Compiler/TMS320F28069M: Merging bootloader and application projects
Part Number: TMS320F28069M
I have two projects. One project for bootloader and another for my application(motor_controller). I want to merge  bootloader.out and motor_controller.out files to create a single .out file, which I can flash.
I referred to this link  http://processors.wiki.ti.com/index.php/Combining_executable_files .
I have followed the Example 3: Build boot loader with embedded boot image
ofd2000.exe motor_controller.out
Output seen:
Step 1:
Create the boot image of the application:
hex2000.exe motor_controller.out --section_name_prefix = 'app_image' --load_image -o app_image.obj
Output seen:
ofd2000.exe app_image.obj
output seen:
Step2 :
lnk2000.exe c2000_bootloader.obj app_image.obj F28069_bl.cmd -o boot.out /*  here F28069_bl.cmd is the linker command script i am using */
Output seen :
I am also attaching my linker( attached F28069_bl.txt changed the format to .txt as cmd was unable to attach)
Can anybody help me understand this problem and help me merge the out files.
// FILE:    F28069.cmd
// TITLE:   Linker Command File For F28069 Device
// $TI Release: F2806x Support Library v2.04.00.00 $
// $Release Date: Mon May 27 06:46:38 CDT 2019 $
// $Copyright:
// Copyright (C) 2009-2019 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// For Code Composer Studio V2.2 and later
// In addition to this memory linker command file,
// add the header linker command file directly to the project.
// The header linker command file is required to link the
// peripheral structures to the proper locations within
// the memory map.
// The header linker files are found in <base>\headers\cmd
// For BIOS applications add:      F2806x_Headers_BIOS.cmd
// For nonBIOS applications add:   F2806x_Headers_nonBIOS.cmd
// For Code Composer Studio prior to V2.2
// 1) Use one of the following -l statements to include the
// header linker command file in the project. The header linker
// file is required to link the peripheral structures to the proper
// locations within the memory map                                    */
/* Uncomment this line to include file only for non-BIOS applications */
/* -l F2806x_Headers_nonBIOS.cmd */
/* Uncomment this line to include file only for BIOS applications */
/* -l F2806x_Headers_BIOS.cmd */
/* 2) In your project add the path to <base>\headers\cmd to the
   library search path under project->build options, linker tab,
   library search path (-i).
/* Define the memory block start/length for the F2806x
   PAGE 0 will be used to organize program sections
   PAGE 1 will be used to organize data sections
   Notes:
         Memory blocks on F28069 are uniform (ie same
         physical memory) in both PAGE 0 and PAGE 1.
         That is the same memory region should not be
         defined for both PAGE 0 and PAGE 1.
         Doing so will result in corruption of program
         and/or data.
         Contiguous SARAM memory blocks can be combined
         if required to create a larger memory block.
MEMORY
PAGE 0 :   /* Program Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
   RAML01234    : origin = 0x008000, length = 0x004000     /* on-chip RAM block L0 */
/*   RAML0       : origin = 0x008000, length = 0x000800 */    /* on-chip RAM block L0 */
/*   RAML1       : origin = 0x008800, length = 0x000400 */    /* on-chip RAM block L1 */
/*   RAML2       : origin = 0x008C00, length = 0x000400 */    /* on-chip RAM block L2 */
/*   RAML3       : origin = 0x009000, length = 0x001000    */  /* on-chip RAM block L3 */
   OTP         : origin = 0x3D7800, length = 0x000400     /* on-chip OTP */
/*   FLASHH      : origin = 0x3D8000, length = 0x004000  */   /* on-chip FLASH */
   BL_FH       : origin = 0x3D8000, length = 0x002000     /* on-chip FLASH for bootloader*/
  /* APP_FH      : origin = 0x3DA000, length = 0x002000 */    /* on-chip FLASH for application*/
  APP_FLASH   : origin = 0x3DC000, length = 0x01BF80     /* on-chip FLASH for application*/
   //FLASHG      : origin = 0x3DC000, length = 0x004000     /* on-chip FLASH */
   //FLASHF      : origin = 0x3E0000, length = 0x004000     /* on-chip FLASH */
   //FLASHE      : origin = 0x3E4000, length = 0x004000     /* on-chip FLASH */
   //FLASHD      : origin = 0x3E8000, length = 0x004000     /* on-chip FLASH */
   //FLASHC      : origin = 0x3EC000, length = 0x004000     /* on-chip FLASH */
   //FLASHA      : origin = 0x3F4000, length = 0x003F80     /* on-chip FLASH */
