Compiler/TMS320F2809: long long type multiplication
Part Number: TMS320F2809
Here's code I tested.
when x=-100, alpha=1000
hpftest1 = 65436000, not -100000
int32 HPF(int32 x, int32 *x_old, int32 *y_old_h, int32 *y_old_l, uint16 alpha)
int64 tmp1, tmp2, tmp3;
tmp1 = ((int64)(x - *x_old)) * (int32)alpha;
hpftest1 = tmp1;
tmp2 = (((((int64)(*y_old_h))<<32) | *y_old_l) * (int32)alpha) >> HPF_SHIFT; // 48 bit * 16 bit >> 16 = 48 bit
hpftest2 = tmp2;
tmp3 = tmp1 + tmp2;
*y_old_h = tmp3 >> 32;
*y_old_l = tmp3 & 0xffffffff;
*x_old = x;
return tmp3 >> HPF_SHIFT;
I tested this code on x86 PC and it works correctly.
I think C2000 compiler has the problem to deal with long long type variable.
Any suggestions and ideas are appreciated.
Thank you.
  • For the source file that contains this function, please follow the directions in the article How to Submit a Compiler Test Case.  In addition, please state the value of all the inputs to the function.
    As for the pointer arguments ...  I don't need to know the value of x_old, but I do need to know the value of *x_old.  The same is true of *y_old_h and *y_old_l.
    Thanks and regards,
    -George
    Thank you for replying.
    I generated .pp file and present the information you need.
    Compiler Version: 4.1.3
    Compiler Option:
    ["Compiler" Settings: "Debug"]
    Options=-pds9 -fr"$(Proj_dir)\Debug" -fs"$(Proj_dir)\Debug" -i"$(Proj_dir)\Include(TI)" -d"_DEBUG" -d"LARGE_MODEL" -ml -mt -v28
    ["Compiler" Settings: "Release"]
    Options=-o3 -fr"$(Proj_dir)\Release" -i"$(Proj_dir)\Include(TI)" -d"LARGE_MODEL" -ml -v28
    ["Linker" Settings: "Debug"]
    Options=-c -heap0x2000 -m".\Debug\ALLGrp_S100_Main.map" -o".\Debug\ALLGrp_S100_Main.out" -stack0x400 -w -x
    ["Linker" Settings: "Release"]
    Options=-c -m".\Release\ALLGrp_S100_Main.map" -o".\Release\ALLGrp_S100_Main.out" -w -x
    ["KPD_TBL_X.c" Settings: "Debug"]
    Options="Compiler" +{-pden -pds70 -pds770}
    ["Mot_Pwm.C" Settings: "Debug"]
    Options="Compiler" +{-al}
    ["test1.c" Settings: "Debug"]
    Options="Compiler" +{-ppa -ppc}
    ["F2809_Start.cmd" Settings: "Debug"]
    LinkOrder=1
    ["F2809_Start.cmd" Settings: "Release"]
    LinkOrder=1
    Preprocessed File:
    // TI File $Revision: /main/4 $
    // Checkin $Date: August 2, 2006 16:58:50 $
    // FILE: DSP280x_Device.h
    // TITLE: DSP280x Device Definitions.
    // $TI Release: DSP280x, DSP2801x Header Files V1.41 $
    // $Release Date: August 7th, 2006 $
    // User To Select Target Device:
    // Common CPU Definitions:
    extern cregister volatile unsigned int IFR;
    extern cregister volatile unsigned int IER;
    #define BIT0 0x0001
    #define BIT1 0x0002
    #define BIT2 0x0004
    #define BIT3 0x0008
    #define BIT4 0x0010
    #define BIT5 0x0020
    #define BIT6 0x0040
    #define BIT7 0x0080
    #define BIT8 0x0100
    #define BIT9 0x0200
    #define BIT10 0x0400
    #define BIT11 0x0800
    #define BIT12 0x1000
    #define BIT13 0x2000
    #define BIT14 0x4000
    #define BIT15 0x8000
    // For Portability, User Is Recommended To Use Following Data Type Size
    // Definitions For 16-bit and 32-Bit Signed/Unsigned Integers:
    typedef int int16;
    typedef long int32;
    typedef unsigned int Uint16;
    typedef unsigned long Uint32;
    typedef float float32;
    typedef long double float64;
    // Include All Peripheral Header Files:
    // TI File $Revision: /main/2 $
    // Checkin $Date: December 2, 2004 13:40:05 $
    // FILE: DSP280x_Adc.h
    // TITLE: DSP280x Device ADC Register Definitions.
    // ADC Individual Register Bit Definitions:
    struct ADCTRL1_BITS { // bits description
    Uint16 rsvd1:4; // 3:0 reserved
    Uint16 SEQ_CASC:1; // 4 Cascaded sequencer mode
    Uint16 SEQ_OVRD:1; // 5 Sequencer override
    Uint16 CONT_RUN:1; // 6 Continuous run
    Uint16 CPS:1; // 7 ADC core clock pre-scalar
    Uint16 ACQ_PS:4; // 11:8 Acquisition window size
    Uint16 SUSMOD:2; // 13:12 Emulation suspend mode
    Uint16 RESET:1; // 14 ADC reset
    Uint16 rsvd2:1; // 15 reserved
    union ADCTRL1_REG {
    Uint16 all;
    struct ADCTRL1_BITS bit;
    struct ADCTRL2_BITS { // bits description
    Uint16 EPWM_SOCB_SEQ2:1; // 0 EPWM compare B SOC mask for SEQ2
    Uint16 rsvd1:1; // 1 reserved
    Uint16 INT_MOD_SEQ2:1; // 2 SEQ2 Interrupt mode
    Uint16 INT_ENA_SEQ2:1; // 3 SEQ2 Interrupt enable
    Uint16 rsvd2:1; // 4 reserved
    Uint16 SOC_SEQ2:1; // 5 Start of conversion for SEQ2
    Uint16 RST_SEQ2:1; // 6 Reset SEQ2
    Uint16 EXT_SOC_SEQ1:1; // 7 External start of conversion for SEQ1
    Uint16 EPWM_SOCA_SEQ1:1; // 8 EPWM compare B SOC mask for SEQ1
    Uint16 rsvd3:1; // 9 reserved
    Uint16 INT_MOD_SEQ1:1; // 10 SEQ1 Interrupt mode
    Uint16 INT_ENA_SEQ1:1; // 11 SEQ1 Interrupt enable
    Uint16 rsvd4:1; // 12 reserved
    Uint16 SOC_SEQ1:1; // 13 Start of conversion trigger for SEQ1
    Uint16 RST_SEQ1:1; // 14 Restart sequencer 1
    Uint16 EPWM_SOCB_SEQ:1; // 15 EPWM compare B SOC enable
    union ADCTRL2_REG {
    Uint16 all;
    struct ADCTRL2_BITS bit;
    struct ADCASEQSR_BITS { // bits description
    Uint16 SEQ1_STATE:4; // 3:0 SEQ1 state
    Uint16 SEQ2_STATE:3; // 6:4 SEQ2 state
    Uint16 rsvd1:1; // 7 reserved
    Uint16 SEQ_CNTR:4; // 11:8 Sequencing counter status
    Uint16 rsvd2:4; // 15:12 reserved
    union ADCASEQSR_REG {
    Uint16 all;
    struct ADCASEQSR_BITS bit;
    struct ADCMAXCONV_BITS { // bits description
    Uint16 MAX_CONV1:4; // 3:0 Max number of conversions
    Uint16 MAX_CONV2:3; // 6:4 Max number of conversions
    Uint16 rsvd1:9; // 15:7 reserved
    union ADCMAXCONV_REG {
    Uint16 all;
    struct ADCMAXCONV_BITS bit;
    struct ADCCHSELSEQ1_BITS { // bits description
    Uint16 CONV00:4; // 3:0 Conversion selection 00
    Uint16 CONV01:4; // 7:4 Conversion selection 01
