Part Number: TMS320F280049
Hello Support team.
Customer is using Stack Usage feature of CCS.
Then customer confirmed that some “Inclusive Stack” are yellow bar.
On other E2E thread, Yellow bar means that “The yellow is a warning that indicated that you are close to the limit of available stacks space while green indicates that you are not.”
Customer confirmed that this yellow bar indicates 106 (byte) even though stack size is 512 byte.
Customer wants to know which variable this Stack Usage uses to determine the maximum stack size.
Also Customers want to know how Stack Usage of CCS determines "Yellow bar" from both using stack size and maximum stack size.
Best Regards
KORO