   CSM_RSVD    : origin = 0x3F7F80, length = 0x000076     /* Part of FLASHA.  Program with all 0x0000 when CSM is in use. */
   BEGIN       : origin = 0x3F7FF6, length = 0x000002     /* Part of FLASHA.  Used for "boot to Flash" bootloader mode. */
   CSM_PWL_P0  : origin = 0x3F7FF8, length = 0x000008     /* Part of FLASHA.  CSM password locations in FLASHA */
   FPUTABLES   : origin = 0x3FD860, length = 0x0006A0      /* FPU Tables in Boot ROM */
   IQTABLES    : origin = 0x3FDF00, length = 0x000B50     /* IQ Math Tables in Boot ROM */
   IQTABLES2   : origin = 0x3FEA50, length = 0x00008C     /* IQ Math Tables in Boot ROM */
   IQTABLES3   : origin = 0x3FEADC, length = 0x0000AA      /* IQ Math Tables in Boot ROM */
   ROM         : origin = 0x3FF3B0, length = 0x000C10     /* Boot ROM */
   RESET       : origin = 0x3FFFC0, length = 0x000002     /* part of boot ROM  */
   VECTORS     : origin = 0x3FFFC2, length = 0x00003E     /* part of boot ROM  */
PAGE 1 :   /* Data Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
           /* Registers remain on PAGE1                                                  */
   BOOT_RSVD   : origin = 0x000000, length = 0x000050     /* Part of M0, BOOT rom will use this for stack */
   RAMM0       : origin = 0x000050, length = 0x0003B0     /* on-chip RAM block M0 */
   RAMM1       : origin = 0x000400, length = 0x000400     /* on-chip RAM block M1 */
  /* RAML4       : origin = 0x00A000, length = 0x002000  */   /* on-chip RAM block L4 */
   RAML5       : origin = 0x00C000, length = 0x002000     /* on-chip RAM block L5 */
   RAML678       : origin = 0x00E000, length = 0x006000     /* on-chip RAM block L6 */
 /*  RAML78       : origin = 0x010000, length = 0x004000   */  /* on-chip RAM block L7 */
  /* RAML8       : origin = 0x012000, length = 0x002000  */   /* on-chip RAM block L8 */
   USB_RAM     : origin = 0x040000, length = 0x000800     /* USB RAM          */
   FLASHB      : origin = 0x3F0000, length = 0x004000     /* on-chip FLASH */
/* Allocate sections to memory blocks.
   Note:
         codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
                   execution when booting to flash
         ramfuncs  user defined section to store functions that will be copied from Flash into RAM
SECTIONS
   /* Allocate program areas: */
   bl_table            : > 0x3D8000,
                         LOAD_START(_BLTableStart),
                         LOAD_END(_BLTableEnd),
                         LOAD_SIZE(_BLTableSize),
                         PAGE = 0
   app_table           : > 0x3F4000,   PAGE = 0, type = DSECT
   codestart           : > BEGIN
   GROUP              : > BL_FH,
                         LOAD_START(_InitLoadStart),
                         LOAD_END(_InitLoadEnd),
                         LOAD_SIZE(_InitLoadSize),
                         PAGE = 0
        codestart_n
        .cinit
        .pinit
        normal
   GROUP               : LOAD = BL_FH,
                         RUN = RAML01234,
                         LOAD_START(_RamfuncsLoadStart),
                         LOAD_END(_RamfuncsLoadEnd),
                         LOAD_SIZE(_RamfuncsLoadSize),
                         RUN_START(_RamfuncsRunStart)
       .text
       .econst
       ramfuncs
                         RUN =  0x3DE000,
                         LOAD_START(_FailsafeLoadStart),
                         LOAD_END(_FailsafeLoadEnd),
                         LOAD_SIZE(_FailsafeLoadSize),
                         RUN_START(_FailsafeRunStart),
                         PAGE = 0
           codestart_f
           failsafe
   .app_image          : {*(image_1)} > LOAD=APP_FLASH, RUN=RAML01234
   csmpasswds          : > CSM_PWL_P0, PAGE = 0
   csm_rsvd            : > CSM_RSVD,   PAGE = 0
   /* Allocate uninitalized data sections: */
   .stack              : > RAMM1,      PAGE = 1
   .ebss               : >>  RAML5 | RAML678,      PAGE = 1
   .esysmem            : >>  RAML5,      PAGE = 1
   CRC32_TABLE           : > RAML5,      PAGE = 1
  /* DMARAML6               : > RAML6,      PAGE = 1 */
  /* DMARAML7               : > RAML7,      PAGE = 1 */
  /* DMARAML8               : > RAML8,      PAGE = 1   */
  /* Uncomment the section below if calling the IQNexp() or IQexp()
      functions from the IQMath.lib library in order to utilize the
      relevant IQ Math table in Boot ROM (This saves space and Boot ROM
      is 1 wait-state). If this section is not uncommented, IQmathTables2
      will be loaded into other memory (SARAM, Flash, etc.) and will take
      up space, but 0 wait-state is possible.
