TMS320F280049: PRD, CMPA and CMPB seem not updated at the same time when enabling shadow mode using driverlib
Part Number: TMS320F280049
Hi expert,
I am trying to make 50% duty square wave and switching its frequency between 70kHz and 250kHz on F280049C LaunchPad use both PWM5 and PWM6. I made a constant 40kHz interrupt using PWM4 and want to update the PRD, CMPA and CMPB value at the PWM5's counter equal zero event. Shadow loading is enabled on period and for compare values the shadow load mode is enabled by default.
When I doing test, there is always a inter-frequency wave in between the 70kHz and 250kHz like below.
// FILE:   epwm_ex2_updown_aq.c
// TITLE:  ePWM Action Qualifier Module - Using up/down count.
//! \addtogroup driver_example_list
//! <h1> ePWM Up Down Count Action Qualifier</h1>
//! This example configures ePWM1, ePWM2, ePWM3 to produce a waveform with
//! independent modulation on ePWMxA and ePWMxB.
//! The compare values CMPA and CMPB are modified within the ePWM's ISR.
//! The TB counter is in up/down count mode for this example.
//! View the ePWM1A/B(GPIO0 & GPIO1), ePWM2A/B(GPIO2 &GPIO3)
//! and ePWM3A/B(GPIO4 & GPIO5) waveforms on oscilloscope.
// $TI Release: F28004x Support Library v1.05.00.00 $
// $Release Date: Tue Jun 26 03:10:30 CDT 2018 $
// $Copyright:
// Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
// Defines
#define PWM_FREQ_250K   250000U
#define PWM_FREQ_70K     70000U
#define PWM_FREQ_40K     40000U
#define TBCLK         50000000U//Project specific configuration pre-scaler and high speed pre-scaler are both 1. SYSCLK is 100MHz
#define EPWM_TIMER_TBPRD_250K  (uint16_t)(TBCLK/PWM_FREQ_250K)//Counter period value for 250K
#define EPWM_TIMER_TBPRD_70K    (uint16_t)(TBCLK/PWM_FREQ_70K)//Counter period value for 70K
#define EPWM_TIMER_TBPRD_40K    (uint16_t)(TBCLK/PWM_FREQ_40K)//Counter period value for 70K
#define EPWM_CMPA_250K         (uint16_t)(EPWM_TIMER_TBPRD_250K/2)
#define EPWM_CMPB_250K         (uint16_t)(EPWM_TIMER_TBPRD_250K/2)
#define EPWM_CMPA_70K          (uint16_t)(EPWM_TIMER_TBPRD_70K/2)
#define EPWM_CMPB_70K          (uint16_t)(EPWM_TIMER_TBPRD_70K/2)
#define EPWM_CMP_UP           1U
#define EPWM_CMP_DOWN         0U
#define PWM_F_70
// Globals
typedef struct
    uint32_t epwmModule;
    uint16_t epwmCompADirection;
    uint16_t epwmCompBDirection;
    uint16_t epwmTimerIntCount;
    uint16_t epwmMaxCompA;
    uint16_t epwmMinCompA;
    uint16_t epwmMaxCompB;
    uint16_t epwmMinCompB;
}epwmInformation;
// Globals to hold the ePWM information used in this example
epwmInformation epwm5Info;
// Function Prototypes
void initEPWM(void);
//__interrupt void epwm1ISR(void);
__interrupt void controlISR(void);
void updateCompare(epwmInformation *epwmInfo);
int i = 0;
// Main
void main(void)
    int i = 0;//Counter for interrupt
    epwm5Info.epwmModule = EPWM5_BASE;
    // Initialize device clock and peripherals
    Device_init();
    // Disable pin locks and enable internal pull ups.
    Device_initGPIO();
    // Initialize PIE and clear PIE registers. Disables CPU interrupts.
    Interrupt_initModule();
    // Initialize the PIE vector table with pointers to the shell Interrupt
    // Service Routines (ISR).