    Uint16 CONV02:4; // 11:8 Conversion selection 02
    Uint16 CONV03:4; // 15:12 Conversion selection 03
    union ADCCHSELSEQ1_REG{
    Uint16 all;
    struct ADCCHSELSEQ1_BITS bit;
    struct ADCCHSELSEQ2_BITS { // bits description
    Uint16 CONV04:4; // 3:0 Conversion selection 04
    Uint16 CONV05:4; // 7:4 Conversion selection 05
    Uint16 CONV06:4; // 11:8 Conversion selection 06
    Uint16 CONV07:4; // 15:12 Conversion selection 07
    union ADCCHSELSEQ2_REG{
    Uint16 all;
    struct ADCCHSELSEQ2_BITS bit;
    struct ADCCHSELSEQ3_BITS { // bits description
    Uint16 CONV08:4; // 3:0 Conversion selection 08
    Uint16 CONV09:4; // 7:4 Conversion selection 09
    Uint16 CONV10:4; // 11:8 Conversion selection 10
    Uint16 CONV11:4; // 15:12 Conversion selection 11
    union ADCCHSELSEQ3_REG{
    Uint16 all;
    struct ADCCHSELSEQ3_BITS bit;
    struct ADCCHSELSEQ4_BITS { // bits description
    Uint16 CONV12:4; // 3:0 Conversion selection 12
    Uint16 CONV13:4; // 7:4 Conversion selection 13
    Uint16 CONV14:4; // 11:8 Conversion selection 14
    Uint16 CONV15:4; // 15:12 Conversion selection 15
    union ADCCHSELSEQ4_REG {
    Uint16 all;
    struct ADCCHSELSEQ4_BITS bit;
    struct ADCTRL3_BITS { // bits description
    Uint16 SMODE_SEL:1; // 0 Sampling mode select
    Uint16 ADCCLKPS:4; // 4:1 ADC core clock divider
    Uint16 ADCPWDN:1; // 5 ADC powerdown
    Uint16 ADCBGRFDN:2; // 7:6 ADC bandgap/ref power down
    Uint16 rsvd1:8; // 15:8 reserved
    union ADCTRL3_REG {
    Uint16 all;
    struct ADCTRL3_BITS bit;
    struct ADCST_BITS { // bits description
    Uint16 INT_SEQ1:1; // 0 SEQ1 Interrupt flag
    Uint16 INT_SEQ2:1; // 1 SEQ2 Interrupt flag
    Uint16 SEQ1_BSY:1; // 2 SEQ1 busy status
    Uint16 SEQ2_BSY:1; // 3 SEQ2 busy status
    Uint16 INT_SEQ1_CLR:1; // 4 SEQ1 Interrupt clear
    Uint16 INT_SEQ2_CLR:1; // 5 SEQ2 Interrupt clear
    Uint16 EOS_BUF1:1; // 6 End of sequence buffer1
    Uint16 EOS_BUF2:1; // 7 End of sequence buffer2
    union ADCST_REG {
    Uint16 all;
    struct ADCST_BITS bit;
    struct ADCREFSEL_BITS { // bits description
    Uint16 rsvd1:14; // 13:0 reserved
    Uint16 REF_SEL:2; // 15:14 Reference select
    union ADCREFSEL_REG {
    Uint16 all;
    struct ADCREFSEL_BITS bit;
    struct ADCOFFTRIM_BITS{ // bits description
    int16 OFFSET_TRIM:9; // 8:0 Offset Trim
    Uint16 rsvd1:7; // 15:9 reserved
    union ADCOFFTRIM_REG{
    Uint16 all;
    struct ADCOFFTRIM_BITS bit;
    struct ADC_REGS {
    union ADCTRL1_REG ADCTRL1; // ADC Control 1
    union ADCTRL2_REG ADCTRL2; // ADC Control 2
    union ADCMAXCONV_REG ADCMAXCONV; // Max conversions
    union ADCCHSELSEQ1_REG ADCCHSELSEQ1; // Channel select sequencing control 1
    union ADCCHSELSEQ2_REG ADCCHSELSEQ2; // Channel select sequencing control 2
    union ADCCHSELSEQ3_REG ADCCHSELSEQ3; // Channel select sequencing control 3
    union ADCCHSELSEQ4_REG ADCCHSELSEQ4; // Channel select sequencing control 4
    union ADCASEQSR_REG ADCASEQSR; // Autosequence status register
    Uint16 ADCRESULT0; // Conversion Result Buffer 0
    Uint16 ADCRESULT1; // Conversion Result Buffer 1
    Uint16 ADCRESULT2; // Conversion Result Buffer 2
    Uint16 ADCRESULT3; // Conversion Result Buffer 3
    Uint16 ADCRESULT4; // Conversion Result Buffer 4
    Uint16 ADCRESULT5; // Conversion Result Buffer 5
    Uint16 ADCRESULT6; // Conversion Result Buffer 6
    Uint16 ADCRESULT7; // Conversion Result Buffer 7
    Uint16 ADCRESULT8; // Conversion Result Buffer 8
    Uint16 ADCRESULT9; // Conversion Result Buffer 9
    Uint16 ADCRESULT10; // Conversion Result Buffer 10
    Uint16 ADCRESULT11; // Conversion Result Buffer 11
    Uint16 ADCRESULT12; // Conversion Result Buffer 12
    Uint16 ADCRESULT13; // Conversion Result Buffer 13
    Uint16 ADCRESULT14; // Conversion Result Buffer 14
    Uint16 ADCRESULT15; // Conversion Result Buffer 15
    union ADCTRL3_REG ADCTRL3; // ADC Control 3
    union ADCST_REG ADCST; // ADC Status Register
    Uint16 rsvd1;
    Uint16 rsvd2;
    union ADCREFSEL_REG ADCREFSEL; // Reference Select Register
    union ADCOFFTRIM_REG ADCOFFTRIM; // Offset Trim Register
    struct ADC_RESULT_MIRROR_REGS
    // ADC External References & Function Declarations:
    extern volatile struct ADC_REGS AdcRegs;
    extern volatile struct ADC_RESULT_MIRROR_REGS AdcMirror;
    // End of file.
    // TI File $Revision: /main/3 $
    // Checkin $Date: September 8, 2005 15:51:55 $
    // FILE: DSP280x_DevEmu.h
    // TITLE: DSP280x Device Emulation Register Definitions.
    // Device Emulation Register Bit Definitions:
    // Device Configuration Register Bit Definitions
    struct DEVICECNF_BITS { // bits description
    Uint16 rsvd1:3; // 2:0 reserved
    Uint16 VMAPS:1; // 3 VMAP Status
    Uint16 XRSn:1; // 5 XRSn Signal Status
    Uint16 rsvd3:10; // 15:6
    Uint16 rsvd4:3; // 18:6
    Uint16 ENPROT:1; // 19 Enable/Disable pipeline protection
    Uint16 MONPRIV:1; // 20 MONPRIV enable bit
    Uint16 rsvd5:1; // 21 reserved
    Uint16 EMU0SEL:2; // 23,22 EMU0 Mux select
    Uint16 EMU1SEL:2; // 25,24 EMU1 Mux select
    Uint16 rsvd6:6; // 31:26 reserved
    union DEVICECNF_REG {
    Uint32 all;
    struct DEVICECNF_BITS bit;
    // PARTID
    struct PARTID_BITS { // bits description
    Uint16 PARTNO:8; // 7:0 Part Number
    Uint16 PARTTYPE:8; // 15:8 Part Type
    union PARTID_REG {
    Uint16 all;
    struct PARTID_BITS bit;
    struct DEV_EMU_REGS {
    union DEVICECNF_REG DEVICECNF; // device configuration
    union PARTID_REG PARTID; // Part ID
    Uint16 REVID; // Device ID
    Uint16 PROTSTART; // Write-Read protection start
    Uint16 PROTRANGE; // Write-Read protection range
    Uint16 rsvd2[202];
    // Device Emulation Register References & Function Declarations:
    extern volatile struct DEV_EMU_REGS DevEmuRegs;
    // End of file.
