I enable EPWM module 1~6, with the same period and 1/6 phase shift. I want to get a ADCSOCAO pulse on each EPWM module CTR_PRD event.
The pin ADCSOCAO is connected to EPWM module 1, but connected to other PWM modules.
How to config PWM module?
Sheng,
the following E2E post is the best solution for your question.
https://e2e.ti.com/support/microcontrollers/c2000/f/171/p/669728/2463811#2463811
Cody
If you are using a F28335 device, you will not have CMPC and CMPD available, but you should still be able to use a PWM configured at a higher frequency to trigger your ADC SOC.
Cody
