what is the relationship between hall sensor sequence and PWM sequence for 3 phase BLDC motor?
for hall sensor which has 60 degree or 120 degree position, if the hall sensor sequence are same? and if the relationship between PWM sequence and hall sensor sequence also same or not? pls help provide a PWM sequence table based on different hall sensor sequence if possible, thanks