    // TI File $Revision: /main/1 $
    // Checkin $Date: December 1, 2004 12:31:30 $
    // FILE: DSP280x_CpuTimers.h
    // TITLE: DSP280x CPU 32-bit Timers Register Definitions.
    // NOTES: CpuTimer1 and CpuTimer2 are reserved for use with DSP BIOS and
    // other realtime operating systems.
    // Do not use these two timers in your application if you ever plan
    // on integrating DSP-BIOS or another realtime OS.
    // For this reason, the code to manipulate these two timers is
    // commented out and not used in these examples.
    // CPU Timer Register Bit Definitions:
    // TCR: Control register bit definitions:
    struct TCR_BITS { // bits description
    Uint16 TSS:1; // 4 Timer Start/Stop
    Uint16 TRB:1; // 5 Timer reload
    Uint16 rsvd2:4; // 9:6 reserved
    Uint16 SOFT:1; // 10 Emulation modes
    Uint16 FREE:1; // 11
    Uint16 rsvd3:2; // 12:13 reserved
    Uint16 TIE:1; // 14 Output enable
    Uint16 TIF:1; // 15 Interrupt flag
    union TCR_REG {
    Uint16 all;
    struct TCR_BITS bit;
    // TPR: Pre-scale low bit definitions:
    struct TPR_BITS { // bits description
    Uint16 TDDR:8; // 7:0 Divide-down low
    Uint16 PSC:8; // 15:8 Prescale counter low
    union TPR_REG {
    Uint16 all;
    struct TPR_BITS bit;
    // TPRH: Pre-scale high bit definitions:
    struct TPRH_BITS { // bits description
    Uint16 TDDRH:8; // 7:0 Divide-down high
    Uint16 PSCH:8; // 15:8 Prescale counter high
    union TPRH_REG {
    Uint16 all;
    struct TPRH_BITS bit;
    // TIM, TIMH: Timer register definitions:
    struct TIM_REG {
    Uint16 LSW;
    Uint16 MSW;
    union TIM_GROUP {
    Uint32 all;
    struct TIM_REG half;
    // PRD, PRDH: Period register definitions:
    struct PRD_REG {
    Uint16 LSW;
    Uint16 MSW;
    union PRD_GROUP {
    Uint32 all;
    struct PRD_REG half;
    // CPU Timer Register File:
    struct CPUTIMER_REGS {
    union TIM_GROUP TIM; // Timer counter register
    union PRD_GROUP PRD; // Period register
    union TCR_REG TCR; // Timer control register
    Uint16 rsvd1; // reserved
    union TPR_REG TPR; // Timer pre-scale low
    union TPRH_REG TPRH; // Timer pre-scale high
    // CPU Timer Support Variables:
    struct CPUTIMER_VARS {
    volatile struct CPUTIMER_REGS *RegsAddr;
    Uint32 InterruptCount;
    float CPUFreqInMHz;
    float PeriodInUSec;
    // Function prototypes and external definitions:
    void InitCpuTimers(void);
    void ConfigCpuTimer(struct CPUTIMER_VARS *Timer, float Freq, float Period);
    extern volatile struct CPUTIMER_REGS CpuTimer0Regs;
    extern struct CPUTIMER_VARS CpuTimer0;
    // CpuTimer 1 and CpuTimer2 are reserved for DSP BIOS & other RTOS
    //extern volatile struct CPUTIMER_REGS CpuTimer1Regs;
    extern volatile struct CPUTIMER_REGS CpuTimer2Regs;
    //extern struct CPUTIMER_VARS CpuTimer1;
    extern struct CPUTIMER_VARS CpuTimer2;
    // Usefull Timer Operations:
    // Start Timer:
    // Stop Timer:
    // Reload Timer With period Value:
    // Read 32-Bit Timer Value:
    // Read 32-Bit Period Value:
    // Do not use these two timers if you ever plan on integrating
    // DSP-BIOS or another realtime OS.
    // Start Timer:
    //#define StartCpuTimer1() CpuTimer1Regs.TCR.bit.TSS = 0
    //#define StartCpuTimer2() CpuTimer2Regs.TCR.bit.TSS = 0
    // Stop Timer:
    //#define StopCpuTimer1() CpuTimer1Regs.TCR.bit.TSS = 1
    //#define StopCpuTimer2() CpuTimer2Regs.TCR.bit.TSS = 1
    //#define ReloadCpuTimer1() CpuTimer1Regs.TCR.bit.TRB = 1
    //#define ReloadCpuTimer2() CpuTimer2Regs.TCR.bit.TRB = 1
    //#define ReadCpuTimer1Counter() CpuTimer1Regs.TIM.all
    //#define ReadCpuTimer2Counter() CpuTimer2Regs.TIM.all
    //#define ReadCpuTimer1Period() CpuTimer1Regs.PRD.all
    //#define ReadCpuTimer2Period() CpuTimer2Regs.PRD.all
    // End of file.
    // Checkin $Date: December 1, 2004 12:31:37 $
    // FILE: DSP280x_ECan.h
    // TITLE: DSP280x Device eCAN Register Definitions.
