i am using TMDSCNCD280049M for generating a 3.3V PWM output, there is a way to low the voltage to 2.2V?
generate 2.2 V pwm output
Thank you
Michael
Thank you
Michael
MCU digital outputs have fixed logic levels. PWMs switch as per the switching characteristics of the IOs defined in the product datasheet. Hence it doesn't support 2.2v output generation. You can use external components to divide the voltage down.
