Part Number: TMS320F28062
Celes.
It sounds like you may have some board or ESD issues where you are damaging units during the programming process. I have a few thoughts.
Mark
Mark,
Thanks for your prompt reply firstly, by the way I have further questions based on your answer and suggestion.
1. We following safe production handling procedure, after the first programming and testing and befor the second loading, conformal coating had been used on the board for preventing ESD damaging.
2.This is our mature product, the voltage which can be tested are normal.
3. After the first programming before the second loading, the previous program can run normally, we can test by testing facility watching its functional instruction on the led, motor, input output display etc.
This issue happen not on every board, just on a few about 20% this batch. I hope you could give me more suggestion, thank you.