    /* eCAN Control & Status Registers */
    /* eCAN Mailbox enable register (CANME) bit definitions */
    struct CANME_BITS { // bit description
    Uint16 ME0:1; // 0 Enable Mailbox 0
    Uint16 ME1:1; // 1 Enable Mailbox 1
    Uint16 ME2:1; // 2 Enable Mailbox 2
    Uint16 ME3:1; // 3 Enable Mailbox 3
    Uint16 ME4:1; // 4 Enable Mailbox 4
    Uint16 ME5:1; // 5 Enable Mailbox 5
    Uint16 ME6:1; // 6 Enable Mailbox 6
    Uint16 ME7:1; // 7 Enable Mailbox 7
    Uint16 ME8:1; // 8 Enable Mailbox 8
    Uint16 ME9:1; // 9 Enable Mailbox 9
    Uint16 ME10:1; // 10 Enable Mailbox 10
    Uint16 ME11:1; // 11 Enable Mailbox 11
    Uint16 ME12:1; // 12 Enable Mailbox 12
    Uint16 ME13:1; // 13 Enable Mailbox 13
    Uint16 ME14:1; // 14 Enable Mailbox 14
    Uint16 ME15:1; // 15 Enable Mailbox 15
    Uint16 ME16:1; // 16 Enable Mailbox 16
    Uint16 ME17:1; // 17 Enable Mailbox 17
    Uint16 ME18:1; // 18 Enable Mailbox 18
    Uint16 ME19:1; // 19 Enable Mailbox 19
    Uint16 ME20:1; // 20 Enable Mailbox 20
    Uint16 ME21:1; // 21 Enable Mailbox 21
    Uint16 ME22:1; // 22 Enable Mailbox 22
    Uint16 ME23:1; // 23 Enable Mailbox 23
    Uint16 ME24:1; // 24 Enable Mailbox 24
    Uint16 ME25:1; // 25 Enable Mailbox 25
    Uint16 ME26:1; // 26 Enable Mailbox 26
    Uint16 ME27:1; // 27 Enable Mailbox 27
    Uint16 ME28:1; // 28 Enable Mailbox 28
    Uint16 ME29:1; // 29 Enable Mailbox 29
    Uint16 ME30:1; // 30 Enable Mailbox 30
    Uint16 ME31:1; // 31 Enable Mailbox 31
    /* Allow access to the bit fields or entire register */
    union CANME_REG {
    Uint32 all;
    struct CANME_BITS bit;
    /* eCAN Mailbox direction register (CANMD) bit definitions */
    struct CANMD_BITS { // bit description
    Uint16 MD0:1; // 0 0 -> Tx 1 -> Rx
    Uint16 MD1:1; // 1 0 -> Tx 1 -> Rx
    Uint16 MD2:1; // 2 0 -> Tx 1 -> Rx
    Uint16 MD3:1; // 3 0 -> Tx 1 -> Rx
    Uint16 MD4:1; // 4 0 -> Tx 1 -> Rx
    Uint16 MD5:1; // 5 0 -> Tx 1 -> Rx
    Uint16 MD6:1; // 6 0 -> Tx 1 -> Rx
    Uint16 MD7:1; // 7 0 -> Tx 1 -> Rx
    Uint16 MD8:1; // 8 0 -> Tx 1 -> Rx
    Uint16 MD9:1; // 9 0 -> Tx 1 -> Rx
    Uint16 MD10:1; // 10 0 -> Tx 1 -> Rx
    Uint16 MD11:1; // 11 0 -> Tx 1 -> Rx
    Uint16 MD12:1; // 12 0 -> Tx 1 -> Rx
    Uint16 MD13:1; // 13 0 -> Tx 1 -> Rx
    Uint16 MD14:1; // 14 0 -> Tx 1 -> Rx
    Uint16 MD15:1; // 15 0 -> Tx 1 -> Rx
    Uint16 MD16:1; // 16 0 -> Tx 1 -> Rx
    Uint16 MD17:1; // 17 0 -> Tx 1 -> Rx
    Uint16 MD18:1; // 18 0 -> Tx 1 -> Rx
    Uint16 MD19:1; // 19 0 -> Tx 1 -> Rx
    Uint16 MD20:1; // 20 0 -> Tx 1 -> Rx
    Uint16 MD21:1; // 21 0 -> Tx 1 -> Rx
    Uint16 MD22:1; // 22 0 -> Tx 1 -> Rx
    Uint16 MD23:1; // 23 0 -> Tx 1 -> Rx
    Uint16 MD24:1; // 24 0 -> Tx 1 -> Rx
    Uint16 MD25:1; // 25 0 -> Tx 1 -> Rx
    Uint16 MD26:1; // 26 0 -> Tx 1 -> Rx
    Uint16 MD27:1; // 27 0 -> Tx 1 -> Rx
    Uint16 MD28:1; // 28 0 -> Tx 1 -> Rx
    Uint16 MD29:1; // 29 0 -> Tx 1 -> Rx
    Uint16 MD30:1; // 30 0 -> Tx 1 -> Rx
    Uint16 MD31:1; // 31 0 -> Tx 1 -> Rx
    union CANMD_REG {
    Uint32 all;
    struct CANMD_BITS bit;
    /* eCAN Transmit Request Set register (CANTRS) bit definitions */
    struct CANTRS_BITS { // bit description
    Uint16 TRS0:1; // 0 TRS for Mailbox 0
    Uint16 TRS1:1; // 1 TRS for Mailbox 1
    Uint16 TRS2:1; // 2 TRS for Mailbox 2
    Uint16 TRS3:1; // 3 TRS for Mailbox 3
    Uint16 TRS4:1; // 4 TRS for Mailbox 4
    Uint16 TRS5:1; // 5 TRS for Mailbox 5
    Uint16 TRS6:1; // 6 TRS for Mailbox 6
    Uint16 TRS7:1; // 7 TRS for Mailbox 7
    Uint16 TRS8:1; // 8 TRS for Mailbox 8
    Uint16 TRS9:1; // 9 TRS for Mailbox 9
    Uint16 TRS10:1; // 10 TRS for Mailbox 10
    Uint16 TRS11:1; // 11 TRS for Mailbox 11
    Uint16 TRS12:1; // 12 TRS for Mailbox 12
    Uint16 TRS13:1; // 13 TRS for Mailbox 13
    Uint16 TRS14:1; // 14 TRS for Mailbox 14
    Uint16 TRS15:1; // 15 TRS for Mailbox 15
    Uint16 TRS16:1; // 16 TRS for Mailbox 16
    Uint16 TRS17:1; // 17 TRS for Mailbox 17
    Uint16 TRS18:1; // 18 TRS for Mailbox 18
    Uint16 TRS19:1; // 19 TRS for Mailbox 19
    Uint16 TRS20:1; // 20 TRS for Mailbox 20
    Uint16 TRS21:1; // 21 TRS for Mailbox 21
    Uint16 TRS22:1; // 22 TRS for Mailbox 22
    Uint16 TRS23:1; // 23 TRS for Mailbox 23
    Uint16 TRS24:1; // 24 TRS for Mailbox 24
    Uint16 TRS25:1; // 25 TRS for Mailbox 25
    Uint16 TRS26:1; // 26 TRS for Mailbox 26
    Uint16 TRS27:1; // 27 TRS for Mailbox 27
    Uint16 TRS28:1; // 28 TRS for Mailbox 28
    Uint16 TRS29:1; // 29 TRS for Mailbox 29
    Uint16 TRS30:1; // 30 TRS for Mailbox 30
    Uint16 TRS31:1; // 31 TRS for Mailbox 31
    union CANTRS_REG {
    Uint32 all;
    struct CANTRS_BITS bit;
    /* eCAN Transmit Request Reset register (CANTRR) bit definitions */
    struct CANTRR_BITS { // bit description
    Uint16 TRR0:1; // 0 TRR for Mailbox 0
    Uint16 TRR1:1; // 1 TRR for Mailbox 1
    Uint16 TRR2:1; // 2 TRR for Mailbox 2
    Uint16 TRR3:1; // 3 TRR for Mailbox 3
    Uint16 TRR4:1; // 4 TRR for Mailbox 4
    Uint16 TRR5:1; // 5 TRR for Mailbox 5
    Uint16 TRR6:1; // 6 TRR for Mailbox 6
    Uint16 TRR7:1; // 7 TRR for Mailbox 7
    Uint16 TRR8:1; // 8 TRR for Mailbox 8
    Uint16 TRR9:1; // 9 TRR for Mailbox 9
    Uint16 TRR10:1; // 10 TRR for Mailbox 10
    Uint16 TRR11:1; // 11 TRR for Mailbox 11
    Uint16 TRR12:1; // 12 TRR for Mailbox 12
    Uint16 TRR13:1; // 13 TRR for Mailbox 13
    Uint16 TRR14:1; // 14 TRR for Mailbox 14
    Uint16 TRR15:1; // 15 TRR for Mailbox 15
    Uint16 TRR16:1; // 16 TRR for Mailbox 16
