 0x080000, length = 0x000002
    RAMM0 : origin = 0x0000F5, length = 0x00030B
    RAMLS0 : origin = 0x008000, length = 0x000800
    RAMLS1 : origin = 0x008800, length = 0x000800
    RAMLS2 : origin = 0x009000, length = 0x000800
    RAMLS3 : origin = 0x009800, length = 0x000800
    RAMLS4 : origin = 0x00A000, length = 0x000800
    RESET : origin = 0x3FFFC0, length = 0x000002
    OTP_BMODE : origin = 0x07800C, length = 0x000001 /* Add by me */
    OTP_KEY : origin = 0x07800D, length = 0x000001 /* Add by me */
    OTP_Boot : origin = 0x07801C, length = 0x000001 /* Add by me */
  • Shih,
    Did you add the following definitions in SECTIONS directive?
              SECTIONS
          OTP_BMODE : > OTP_BMODE, PAGE = 0
          OTP_KEY : > OTP_KEY, PAGE = 0
          OTP_Boot: : > OTP_Boot, PAGE = 0
    Manoj
  • Dear Manoj,
    No, I am not add this function definitions in SECTIONS ,
    I am out off office this week,
    I will try it next Monday, thanks a lot for your suggest.
  • Dear Manoj,
    After add definitions in SECTIONS,
    I am the same can't  into FLASH mode.
    Please help me review my "28004x_generic_flash_lnk.cmd" & "f28004x_codestartbranch.asm" source code as below:
    1. 28004x_generic_flash_lnk.cmd  =======================================================================>>
    MEMORY
    PAGE 0 :
    /* Flash sectors */
    /* BANK 0 */
    FLASH_BANK0_SEC0 : origin = 0x080002, length = 0x000FFE /* on-chip Flash */
    FLASH_BANK0_SEC1 : origin = 0x081000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC2 : origin = 0x082000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC3 : origin = 0x083000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC4 : origin = 0x084000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC5 : origin = 0x085000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC6 : origin = 0x086000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC7 : origin = 0x087000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC8 : origin = 0x088000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC9 : origin = 0x089000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC10 : origin = 0x08A000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC11 : origin = 0x08B000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC12 : origin = 0x08C000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC13 : origin = 0x08D000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC14 : origin = 0x08E000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK0_SEC15 : origin = 0x08F000, length = 0x001000 /* on-chip Flash */
    /* BANK 1 */
    FLASH_BANK1_SEC0 : origin = 0x090000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC1 : origin = 0x091000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC2 : origin = 0x092000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC3 : origin = 0x093000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC4 : origin = 0x094000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC5 : origin = 0x095000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC6 : origin = 0x096000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC7 : origin = 0x097000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC8 : origin = 0x098000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC9 : origin = 0x099000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC10 : origin = 0x09A000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC11 : origin = 0x09B000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC12 : origin = 0x09C000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC13 : origin = 0x09D000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC14 : origin = 0x09E000, length = 0x001000 /* on-chip Flash */
    FLASH_BANK1_SEC15 : origin = 0x09F000, length = 0x001000 /* on-chip Flash */
    PAGE 1 :
    BOOT_RSVD : origin = 0x000002, length = 0x0000F3 /* Part of M0, BOOT rom will use this for stack */
    RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
    RAMLS5 : origin = 0x00A800, length = 0x000800
    RAMLS6 : origin = 0x00B000, length = 0x000800
    RAMLS7 : origin = 0x00B800, length = 0x000800
    RAMGS0 : origin = 0x00C000, length = 0x002000
    RAMGS1 : origin = 0x00E000, length = 0x002000
    RAMGS2 : origin = 0x010000, length = 0x002000
    RAMGS3 : origin = 0x012000, length = 0x002000
    SECTIONS
    codestart : > BEGIN, PAGE = 0, ALIGN(4)
    .text : >>FLASH_BANK0_SEC1 | FLASH_BANK0_SEC2 | FLASH_BANK0_SEC3, PAGE = 0, ALIGN(4)
    .cinit : > FLASH_BANK0_SEC1, PAGE = 0, ALIGN(4)
    .pinit : > FLASH_BANK0_SEC1, PAGE = 0, ALIGN(4)
    .switch : > FLASH_BANK0_SEC1, PAGE = 0, ALIGN(4)
    .reset : > RESET, PAGE = 0, TYPE = DSECT /* not used, */
    OTP_BMODE : > OTP_BMODE, PAGE = 0 /*Add by me*/
    OTP_KEY : > OTP_KEY, PAGE = 0 /*Add by me*/
    OTP_Boot :: > OTP_Boot, PAGE = 0 /*Add by me*/
    .cio : > RAMLS0, PAGE = 0
    .stack : > RAMM1, PAGE = 1
    .ebss : > RAMLS5, PAGE = 1
    .esysmem : > RAMLS5, PAGE = 1
    .econst : > FLASH_BANK0_SEC4, PAGE = 0, ALIGN(4)
    ramgs0 : > RAMGS0, PAGE = 1
    ramgs1 : > RAMGS1, PAGE = 1
    .TI.ramfunc : LOAD = FLASH_BANK0_SEC1,
    RUN = RAMLS0 | RAMLS1 | RAMLS2 |RAMLS3,
    LOAD_START(_RamfuncsLoadStart),
    LOAD_SIZE(_RamfuncsLoadSize),
    LOAD_END(_RamfuncsLoadEnd),
    RUN_START(_RamfuncsRunStart),
    RUN_SIZE(_RamfuncsRunSize),
    RUN_END(_RamfuncsRunEnd),
    PAGE = 0, ALIGN(4)
    2. f28004x_codestartbranch.asm =========================================================================>>
    WD_DISABLE .set 0 ;set to 1 to disable WD, else set to 0
    .ref _c_int00
    .global code_start
    .sect "codestart"
    .sect "OTP_KEY"
    .int 0x5AFF
    .sect "OTP_BMODE"
    .int 0xFFFF
    .sect "OTP_Boot"
    .int 0xFF03
    code_start:
    .if WD_DISABLE == 1
    LB wd_disable ;Branch to watchdog disable code
    .else
    LB _c_int00 ;Branch to start of boot._asm in RTS library
    .endif
    ;end codestart section
    * Function: wd_disable
    * Description: Disables the watchdog timer
    .if WD_DISABLE == 1
    .text
    wd_disable:
    SETC OBJMODE ;Set OBJMODE for 28x object code
    EALLOW ;Enable EALLOW protected register access
    MOVZ DP, #7029h>>6 ;Set data page for WDCR register
    MOV @7029h, #0068h ;Set WDDIS bit in WDCR to disable WD
    EDIS ;Disable EALLOW protected register access
    .endif
    ;end wd_disable
    .end
    ;// End of file.
  • Johnny,
    I skimmed through your code. I didn't see any major issue with your .cmd / .asm file except for below line. But, it is practically difficult to review customer code line by line.
    it should be instead
    OTP_Boot : > OTP_Boot, PAGE = 0 /*Add by me*/
    Did you make sure OTP locations are programmed with right intended data to begin with?
    Manoj
  • Dear Manoj,
    OK, Thanks a lot for your help,
    It can work now.