    Interrupt_initVectorTable();
    // Assign the interrupt service routines to ePWM interrupts
    Interrupt_register(INT_EPWM4, &controlISR);
    // Configure GPIO10/11 and GPIO8/9 as ePWM6A/6B and ePWM5A/5B respectively
    // On F280049C LP J4-40 GPIO10 J4-39 GPIO11 J4-38 GPIO8 J4-37 GPIO9
    GPIO_setPadConfig(10, GPIO_PIN_TYPE_STD);
    GPIO_setPinConfig(GPIO_10_EPWM6A);
    GPIO_setPadConfig(11, GPIO_PIN_TYPE_STD);
    GPIO_setPinConfig(GPIO_11_EPWM6B);
    GPIO_setPadConfig(8, GPIO_PIN_TYPE_STD);
    GPIO_setPinConfig(GPIO_8_EPWM5A);
    GPIO_setPadConfig(9, GPIO_PIN_TYPE_STD);
    GPIO_setPinConfig(GPIO_9_EPWM5B);
    // Disable sync(Freeze clock to PWM as well)
    SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
    initEPWM();
    // Enable sync and clock to PWM
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
    // Enable ePWM interrupts
    Interrupt_enable(INT_EPWM4);
    // Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
    EINT;
    ERTM;
    // IDLE loop. Just sit and loop forever (optional):
    for(;;)
        NOP;
// controlISR
    i++;
    // Update the CMPA and CMPB values
    if(i == 10){
    updateCompare(&epwm5Info);
    i = 0;
    // Clear INT flag for this timer
    EPWM_clearEventTriggerInterruptFlag(EPWM4_BASE);
    // Acknowledge interrupt group
    Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP3);
// initEPWM1 - Configure ePWM1
void initEPWM()
    // Set-up TBCLK
    EPWM_setTimeBasePeriod(EPWM6_BASE, EPWM_TIMER_TBPRD_70K);//Sets the period of the PWM count.
    EPWM_setPhaseShift(EPWM6_BASE, 0U);//Sets the 16 bit time-base counter phase of the ePWM relative to the time-base.
    EPWM_setTimeBaseCounter(EPWM6_BASE, 0U);//Sets the 16 bit counter value of the time base counter.
    // Set Compare values
    EPWM_setCounterCompareValue(EPWM6_BASE,
                                EPWM_COUNTER_COMPARE_A,
                                EPWM_CMPA_70K);
                                EPWM_COUNTER_COMPARE_B,
                                EPWM_CMPB_70K);
    // Set up counter mode
    EPWM_setTimeBaseCounterMode(EPWM6_BASE, EPWM_COUNTER_MODE_UP_DOWN);
    EPWM_disablePhaseShiftLoad(EPWM6_BASE);//Disables loading of phase shift occurs.
    EPWM_setClockPrescaler(EPWM6_BASE,
                           EPWM_CLOCK_DIVIDER_1,
                           EPWM_HSCLOCK_DIVIDER_1);//PWMCLK = TBCLK = 50MHz in this case
    // Set up shadowing
    EPWM_setCounterCompareShadowLoadMode(EPWM6_BASE,
                                         EPWM_COMP_LOAD_ON_CNTR_ZERO);
    EPWM_selectPeriodLoadEvent(EPWM6_BASE, EPWM_SHADOW_LOAD_MODE_COUNTER_ZERO);
    // Set actions
    EPWM_setActionQualifierAction(EPWM6_BASE,
                                  EPWM_AQ_OUTPUT_A,
                                  EPWM_AQ_OUTPUT_HIGH,
                                  EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
                                  EPWM_AQ_OUTPUT_A,
                                  EPWM_AQ_OUTPUT_LOW,
                                  EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
                                  EPWM_AQ_OUTPUT_B,
                                  EPWM_AQ_OUTPUT_LOW,
                                  EPWM_AQ_OUTPUT_B,
// initEPWM2 - Configure ePWM2
    // Set-up TBCLK
    EPWM_setTimeBasePeriod(EPWM5_BASE, EPWM_TIMER_TBPRD_70K);
    EPWM_setPhaseShift(EPWM5_BASE, 0U);
    EPWM_setTimeBaseCounter(EPWM5_BASE, 0U);
    EPWM_setCounterCompareValue(EPWM5_BASE,
                                EPWM_CMPA_70K);
                                EPWM_CMPB_70K);
    // Set-up counter mode
    EPWM_setTimeBaseCounterMode(EPWM5_BASE, EPWM_COUNTER_MODE_UP_DOWN);
    EPWM_disablePhaseShiftLoad(EPWM5_BASE);
    EPWM_setClockPrescaler(EPWM5_BASE,
    // Set-up shadowing
    EPWM_setCounterCompareShadowLoadMode(EPWM5_BASE,
    EPWM_selectPeriodLoadEvent(EPWM5_BASE, EPWM_SHADOW_LOAD_MODE_COUNTER_ZERO);
    // Set actions
    EPWM_setActionQualifierAction(EPWM5_BASE,
                                  EPWM_AQ_OUTPUT_A,
                                  EPWM_AQ_OUTPUT_LOW,
                                  EPWM_AQ_OUTPUT_A,
                                  EPWM_AQ_OUTPUT_B,
                                  EPWM_AQ_OUTPUT_B,
                                  EPWM_AQ_OUTPUT_LOW,
    // Set-up EPWM4 for control ISR
    EPWM_setTimeBasePeriod(EPWM4_BASE, EPWM_TIMER_TBPRD_40K);//Sets the period of the PWM count.
