Please let me know how to import a project, which created in CCS3.1 or 3.3, to CCS9.
Naoki,
In CCSv9 on the Project menu there is an item called "Import Legacy CCSv3.3 Projects"
That can be used to import a CCSv3 project and create a project in CCSv9.
However that is likely just the first step in your migration. There is more than 10 years between when CCSv3 and CCSv9 were released. The compiler in CCSv9 is much newer and the option sets have changed. CCS will attempt to migrate the options for you but you may have adjustments to make. I am not sure if your Application uses DSP/BIOS or not. If it does you may need to look at moving to a newer version.
The CCS environment has also changed a lot. Here is a link to a CCS workshop for C2000. It was written for CCSv7 but is still very applicable to CCSv9. That will help with getting familiar with the newer CCS.
http://dev.ti.com/tirex/explore/node?node=ANJXzL69ZqXoHLjas70yCQ__FUz-xrs__LATEST
John
This is a big jump in tool versions.
Just adding to John's reply above, past e2e threads are your best be in trying to find procedures and considerations to perform this task. Please check the references below.
Considerations when migrating a legacy project:
https://e2e.ti.com/support/tools/ccs/f/81/t/218175
Analyzing the migration.log file:
https://e2e.ti.com/support/tools/ccs/f/81/t/53700
Considerations when making a decision to migrate or keep the existing development environment:
https://e2e.ti.com/support/tools/ccs/f/81/p/581352/2147264#2147264
If you are using DSP/BIOS, there will be many steps expecially if you are using CCSv3.1 and DSP/BIOS 4.90. Please check the following e2e threads for references.
Migrating a project from CCSv3.1:
https://e2e.ti.com/support/tools/ccs/f/81/t/136794
Built-in CSL (Chip Support Library) support:
https://e2e.ti.com/support/tools/ccs/f/81/t/109857
RTA (Real-time Analysis) tools support status:
https://e2e.ti.com/support/tools/ccs/f/81/t/299367
Hope this helps,
Rafael