    Uint16 TRR17:1; // 17 TRR for Mailbox 17
    Uint16 TRR18:1; // 18 TRR for Mailbox 18
    Uint16 TRR19:1; // 19 TRR for Mailbox 19
    Uint16 TRR20:1; // 20 TRR for Mailbox 20
    Uint16 TRR21:1; // 21 TRR for Mailbox 21
    Uint16 TRR22:1; // 22 TRR for Mailbox 22
    Uint16 TRR23:1; // 23 TRR for Mailbox 23
    Uint16 TRR24:1; // 24 TRR for Mailbox 24
    Uint16 TRR25:1; // 25 TRR for Mailbox 25
    Uint16 TRR26:1; // 26 TRR for Mailbox 26
    Uint16 TRR27:1; // 27 TRR for Mailbox 27
    Uint16 TRR28:1; // 28 TRR for Mailbox 28
    Uint16 TRR29:1; // 29 TRR for Mailbox 29
    Uint16 TRR30:1; // 30 TRR for Mailbox 30
    Uint16 TRR31:1; // 31 TRR for Mailbox 31
    union CANTRR_REG {
    Uint32 all;
    struct CANTRR_BITS bit;
    /* eCAN Transmit Acknowledge register (CANTA) bit definitions */
    struct CANTA_BITS { // bit description
    Uint16 TA0:1; // 0 TA for Mailbox 0
    Uint16 TA1:1; // 1 TA for Mailbox 1
    Uint16 TA2:1; // 2 TA for Mailbox 2
    Uint16 TA3:1; // 3 TA for Mailbox 3
    Uint16 TA4:1; // 4 TA for Mailbox 4
    Uint16 TA5:1; // 5 TA for Mailbox 5
    Uint16 TA6:1; // 6 TA for Mailbox 6
    Uint16 TA7:1; // 7 TA for Mailbox 7
    Uint16 TA8:1; // 8 TA for Mailbox 8
    Uint16 TA9:1; // 9 TA for Mailbox 9
    Uint16 TA10:1; // 10 TA for Mailbox 10
    Uint16 TA11:1; // 11 TA for Mailbox 11
    Uint16 TA12:1; // 12 TA for Mailbox 12
    Uint16 TA13:1; // 13 TA for Mailbox 13
    Uint16 TA14:1; // 14 TA for Mailbox 14
    Uint16 TA15:1; // 15 TA for Mailbox 15
    Uint16 TA16:1; // 16 TA for Mailbox 16
    Uint16 TA17:1; // 17 TA for Mailbox 17
    Uint16 TA18:1; // 18 TA for Mailbox 18
    Uint16 TA19:1; // 19 TA for Mailbox 19
    Uint16 TA20:1; // 20 TA for Mailbox 20
    Uint16 TA21:1; // 21 TA for Mailbox 21
    Uint16 TA22:1; // 22 TA for Mailbox 22
    Uint16 TA23:1; // 23 TA for Mailbox 23
    Uint16 TA24:1; // 24 TA for Mailbox 24
    Uint16 TA25:1; // 25 TA for Mailbox 25
    Uint16 TA26:1; // 26 TA for Mailbox 26
    Uint16 TA27:1; // 27 TA for Mailbox 27
    Uint16 TA28:1; // 28 TA for Mailbox 28
    Uint16 TA29:1; // 29 TA for Mailbox 29
    Uint16 TA30:1; // 30 TA for Mailbox 30
    Uint16 TA31:1; // 31 TA for Mailbox 31
    union CANTA_REG {
    Uint32 all;
    struct CANTA_BITS bit;
    /* eCAN Transmit Abort Acknowledge register (CANAA) bit definitions */
    struct CANAA_BITS { // bit description
    Uint16 AA0:1; // 0 AA for Mailbox 0
    Uint16 AA1:1; // 1 AA for Mailbox 1
    Uint16 AA2:1; // 2 AA for Mailbox 2
    Uint16 AA3:1; // 3 AA for Mailbox 3
    Uint16 AA4:1; // 4 AA for Mailbox 4
    Uint16 AA5:1; // 5 AA for Mailbox 5
    Uint16 AA6:1; // 6 AA for Mailbox 6
    Uint16 AA7:1; // 7 AA for Mailbox 7
    Uint16 AA8:1; // 8 AA for Mailbox 8
    Uint16 AA9:1; // 9 AA for Mailbox 9
    Uint16 AA10:1; // 10 AA for Mailbox 10
    Uint16 AA11:1; // 11 AA for Mailbox 11
    Uint16 AA12:1; // 12 AA for Mailbox 12
    Uint16 AA13:1; // 13 AA for Mailbox 13
    Uint16 AA14:1; // 14 AA for Mailbox 14
    Uint16 AA15:1; // 15 AA for Mailbox 15
    Uint16 AA16:1; // 16 AA for Mailbox 16
    Uint16 AA17:1; // 17 AA for Mailbox 17
    Uint16 AA18:1; // 18 AA for Mailbox 18
    Uint16 AA19:1; // 19 AA for Mailbox 19
    Uint16 AA20:1; // 20 AA for Mailbox 20
    Uint16 AA21:1; // 21 AA for Mailbox 21
    Uint16 AA22:1; // 22 AA for Mailbox 22
    Uint16 AA23:1; // 23 AA for Mailbox 23
    Uint16 AA24:1; // 24 AA for Mailbox 24
    Uint16 AA25:1; // 25 AA for Mailbox 25
    Uint16 AA26:1; // 26 AA for Mailbox 26
    Uint16 AA27:1; // 27 AA for Mailbox 27
    Uint16 AA28:1; // 28 AA for Mailbox 28
    Uint16 AA29:1; // 29 AA for Mailbox 29
    Uint16 AA30:1; // 30 AA for Mailbox 30
    Uint16 AA31:1; // 31 AA for Mailbox 31
    union CANAA_REG {
    Uint32 all;
    struct CANAA_BITS bit;
    /* eCAN Received Message Pending register (CANRMP) bit definitions */
    struct CANRMP_BITS { // bit description
    Uint16 RMP0:1; // 0 RMP for Mailbox 0
    Uint16 RMP1:1; // 1 RMP for Mailbox 1
    Uint16 RMP2:1; // 2 RMP for Mailbox 2
    Uint16 RMP3:1; // 3 RMP for Mailbox 3
    Uint16 RMP4:1; // 4 RMP for Mailbox 4
    Uint16 RMP5:1; // 5 RMP for Mailbox 5
    Uint16 RMP6:1; // 6 RMP for Mailbox 6
    Uint16 RMP7:1; // 7 RMP for Mailbox 7
    Uint16 RMP8:1; // 8 RMP for Mailbox 8
    Uint16 RMP9:1; // 9 RMP for Mailbox 9
    Uint16 RMP10:1; // 10 RMP for Mailbox 10
    Uint16 RMP11:1; // 11 RMP for Mailbox 11
    Uint16 RMP12:1; // 12 RMP for Mailbox 12
    Uint16 RMP13:1; // 13 RMP for Mailbox 13
    Uint16 RMP14:1; // 14 RMP for Mailbox 14
    Uint16 RMP15:1; // 15 RMP for Mailbox 15
    Uint16 RMP16:1; // 16 RMP for Mailbox 16
    Uint16 RMP17:1; // 17 RMP for Mailbox 17
    Uint16 RMP18:1; // 18 RMP for Mailbox 18
    Uint16 RMP19:1; // 19 RMP for Mailbox 19
    Uint16 RMP20:1; // 20 RMP for Mailbox 20
    Uint16 RMP21:1; // 21 RMP for Mailbox 21
    Uint16 RMP22:1; // 22 RMP for Mailbox 22
    Uint16 RMP23:1; // 23 RMP for Mailbox 23
    Uint16 RMP24:1; // 24 RMP for Mailbox 24
    Uint16 RMP25:1; // 25 RMP for Mailbox 25
    Uint16 RMP26:1; // 26 RMP for Mailbox 26
    Uint16 RMP27:1; // 27 RMP for Mailbox 27
    Uint16 RMP28:1; // 28 RMP for Mailbox 28
    Uint16 RMP29:1; // 29 RMP for Mailbox 29
    Uint16 RMP30:1; // 30 RMP for Mailbox 30
    Uint16 RMP31:1; // 31 RMP for Mailbox 31
    union CANRMP_REG {
    Uint32 all;
    struct CANRMP_BITS bit;
    /* eCAN Received Message Lost register (CANRML) bit definitions */
    struct CANRML_BITS { // bit description
    Uint16 RML0:1; // 0 RML for Mailbox 0