    EPWM_setPhaseShift(EPWM4_BASE, 0U);//Sets the 16 bit time-base counter phase of the ePWM relative to the time-base.
    EPWM_setTimeBaseCounter(EPWM4_BASE, 0U);//Sets the 16 bit counter value of the time base counter.
    EPWM_setTimeBaseCounterMode(EPWM4_BASE, EPWM_COUNTER_MODE_UP_DOWN);
    EPWM_disablePhaseShiftLoad(EPWM4_BASE);//Disables loading of phase shift occurs.
    EPWM_setClockPrescaler(EPWM4_BASE,
    // Interrupt where we will change the Compare Values
    // Select INT on Time base counter zero event,
    // Enable INT, generate INT on 3rd event
    EPWM_setInterruptSource(EPWM4_BASE, EPWM_INT_TBCTR_ZERO);//Update at carrier valley
    EPWM_enableInterrupt(EPWM4_BASE);
    EPWM_setInterruptEventCount(EPWM4_BASE, 1U);
    //Update period and comparator value together
    EPWM_setupEPWMLinks(EPWM6_BASE, EPWM_LINK_WITH_EPWM_5, EPWM_LINK_TBPRD);
    EPWM_setupEPWMLinks(EPWM6_BASE, EPWM_LINK_WITH_EPWM_5, EPWM_LINK_COMP_A);
    EPWM_setupEPWMLinks(EPWM6_BASE, EPWM_LINK_WITH_EPWM_5, EPWM_LINK_COMP_B);
    //Synchronization
//    EPWM_setSyncOutPulseMode(EPWM4_BASE, EPWM_SYNC_OUT_PULSE_ON_EPWMxSYNCIN);
//    EPWM_setSyncOutPulseMode(EPWM5_BASE, EPWM_SYNC_OUT_PULSE_ON_EPWMxSYNCIN);
//    EPWM_setSyncOutPulseMode(EPWM6_BASE, EPWM_SYNC_OUT_PULSE_ON_EPWMxSYNCIN);
    //Set synchronize source
    //Set Period load mode.
    EPWM_setPeriodLoadMode(EPWM4_BASE, EPWM_PERIOD_SHADOW_LOAD);
    EPWM_setPeriodLoadMode(EPWM5_BASE, EPWM_PERIOD_SHADOW_LOAD);
    EPWM_setPeriodLoadMode(EPWM6_BASE, EPWM_PERIOD_SHADOW_LOAD);
//    EPWM_enableGlobalLoad(EPWM4_BASE);
//    EPWM_enableGlobalLoad(EPWM5_BASE);
//    EPWM_enableGlobalLoad(EPWM6_BASE);
//    EPWM_selectPeriodLoadEvent(EPWM4_BASE, EPWM_SHADOW_LOAD_MODE_COUNTER_SYNC);
//    EPWM_selectPeriodLoadEvent(EPWM5_BASE, EPWM_SHADOW_LOAD_MODE_COUNTER_SYNC);
//    EPWM_selectPeriodLoadEvent(EPWM6_BASE, EPWM_SHADOW_LOAD_MODE_COUNTER_SYNC);
    //See Pgae 1650 of TRM for block
    //Set dead band
    EPWM_setDeadBandCounterClock(EPWM5_BASE,EPWM_DB_COUNTER_CLOCK_HALF_CYCLE);
    //OUT mode
    EPWM_setDeadBandDelayMode(EPWM5_BASE, EPWM_DB_RED, true);
    EPWM_setDeadBandDelayMode(EPWM5_BASE, EPWM_DB_FED, true);
    //IN_MODE
    EPWM_setRisingEdgeDeadBandDelayInput(EPWM5_BASE, EPWM_DB_INPUT_EPWMA);
    EPWM_setFallingEdgeDeadBandDelayInput(EPWM5_BASE, EPWM_DB_INPUT_EPWMA);
    //Set delay
    EPWM_setRisingEdgeDelayCount(EPWM5_BASE, 5);
    EPWM_setFallingEdgeDelayCount(EPWM5_BASE, 5);
    //Polarity
    EPWM_setDeadBandDelayPolarity(EPWM5_BASE, EPWM_DB_RED, EPWM_DB_POLARITY_ACTIVE_HIGH);
    EPWM_setDeadBandDelayPolarity(EPWM5_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_LOW);
    //PWM output is not swapped.
