Other Parts Discussed in Thread: MOTORWARE
I saw in the TMDSHVMTRINSPIN manual that if the board is powered by the AC line, the ground of the board is floating and the protective earth is not connected to the board, so I should not connect the ground probe of the oscilloscope to the ground of the board.
My question is what if I power the board with a DC power supply in which the negative and ground are connected. Will the ground of the board still be floating in this case or it will be the earth ground, so I ca connect the oscilloscope ground to it?
Ata