    Uint16 RML1:1; // 1 RML for Mailbox 1
    Uint16 RML2:1; // 2 RML for Mailbox 2
    Uint16 RML3:1; // 3 RML for Mailbox 3
    Uint16 RML4:1; // 4 RML for Mailbox 4
    Uint16 RML5:1; // 5 RML for Mailbox 5
    Uint16 RML6:1; // 6 RML for Mailbox 6
    Uint16 RML7:1; // 7 RML for Mailbox 7
    Uint16 RML8:1; // 8 RML for Mailbox 8
    Uint16 RML9:1; // 9 RML for Mailbox 9
    Uint16 RML10:1; // 10 RML for Mailbox 10
    Uint16 RML11:1; // 11 RML for Mailbox 11
    Uint16 RML12:1; // 12 RML for Mailbox 12
    Uint16 RML13:1; // 13 RML for Mailbox 13
    Uint16 RML14:1; // 14 RML for Mailbox 14
    Uint16 RML15:1; // 15 RML for Mailbox 15
    Uint16 RML16:1; // 16 RML for Mailbox 16
    Uint16 RML17:1; // 17 RML for Mailbox 17
    Uint16 RML18:1; // 18 RML for Mailbox 18
    Uint16 RML19:1; // 19 RML for Mailbox 19
    Uint16 RML20:1; // 20 RML for Mailbox 20
    Uint16 RML21:1; // 21 RML for Mailbox 21
    Uint16 RML22:1; // 22 RML for Mailbox 22
    Uint16 RML23:1; // 23 RML for Mailbox 23
    Uint16 RML24:1; // 24 RML for Mailbox 24
    Uint16 RML25:1; // 25 RML for Mailbox 25
    Uint16 RML26:1; // 26 RML for Mailbox 26
    Uint16 RML27:1; // 27 RML for Mailbox 27
    Uint16 RML28:1; // 28 RML for Mailbox 28
    Uint16 RML29:1; // 29 RML for Mailbox 29
    Uint16 RML30:1; // 30 RML for Mailbox 30
    Uint16 RML31:1; // 31 RML for Mailbox 31
    union CANRML_REG {
    Uint32 all;
    struct CANRML_BITS bit;
    /* eCAN Remote Frame Pending register (CANRFP) bit definitions */
    struct CANRFP_BITS { // bit description
    Uint16 RFP0:1; // 0 RFP for Mailbox 0
    Uint16 RFP1:1; // 1 RFP for Mailbox 1
    Uint16 RFP2:1; // 2 RFP for Mailbox 2
    Uint16 RFP3:1; // 3 RFP for Mailbox 3
    Uint16 RFP4:1; // 4 RFP for Mailbox 4
    Uint16 RFP5:1; // 5 RFP for Mailbox 5
    Uint16 RFP6:1; // 6 RFP for Mailbox 6
    Uint16 RFP7:1; // 7 RFP for Mailbox 7
    Uint16 RFP8:1; // 8 RFP for Mailbox 8
    Uint16 RFP9:1; // 9 RFP for Mailbox 9
    Uint16 RFP10:1; // 10 RFP for Mailbox 10
    Uint16 RFP11:1; // 11 RFP for Mailbox 11
    Uint16 RFP12:1; // 12 RFP for Mailbox 12
    Uint16 RFP13:1; // 13 RFP for Mailbox 13
    Uint16 RFP14:1; // 14 RFP for Mailbox 14
    Uint16 RFP15:1; // 15 RFP for Mailbox 15
    Uint16 RFP16:1; // 16 RFP for Mailbox 16
    Uint16 RFP17:1; // 17 RFP for Mailbox 17
    Uint16 RFP18:1; // 18 RFP for Mailbox 18
    Uint16 RFP19:1; // 19 RFP for Mailbox 19
    Uint16 RFP20:1; // 20 RFP for Mailbox 20
    Uint16 RFP21:1; // 21 RFP for Mailbox 21
    Uint16 RFP22:1; // 22 RFP for Mailbox 22
    Uint16 RFP23:1; // 23 RFP for Mailbox 23
    Uint16 RFP24:1; // 24 RFP for Mailbox 24
    Uint16 RFP25:1; // 25 RFP for Mailbox 25
    Uint16 RFP26:1; // 26 RFP for Mailbox 26
    Uint16 RFP27:1; // 27 RFP for Mailbox 27
    Uint16 RFP28:1; // 28 RFP for Mailbox 28
    Uint16 RFP29:1; // 29 RFP for Mailbox 29
    Uint16 RFP30:1; // 30 RFP for Mailbox 30
    Uint16 RFP31:1; // 31 RFP for Mailbox 31
    union CANRFP_REG {
    Uint32 all;
    struct CANRFP_BITS bit;
    /* eCAN Global Acceptance Mask register (CANGAM) bit definitions */
    struct CANGAM_BITS { // bits description
    Uint16 GAM150:16; // 15:0 Global acceptance mask bits 0-15
    Uint16 GAM2816:13; // 28:16 Global acceptance mask bits 16-28
    Uint16 rsvd:2; // 30:29 reserved
    Uint16 AMI:1; // 31 AMI bit
    union CANGAM_REG {
    Uint32 all;
    struct CANGAM_BITS bit;
    /* eCAN Master Control register (CANMC) bit definitions */
    struct CANMC_BITS { // bits description
    Uint16 MBNR:5; // 4:0 MBX # for CDR bit
    Uint16 SRES:1; // 5 Soft reset
    Uint16 STM:1; // 6 Self-test mode
    Uint16 ABO:1; // 7 Auto bus-on
    Uint16 CDR:1; // 8 Change data request
    Uint16 WUBA:1; // 9 Wake-up on bus activity
    Uint16 DBO:1; // 10 Data-byte order
    Uint16 PDR:1; // 11 Power-down mode request
    Uint16 CCR:1; // 12 Change configuration request
    Uint16 SCB:1; // 13 SCC compatibility bit
    Uint16 TCC:1; // 14 TSC MSB clear bit
    Uint16 MBCC:1; // 15 TSC clear bit thru mailbox 16
    Uint16 SUSP:1; // 16 SUSPEND free/soft bit
    Uint16 rsvd:15; // 31:17 reserved
    union CANMC_REG {
    Uint32 all;
    struct CANMC_BITS bit;
    /* eCAN Bit -timing configuration register (CANBTC) bit definitions */
    struct CANBTC_BITS { // bits description
    Uint16 TSEG2REG:3; // 2:0 TSEG2 register value
    Uint16 TSEG1REG:4; // 6:3 TSEG1 register value
    Uint16 SAM:1; // 7 Sample-point setting
    Uint16 SJWREG:2; // 9:8 Synchroniztion Jump Width register value
    Uint16 rsvd1:6; // 15:10 reserved
    Uint16 BRPREG:8; // 23:16 Baudrate prescaler register value
    Uint16 rsvd2:8; // 31:24 reserved
    union CANBTC_REG {
    Uint32 all;
    struct CANBTC_BITS bit;
    /* eCAN Error & Status register (CANES) bit definitions */
    struct CANES_BITS { // bits description
    Uint16 TM:1; // 0 Transmit Mode
    Uint16 RM:1; // 1 Receive Mode
    Uint16 rsvd1:1; // 2 reserved
    Uint16 PDA:1; // 3 Power-down acknowledge
    Uint16 CCE:1; // 4 Change Configuration Enable
    Uint16 SMA:1; // 5 Suspend Mode Acknowledge
    Uint16 rsvd2:10; // 15:6 reserved
    Uint16 EW:1; // 16 Warning status
    Uint16 EP:1; // 17 Error Passive status
    Uint16 BO:1; // 18 Bus-off status
    Uint16 ACKE:1; // 19 Acknowledge error
    Uint16 SE:1; // 20 Stuff error
    Uint16 CRCE:1; // 21 CRC error
    Uint16 SA1:1; // 22 Stuck at Dominant error
    Uint16 BE:1; // 23 Bit error
    Uint16 FE:1; // 24 Framing error
    Uint16 rsvd3:7; // 31:25 reserved
    union CANES_REG {
    Uint32 all;