    EPWM_setDeadBandOutputSwapMode(EPWM1_BASE, EPWM_DB_OUTPUT_A,0);
    EPWM_setDeadBandOutputSwapMode(EPWM1_BASE, EPWM_DB_OUTPUT_B,0);
    EPWM_setDeadBandCounterClock(EPWM6_BASE,EPWM_DB_COUNTER_CLOCK_HALF_CYCLE);
    //OUT mode
    EPWM_setDeadBandDelayMode(EPWM6_BASE, EPWM_DB_RED, true);
    EPWM_setDeadBandDelayMode(EPWM6_BASE, EPWM_DB_FED, true);
    //IN_MODE
    EPWM_setRisingEdgeDeadBandDelayInput(EPWM6_BASE, EPWM_DB_INPUT_EPWMB);
    EPWM_setFallingEdgeDeadBandDelayInput(EPWM6_BASE, EPWM_DB_INPUT_EPWMB);
    //Set delay
    EPWM_setRisingEdgeDelayCount(EPWM6_BASE, 50);
    EPWM_setFallingEdgeDelayCount(EPWM6_BASE, 50);
    //Polarity
    EPWM_setDeadBandDelayPolarity(EPWM6_BASE, EPWM_DB_RED, EPWM_DB_POLARITY_ACTIVE_HIGH);
    EPWM_setDeadBandDelayPolarity(EPWM6_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_LOW);
    EPWM_setDeadBandOutputSwapMode(EPWM6_BASE, EPWM_DB_OUTPUT_A,0);
    EPWM_setDeadBandOutputSwapMode(EPWM6_BASE, EPWM_DB_OUTPUT_B,0);
// updateCompare - Function to update the frequency
    uint16_t compAValue;
    uint16_t compBValue;
    uint16_t period;
    //Change frequency
    period = EPWM_getTimeBasePeriod(epwmInfo->epwmModule);
    if(period == EPWM_TIMER_TBPRD_70K){
        period = EPWM_TIMER_TBPRD_250K;
        compAValue = EPWM_CMPA_250K;
        compBValue = EPWM_CMPB_250K;
    }else
        period = EPWM_TIMER_TBPRD_70K;
        compAValue = EPWM_CMPA_70K;
        compBValue = EPWM_CMPB_70K;
    EPWM_setTimeBasePeriod(epwmInfo->epwmModule, period);
    EPWM_setCounterCompareValue(epwmInfo->epwmModule, EPWM_COUNTER_COMPARE_A, compAValue);
    EPWM_setCounterCompareValue(epwmInfo->epwmModule, EPWM_COUNTER_COMPARE_B, compBValue);
I am not so familiar with driverlib APIs, could you give me some advice on thee code to fix this?
Thanks!
epwm_phase_shift.zip
  • Hi Sheldon,
    Are you looking at ePWM output A or B?  If it is B, which is high at zero and goes low between CMPAU and CMPAD this waveform would make sense for two back-to-back frequencies where the frequency changes at zero event (the 3 horizontal red segments are the same length as are the 3 horizontal purple segments):
  • Hi Devin,
    I am capturing PWM6A and put output to high state when counter go up across CMPA and to low when counter go down across CMPA. In another case, the low state between two frequency seems not okay, could you kindly help me with it?
    Thanks!
  • Hi Sheldon,
    Does this happen at every transition, or only sometimes? It might be worthwhile to toggle a GPIO at the start and end of the control update ISR or at the start and end of the updateCompare() function. You can then compare the timings for good/bad transitions to try and see if the timing difference makes sense as to why some transitions work and some don't.
  • Hi Devin,
    The "long time 0" happens sometimes. I will try this on my side. Thanks for your advice!
  • Hi Devin,
    I try to toggle a GPIO on every update event and capture some waveform when switching from 250K to 70K. Please give me some advice. It seems the registers are not being updated on the same time (counter to zero). Thanks!
  • Hi Sheldon,
    The control ISR is asynchronous to the ePWM waveform, so you wouldn't expect the register update to occur at the same time for each transition between frequencies.
    I think what you want to look at is whether there is a correlation between where the update occurs and what the transition between frequencies looks like (since you were seeing different transition behavior in different transition instances).   e.g. it might be the case that an update very near the zero event causes some issues but one that occurs well before the zero event does what you expect.
  • Thanks you Devin. Solved!
