is it possible to have an example about the correct way to get the reset cause of the microcontroller.
I have performed some tests, I have found the following results:
| Reset cause | RESC register | driverlib APIs |
| POR |
No bit set. Expected (POR and XRSn bits set). |
No bit set. Expected (POR and XRSn bits set) |
| WDT | WDRSn bit set (OK) | XRSn and WDRSn bits set |
| Debugger | No bit set (OK) |
No bit set or XRSn bit set. The last case XRSn bit seems to be sticky after performing a WDT reset. |
Thank you,
Carlo
