Part Number: LAUNCHXL-F28377S
Hi e2e community,
I have an issue similar to described in this post: the program boots from flash after power up, but there is no SCI (UART) connection with cable plugged until reset button is pressed.
I went a little further in troubleshooting and noticed that the problem persists even if the DSP is powered from external +3.3V power supply (with JP1 removed) and not from USB. FTDI chip is still powered from USB.
That post has solutions based on voltage monitoring and additional capacitance to reset circuit which cannot be applied to my case as the board remains powered when the USB cable is unplugged.
Any help is appreciated