    struct CANES_BITS bit;
    /* eCAN Transmit Error Counter register (CANTEC) bit definitions */
    struct CANTEC_BITS { // bits description
    Uint16 TEC:8; // 7:0 TEC
    Uint16 rsvd2:16; // 31:16 reserved
    union CANTEC_REG {
    Uint32 all;
    struct CANTEC_BITS bit;
    /* eCAN Receive Error Counter register (CANREC) bit definitions */
    struct CANREC_BITS { // bits description
    Uint16 REC:8; // 7:0 REC
    union CANREC_REG {
    Uint32 all;
    struct CANREC_BITS bit;
    /* eCAN Global Interrupt Flag 0 (CANGIF0) bit definitions */
    struct CANGIF0_BITS { // bits description
    Uint16 MIV0:5; // 4:0 Mailbox Interrupt Vector
    Uint16 rsvd1:3; // 7:5 reserved
    Uint16 WLIF0:1; // 8 Warning level interrupt flag
    Uint16 EPIF0:1; // 9 Error-passive interrupt flag
    Uint16 BOIF0:1; // 10 Bus-off interrupt flag
    Uint16 RMLIF0:1; // 11 Received message lost interrupt flag
    Uint16 WUIF0:1; // 12 Wakeup interrupt flag
    Uint16 WDIF0:1; // 13 Write denied interrupt flag
    Uint16 AAIF0:1; // 14 Abort Ack interrupt flag
    Uint16 GMIF0:1; // 15 Global MBX interrupt flag
    Uint16 TCOF0:1; // 16 TSC Overflow flag
    Uint16 MTOF0:1; // 17 Mailbox Timeout flag
    Uint16 rsvd2:14; // 31:18 reserved
    union CANGIF0_REG {
    Uint32 all;
    struct CANGIF0_BITS bit;
    /* eCAN Global Interrupt Mask register (CANGIM) bit definitions */
    struct CANGIM_BITS { // bits description
    Uint16 I0EN:1; // 0 Interrupt 0 enable
    Uint16 I1EN:1; // 1 Interrupt 1 enable
    Uint16 GIL:1; // 2 Global Interrupt Level
    Uint16 rsvd1:5; // 7:3 reserved
    Uint16 WLIM:1; // 8 Warning level interrupt mask
    Uint16 EPIM:1; // 9 Error-passive interrupt mask
    Uint16 BOIM:1; // 10 Bus-off interrupt mask
    Uint16 RMLIM:1; // 11 Received message lost interrupt mask
    Uint16 WUIM:1; // 12 Wakeup interrupt mask
    Uint16 WDIM:1; // 13 Write denied interrupt mask
    Uint16 AAIM:1; // 14 Abort Ack interrupt mask
    Uint16 TCOM:1; // 16 TSC overflow interrupt mask
    Uint16 MTOM:1; // 17 MBX Timeout interrupt mask
    Uint16 rsvd3:14; // 31:18 reserved
    union CANGIM_REG {
    Uint32 all;
    struct CANGIM_BITS bit;
    /* eCAN Global Interrupt Flag 1 (eCANGIF1) bit definitions */
    struct CANGIF1_BITS { // bits description
    Uint16 MIV1:5; // 4:0 Mailbox Interrupt Vector
    Uint16 WLIF1:1; // 8 Warning level interrupt flag
    Uint16 EPIF1:1; // 9 Error-passive interrupt flag
    Uint16 BOIF1:1; // 10 Bus-off interrupt flag
    Uint16 RMLIF1:1; // 11 Received message lost interrupt flag
    Uint16 WUIF1:1; // 12 Wakeup interrupt flag
    Uint16 WDIF1:1; // 13 Write denied interrupt flag
    Uint16 AAIF1:1; // 14 Abort Ack interrupt flag
    Uint16 GMIF1:1; // 15 Global MBX interrupt flag
    Uint16 TCOF1:1; // 16 TSC Overflow flag
    Uint16 MTOF1:1; // 17 Mailbox Timeout flag
    union CANGIF1_REG {
    Uint32 all;
    struct CANGIF1_BITS bit;
    /* eCAN Mailbox Interrupt Mask register (CANMIM) bit definitions */
    struct CANMIM_BITS { // bit description
    Uint16 MIM0:1; // 0 MIM for Mailbox 0
    Uint16 MIM1:1; // 1 MIM for Mailbox 1
    Uint16 MIM2:1; // 2 MIM for Mailbox 2
    Uint16 MIM3:1; // 3 MIM for Mailbox 3
    Uint16 MIM4:1; // 4 MIM for Mailbox 4
    Uint16 MIM5:1; // 5 MIM for Mailbox 5
    Uint16 MIM6:1; // 6 MIM for Mailbox 6
    Uint16 MIM7:1; // 7 MIM for Mailbox 7
    Uint16 MIM8:1; // 8 MIM for Mailbox 8
    Uint16 MIM9:1; // 9 MIM for Mailbox 9
    Uint16 MIM10:1; // 10 MIM for Mailbox 10
    Uint16 MIM11:1; // 11 MIM for Mailbox 11
    Uint16 MIM12:1; // 12 MIM for Mailbox 12
    Uint16 MIM13:1; // 13 MIM for Mailbox 13
    Uint16 MIM14:1; // 14 MIM for Mailbox 14
    Uint16 MIM15:1; // 15 MIM for Mailbox 15
    Uint16 MIM16:1; // 16 MIM for Mailbox 16
    Uint16 MIM17:1; // 17 MIM for Mailbox 17
    Uint16 MIM18:1; // 18 MIM for Mailbox 18
    Uint16 MIM19:1; // 19 MIM for Mailbox 19
    Uint16 MIM20:1; // 20 MIM for Mailbox 20
    Uint16 MIM21:1; // 21 MIM for Mailbox 21
    Uint16 MIM22:1; // 22 MIM for Mailbox 22
    Uint16 MIM23:1; // 23 MIM for Mailbox 23
    Uint16 MIM24:1; // 24 MIM for Mailbox 24
    Uint16 MIM25:1; // 25 MIM for Mailbox 25
    Uint16 MIM26:1; // 26 MIM for Mailbox 26
    Uint16 MIM27:1; // 27 MIM for Mailbox 27
    Uint16 MIM28:1; // 28 MIM for Mailbox 28
    Uint16 MIM29:1; // 29 MIM for Mailbox 29
    Uint16 MIM30:1; // 30 MIM for Mailbox 30
    Uint16 MIM31:1; // 31 MIM for Mailbox 31
    union CANMIM_REG {
    Uint32 all;
    struct CANMIM_BITS bit;
    /* eCAN Mailbox Interrupt Level register (CANMIL) bit definitions */
    struct CANMIL_BITS { // bit description
    Uint16 MIL0:1; // 0 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL1:1; // 1 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL2:1; // 2 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL3:1; // 3 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL4:1; // 4 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL5:1; // 5 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL6:1; // 6 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL7:1; // 7 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL8:1; // 8 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL9:1; // 9 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL10:1; // 10 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL11:1; // 11 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL12:1; // 12 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL13:1; // 13 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL14:1; // 