Part Number: TMS320F2812
Other Parts Discussed in Thread: CONTROLSUITE, C2000WARE
Hi TI expert, please tell me how to find the demo code about f2812, such as pmsm3_1 to 3_4.thanks
The codes you are referring to are not actively in the support list. You can refer to controlSuite or MCSDK for the list of example projects/codes available and supported.
If PMSM control is what you need, download and install controlSUITE and refer to example projects at
C:\ti\controlSUITE\development_kits\HVMotorCtrl+PfcKit_v2.1
Hope it helps.
Hi Ramesh,
I am separately (from the above ask) looking for any/all sample CCS code/projects for the F2812. Where in general does TI provide sample code/projects for the F2812? I do not anything in C2000Ware (http://www.ti.com/tool/C2000WARE ).
Thanks, Merril
F2812 is a predecessor to F28035. Both are fixed point CPUs. In the link I referred above, you will see example projects of F28035 that you may be able to use for F2812. C2000ware is pretty recent and it does not carry any examples of F2812 or even F28035 for that matter.
The F281x device-centric examples can be found at the below under "C281x C/C++ Header Files and Peripheral Examples":
http://www.ti.com/product/TMS320F2812/toolssoftware
For motor related software for the F281x device family, note the following e2e thread:
https://e2e.ti.com/support/microcontrollers/c2000/f/171/p/235921/826471#826471
The motor software links in the F281x product page are currently down & we'll look to bring them back.
In the mean time you can put the sprc# you are looking to get by entering it as a URL as in below.
http://www.ti.com/lit/zip/sprc###
However, as Ramesh mentions please do note that this is an older device. Newer and more feature rich devices like the F28035 exist (or the F2837x or F28004x) & the motor control examples for those newer devices will be more up-to-date. So if you are just starting out with motor control with C2000, I'd highly recommend for you to start with one of those newer devices.
Thank you,
Brett
Am closing the thread as we nothing more to add. If you have any other queries, post it in a new thread.
