LM5116: HB resistor
Part Number: LM5116
Following is mentioned on the datasheet.
"Use of an HB resistor for this function should be carefully evaluated so as not cause potentially harmful negative voltage to the high-side driver, and is generally limited to 2.2-Ω maximum.".
What does "harmful negative voltage" mean?
How behavior is supposed by large HB resistor?
Kuramochi
