Part Number: TMS320F28379D
Hi
I have a device that is sending CAN message at my LAUNCHXL-F28379D board at 500kb/s with different message IDs.
I set up four message object with the same obj ID and different msg ID.
CAN_setupMessageObject(CANB_BASE, OBJ_ID_FROM_AMK, 0x283, //AMK_ACT_VAL_1 FL
CAN_MSG_FRAME_STD, CAN_MSG_OBJ_TYPE_RX, 0xFFFFFFFF,
CAN_MSG_OBJ_RX_INT_ENABLE | CAN_MSG_OBJ_USE_ID_FILTER, MSG_DATA_LENGTH);
CAN_setupMessageObject(CANB_BASE, OBJ_ID_FROM_AMK, 0x284, //AMK_ACT_VAL_1 FR
CAN_MSG_FRAME_STD, CAN_MSG_OBJ_TYPE_RX, 0xFFFFFFF0,
CAN_setupMessageObject(CANB_BASE, OBJ_ID_FROM_AMK, 0x287, //AMK_ACT_VAL_1 RL
CAN_MSG_FRAME_STD, CAN_MSG_OBJ_TYPE_RX, 0xFFFFFFE1,
CAN_setupMessageObject(CANB_BASE, OBJ_ID_FROM_AMK, 0x288, //AMK_ACT_VAL_1 RR
CAN_MSG_FRAME_STD, CAN_MSG_OBJ_TYPE_RX, 0xFFFFFFD2,
When i try to read them it happens something unusal:
the messages with ID 0x284, 0x287 and 0x288 are received just fine, but when i try to send a message with ID 0x283 it does not get received but it behave as if there where no msg Obj with such ID.
Far more strange, if i try to send a message with ID 0x285 it gets read!
I know this has something to do with ID filter and masking but i don't know how it works.
I tried to look on the TRM and on the E2E forum, with no results.
Any help is appreciated
