Part Number: CCSTUDIO-C2000
Dear C2000 Users,
On-chip Flash Plugin in CCSv9.3 has a DCSM related bug that prevents re-programming of the Flash once the password is programmed in to the device. If you encounter Flash program failure even after writing the correct password in the Flash Plugin GUI in CCSv9.3, please check for updates in CCS and install the "Debug Server Flash" patch v10.0.0.1936 or higher. This should fix the issue. This bug fix is already implemented in CCSv10 and it should work by default with not required updates.
This issue does not exist in any other CCS version prior to CCSv9.3.
Please let us know if you have any questions on this.
Thanks and regards,
Vamsi
C2000 System SW team