   IQmathTables2    : > IQTABLES2, PAGE = 0, TYPE = NOLOAD
              IQmath.lib<IQNexpTable.obj> (IQmathTablesRam)
    /* Uncomment the section below if calling the IQNasin() or IQasin()
    IQmathTables3    : > IQTABLES3, PAGE = 0, TYPE = NOLOAD
               IQmath.lib<IQNasinTable.obj> (IQmathTablesRam)
   /* .reset is a standard section used by the compiler.  It contains the */
   /* the address of the start of _c_int00 for C Code.   /*
   /* When using the boot ROM this section and the CPU vector */
   /* table is not needed.  Thus the default type is set here to  */
   /* DSECT  */
   .reset              : > RESET,      PAGE = 0, TYPE = DSECT
   vectors             : > VECTORS,    PAGE = 0, TYPE = DSECT
// End of file.
Nandini
  • You made a syntax error in your linker command file.  On this line ...
    Remove the character ">".  Then it will work.
    The linker should do a better job of telling you about this syntax error.  So, I filed the entry CODEGEN-6499 in the SDOWP system to have this investigated.  You are welcome to follow it with the SDOWP link below in my signature.
    Thanks and regards,
    -George
  • Hello George,
    Thanks a lot for quick reply. I did remove the character ">", this resolved the first 3 errors. I still do have errors. These errors must be because of my placement of the sections and grouping them in boot loader and application. I am attaching my both linker files for reference.
    // FILE:    F28069.cmd
    // $Copyright:
    // are met:
    //   distribution.
    // the memory map.
       Notes:
             and/or data.
    MEMORY
       BL_FH       : origin = 0x3D8000, length = 0x004000     /* on-chip FLASH for bootloader*/
       Note:
    SECTIONS
                             PAGE = 0
       codestart           : > BEGIN
       GROUP              : > BL_FH,
                             PAGE = 0
            codestart_n
            .cinit
            .pinit
            normal
                             RUN = RAML01234,
           .text
           .econst
           ramfuncs
                             RUN =  0x3DE000,
                             PAGE = 0
               codestart_f
               failsafe
      .app_image          : {*(app_image_1)} LOAD=FLASH, RUN=RAML01234
       /* DSECT  */
    // End of file.
    // FILE:    F28069.cmd
    // $TI Release: F2806x C/C++ Header Files and Peripheral Examples V135 $
    // $Release Date: Sep 8, 2012 $
    // the memory map.
    // The header linker files are found in <base>\F2806x_headers\cmd
    /* 2) In your project add the path to <base>\F2806x_headers\cmd to the
       Notes:
             and/or data.
