Hi TI Community,
i try here to shifting my two PWMs (ePWM1A and ePWM1B) with 180 degree, i used your example of epwm _synchronization, and i got a shift between two ePWMs for example ePWM1 and ePWM2. and now how cana i get a shift for ePWMA and ePWMB and not an inverted signal.
Thank you!
here is my initEPWM1:
void initEPWM1_Configuration(void)
EPWM_setClockPrescaler(EPWM1_BASE,
EPWM_CLOCK_DIVIDER_1,
EPWM_HSCLOCK_DIVIDER_1);
EPWM_setTimeBaseCounterMode(EPWM1_BASE, EPWM_COUNTER_MODE_UP);
EPWM_setTimeBaseCounter(EPWM1_BASE, 0);// count initial value setting
EPWM_setTimeBasePeriod(EPWM1_BASE, EPWM_TIMER_TBPRD); //count cycle fs=300khz
EPWM_setPeriodLoadMode(EPWM1_BASE, EPWM_PERIOD_SHADOW_LOAD);// CYCLE LOADING MODE
EPWM_setCounterCompareShadowLoadMode(EPWM1_BASE,
EPWM_COUNTER_COMPARE_A,
EPWM_COMP_LOAD_ON_CNTR_ZERO_PERIOD); // comparison value loading mode
EPWM_COUNTER_COMPARE_B,
EPWM_setCounterCompareValue(EPWM1_BASE, EPWM_COUNTER_COMPARE_A, Duty_cycle); //Set the comparison value
EPWM_setCounterCompareValue(EPWM1_BASE, EPWM_COUNTER_COMPARE_B, Duty_cycle);
EPWM_setActionQualifierAction(EPWM1_BASE,
EPWM_AQ_OUTPUT_A,
EPWM_AQ_OUTPUT_LOW,
EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA); //ePWMA
EPWM_AQ_OUTPUT_A,
EPWM_AQ_OUTPUT_HIGH,
EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
EPWM_AQ_OUTPUT_B,
EPWM_AQ_OUTPUT_LOW,
EPWM_AQ_OUTPUT_B,
EPWM_setSyncOutPulseMode(EPWM1_BASE, EPWM_SYNC_OUT_PULSE_ON_COUNTER_ZERO); //Synchronize pulse when counting to zero
EPWM_setRisingEdgeDeadBandDelayInput(EPWM1_BASE,EPWM_DB_INPUT_EPWMA);
EPWM_setFallingEdgeDeadBandDelayInput(EPWM1_BASE, EPWM_DB_INPUT_EPWMA); //Configure dead zone input mode
EPWM_setDeadBandDelayPolarity(EPWM1_BASE,EPWM_DB_RED,EPWM_DB_POLARITY_ACTIVE_HIGH);
EPWM_setDeadBandDelayPolarity(EPWM1_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_HIGH); // configuration polarity
EPWM_setDeadBandDelayMode(EPWM1_BASE,EPWM_DB_RED,true);
EPWM_setDeadBandDelayMode(EPWM1_BASE, EPWM_DB_FED, true); //Configure output mode
EPWM_setDeadBandOutputSwapMode(EPWM1_BASE,EPWM_DB_OUTPUT_A,false);
EPWM_setDeadBandOutputSwapMode(EPWM1_BASE, EPWM_DB_OUTPUT_B, false); //Output is not exchanged
EPWM_setRisingEdgeDelayCount(EPWM1_BASE, Dead_Band_RED); //Rising edge delay 0nS
EPWM_setFallingEdgeDelayCount(EPWM1_BASE, Dead_Band_FED); //falling edge delay 0nS
