LAUNCHXL-F28377S: SCI boot flash programming with C2prog
Part Number: LAUNCHXL-F28377S
Hi all,
I'd like to know flash programming with SCI boot.
Currently I get the following error in C2prog.
I am writing FLASH by the following flow.
1) Generate a hex file with the following settings.
2) Make the LAUNCHXL-28377S's boot pin SCI boot
3) Power on the board and start up with SCI boot
4) Run C2Prog with the following settings.
5) Then the following error is output.
*** PLEASE RESET TARGET IN SCI BOOT-LOADER MODE ***
Connecting with target (autobaud)... OK.
Bootloading... failed (no response)!
Are there other required settings?
Sasaki
