Part Number: TMS320F280040C
Dear All
Are there plans to add FSI to the simulink block of F28004xC?
Dear All
Hi Hayaoki.
Please can you help with the use case for this interface.
That will help us plan to come up with a requirement for this feature.
We can take it up in future to add support if we have a customer with specific use cases.
Dear all
“Using the fast serial interface (FSI) with multiple devices in an application”
I want to do the above application note of TI with Simulink.
Please.
Best regards
Hi Hayaoki,
I couldn't understand your question.
Do you want to write an application note similar to the above one using Simulink
(or) Do you want to implement an application as mentioned in the app note but using Simulink.
Please clarify. Venkatesh will help you.
Thanks, Katta
Dear All
Thank you for pointing out the confusing points.
I want to try using Simulink to do what is written in the application note.
For that purpose, I think that FSI block is necessary for F28004x block.
Please add FSI blocks as soon as possible.
I am waiting for you.
Hayaoki
Hi Hayaoki,
We have taken the request for supporting this feature. However, we cannot commit for a date and time when this will be available.
We will see what inputs we can provide to help you come up with a workaround in the mean time.
Please give us couple of days for the same.
Hi Hayaoki,
I studied the application report.
I would say supporting customer on this topic is beyond the scope of technical support.
Please contact MathWorks for consulting opportunity.
Dear all
C: \ ti \ c2000 \ C2000Ware_2_00_00_02 \ driverlib \ f28004x \ driverlib
Is there any way to make the driver source code from in simulink available?
Best regardsake the driver source code from in simulink available?
Hayaoki
I am sorry for asking questions that I have trouble answering.
When FSI blocks are added in R2019A Target Update
I'm glad.
We plan to test the RS485 by August.
I try with communication function such as SCI of the existing block.
Thank you for reading this application note.
Add target peripherals or
We hope to support the new target (TMS320F28388x).