    MEMORY
       FPUTABLES   : origin = 0x3FD590, length = 0x0006A0	 /* FPU Tables in Boot ROM */
       IQTABLES    : origin = 0x3FDC30, length = 0x000B50    /* IQ Math Tables in Boot ROM */
       IQTABLES2   : origin = 0x3FE780, length = 0x00008C    /* IQ Math Tables in Boot ROM */
       IQTABLES3   : origin = 0x3FE80C, length = 0x0000AA	 /* IQ Math Tables in Boot ROM */
       RAMM0_1     : origin = 0x000050, length = 0x0007B0     /* on-chip RAM block M0 */
       RAM         : origin = 0x008000, length = 0x00B800     /* on-chip RAM */
       Note:
    SECTIONS
       GROUP               : > APP_FLASH,     PAGE = 0, crc_table(_CRCTestVector)
           .cinit
           .pinit
           .text
           /* Initalized sections to go in Flash */
           /* For SDFlash to program these, they must be allocated to page 0 */
           .econst
           .switch
       .binit              : {} > APP_FLASH,    PAGE = 0
       codestart           : > BEGIN,    PAGE = 0
       .TI.ramfunc         : {} LOAD=APP_FLASH PAGE = 0,crc_table(_CRCTestVector)
                                RUN=RAM    PAGE = 1,
                                TABLE(BINIT)
       .stack              : > RAM,      PAGE = 1
       .ebss               : > RAM,    PAGE = 1
       .esysmem            : > RAM,    PAGE = 1
       .TI.crctab         : > APP_FLASH
       /* Allocate IQ math areas: */
       IQmath              : > APP_FLASH,   PAGE = 0            /* Math Code */
       IQmathTables        : > IQTABLES,     PAGE = 0, TYPE = NOLOAD
       /* Allocate FPU math areas: */
       FPUmathTables       : > FPUTABLES,  PAGE = 0, TYPE = NOLOAD
       /* DSECT  */
    // End of file.
    output:
    . I am unable to build the bootloader project as well with this linker file. I get these errors.
    "../F28069_bl.cmd", line 206: warning: no matching section
    "../F28069_bl.cmd", line 206: warning: memory range not found: RAML01234 on
       page 1
    "../F28069_bl.cmd", line 206: error: program will not fit into available
       memory.  run placement with alignment/blocking fails for section
       ".app_image" size 0 page 1
    Nandini
  • Hello George,
    // FILE:    F28069.cmd
    // $Copyright:
    // are met:
    //   distribution.
    // the memory map.
       Notes:
             and/or data.
    MEMORY
       Note:
    SECTIONS
                             PAGE = 0
       codestart           : > BEGIN
       GROUP              : > BL_FH,
                             PAGE = 0
            codestart_n
            .cinit
            .pinit
            normal
                             RUN = RAML01234,
           .text
           .econst
           ramfuncs
                             RUN =  0x3DE000,
                             PAGE = 0
               codestart_f
               failsafe
       /* DSECT  */
    // End of file.
    // FILE:    F28069.cmd
    // the memory map.
       Notes:
             and/or data.
    MEMORY
       Note:
    SECTIONS
           .cinit
           .pinit
           .text
           .econst
           .switch
                                RUN=RAM    PAGE = 1,
                                TABLE(BINIT)
       /* DSECT  */
    // End of file.
    output:
       page 1
    Nandini
  • I reproduced similar problems.  I made two changes, and the problems disappeared.
    On this line ...
    Change FLASH to APP_FLASH.  There is no memory range named FLASH, though there are several memory range names that are similar.  I think you intend to use APP_FLASH, though you might intend to use a different one.
    On this line ...
    codestart           : > BEGIN
    Change it to ...
    codestart           : > BEGIN, PAGE 0
    Thanks and regards,
    -George
  • Hello George,
    Thank you for pointing this out. I was able to figure that and now I am able to merge boot loader and application.
    Now I see a problem with app_table not being updated in the merged.out file.
    app_table is defined in boot loader project in bl_entrytable.asm  as
        .def _pAppEntry
        .def _pAppSig
     .sect "app_table"
    app_table:
    _pAppEntry    .long 0
    _pAppSig      .long 0
     And in my application project I have app_table defined as
        .ref _pAppEntry
        .ref _pAppSig
       .sect "app_table"
    app_table:
    _pAppEntry    .long code_start
    _pAppSig      .long _CRCTestVector
    When I load the application.out . The memory location app_table in
    memory location: 0x3f4000 :code_start(0x003F 7FF6)
    0x3f4002 :_CRCTestVector(0x003E 58CC)
    which is correct.
    But my merge .out has app_table content as
    memory location: 0x3f4000 : (0xFFFF FFFF)
    0x3f4002 : (0xFFFF FFFF)
    Seems like this section has been not merged. Is it because both section has same content, ie same symbols?
    How do I merge these symbols and point to the correct location which is present in the application software?
    Nandini
  • Regarding the problem where the linker did not find the BEGIN memory range on PAGE 0 ... I filed the entry CODEGEN-6506 in the SDOWP system to have this investigated.  You are welcome to follow it with the SDOWP link below in my signature.
    Thanks and regards,
    -George