14 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL15:1; // 15 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL16:1; // 16 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL17:1; // 17 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL18:1; // 18 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL19:1; // 19 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL20:1; // 20 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL21:1; // 21 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL22:1; // 22 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL23:1; // 23 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL24:1; // 24 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL25:1; // 25 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL26:1; // 26 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL27:1; // 27 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL28:1; // 28 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL29:1; // 29 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL30:1; // 30 0 -> Int 9.5 1 -> Int 9.6
    Uint16 MIL31:1; // 31 0 -> Int 9.5 1 -> Int 9.6
    union CANMIL_REG {
    Uint32 all;
    struct CANMIL_BITS bit;
    /* eCAN Overwrite Protection Control register (CANOPC) bit definitions */
    struct CANOPC_BITS { // bit description
    Uint16 OPC0:1; // 0 OPC for Mailbox 0
    Uint16 OPC1:1; // 1 OPC for Mailbox 1
    Uint16 OPC2:1; // 2 OPC for Mailbox 2
    Uint16 OPC3:1; // 3 OPC for Mailbox 3
    Uint16 OPC4:1; // 4 OPC for Mailbox 4
    Uint16 OPC5:1; // 5 OPC for Mailbox 5
    Uint16 OPC6:1; // 6 OPC for Mailbox 6
    Uint16 OPC7:1; // 7 OPC for Mailbox 7
    Uint16 OPC8:1; // 8 OPC for Mailbox 8
    Uint16 OPC9:1; // 9 OPC for Mailbox 9
    Uint16 OPC10:1; // 10 OPC for Mailbox 10
    Uint16 OPC11:1; // 11 OPC for Mailbox 11
    Uint16 OPC12:1; // 12 OPC for Mailbox 12
    Uint16 OPC13:1; // 13 OPC for Mailbox 13
    Uint16 OPC14:1; // 14 OPC for Mailbox 14
    Uint16 OPC15:1; // 15 OPC for Mailbox 15
    Uint16 OPC16:1; // 16 OPC for Mailbox 16
    Uint16 OPC17:1; // 17 OPC for Mailbox 17
    Uint16 OPC18:1; // 18 OPC for Mailbox 18
    Uint16 OPC19:1; // 19 OPC for Mailbox 19
    Uint16 OPC20:1; // 20 OPC for Mailbox 20
    Uint16 OPC21:1; // 21 OPC for Mailbox 21
    Uint16 OPC22:1; // 22 OPC for Mailbox 22
    Uint16 OPC23:1; // 23 OPC for Mailbox 23
    Uint16 OPC24:1; // 24 OPC for Mailbox 24
    Uint16 OPC25:1; // 25 OPC for Mailbox 25
    Uint16 OPC26:1; // 26 OPC for Mailbox 26
    Uint16 OPC27:1; // 27 OPC for Mailbox 27
    Uint16 OPC28:1; // 28 OPC for Mailbox 28
    Uint16 OPC29:1; // 29 OPC for Mailbox 29
    Uint16 OPC30:1; // 30 OPC for Mailbox 30
    Uint16 OPC31:1; // 31 OPC for Mailbox 31
    union CANOPC_REG {
    Uint32 all;
    struct CANOPC_BITS bit;
    /* eCAN TX I/O Control Register (CANTIOC) bit definitions */
    struct CANTIOC_BITS { // bits description
    Uint16 TXFUNC:1; // 3 TXFUNC
    Uint16 rsvd2:12; // 15:4 reserved
    Uint16 rsvd3:16; // 31:16 reserved
    union CANTIOC_REG {
    Uint32 all;
    struct CANTIOC_BITS bit;
    /* eCAN RX I/O Control Register (CANRIOC) bit definitions */
    struct CANRIOC_BITS { // bits description
    Uint16 RXFUNC:1; // 3 RXFUNC
    union CANRIOC_REG {
    Uint32 all;
    struct CANRIOC_BITS bit;
    /* eCAN Time-out Control register (CANTOC) bit definitions */
    struct CANTOC_BITS { // bit description
    Uint16 TOC0:1; // 0 TOC for Mailbox 0
    Uint16 TOC1:1; // 1 TOC for Mailbox 1
    Uint16 TOC2:1; // 2 TOC for Mailbox 2
    Uint16 TOC3:1; // 3 TOC for Mailbox 3
    Uint16 TOC4:1; // 4 TOC for Mailbox 4
    Uint16 TOC5:1; // 5 TOC for Mailbox 5
    Uint16 TOC6:1; // 6 TOC for Mailbox 6
    Uint16 TOC7:1; // 7 TOC for Mailbox 7
    Uint16 TOC8:1; // 8 TOC for Mailbox 8
    Uint16 TOC9:1; // 9 TOC for Mailbox 9
    Uint16 TOC10:1; // 10 TOC for Mailbox 10
    Uint16 TOC11:1; // 11 TOC for Mailbox 11
    Uint16 TOC12:1; // 12 TOC for Mailbox 12
    Uint16 TOC13:1; // 13 TOC for Mailbox 13
    Uint16 TOC14:1; // 14 TOC for Mailbox 14
    Uint16 TOC15:1; // 15 TOC for Mailbox 15
    Uint16 TOC16:1; // 16 TOC for Mailbox 16
    Uint16 TOC17:1; // 17 TOC for Mailbox 17
    Uint16 TOC18:1; // 18 TOC for Mailbox 18
    Uint16 TOC19:1; // 19 TOC for Mailbox 19
    Uint16 TOC20:1; // 20 TOC for Mailbox 20
    Uint16 TOC21:1; // 21 TOC for Mailbox 21
    Uint16 TOC22:1; // 22 TOC for Mailbox 22
    Uint16 TOC23:1; // 23 TOC for Mailbox 23
    Uint16 TOC24:1; // 24 TOC for Mailbox 24
    Uint16 TOC25:1; // 25 TOC for Mailbox 25
    Uint16 TOC26:1; // 26 TOC for Mailbox 26
    Uint16 TOC27:1; // 27 TOC for Mailbox 27
    Uint16 TOC28:1; // 28 TOC for Mailbox 28
    Uint16 TOC29:1; // 29 TOC for Mailbox 29
    Uint16 TOC30:1; // 30 TOC for Mailbox 30
    Uint16 TOC31:1; // 31 TOC for Mailbox 31
    union CANTOC_REG {
    Uint32 all;
    struct CANTOC_BITS bit;
    /* eCAN Time-out Status register (CANTOS) bit definitions */
    struct CANTOS_BITS { // bit description
    Uint16 TOS0:1; // 0 TOS for Mailbox 0
    Uint16 TOS1:1; // 1 TOS for Mailbox 1
    Uint16 TOS2:1; // 2 TOS for Mailbox 2
    Uint16 TOS3:1; // 3 TOS for Mailbox 3
    Uint16 TOS4:1; // 4 TOS for Mailbox 4
    Uint16 TOS5:1; // 5 TOS for Mailbox 5
    Uint16 TOS6:1; // 6 TOS for Mailbox 6
    Uint16 TOS7:1; // 7 TOS for Mailbox 7
    Uint16 TOS8:1; // 8 TOS for Mailbox 8
    Uint16 TOS9:1; // 9 TOS for Mailbox 9
    Uint16 TOS10:1; // 10 TOS for Mailbox 10
    Uint16 TOS11:1; // 11 TOS for Mailbox 11
    Uint16 TOS12:1; // 12 TOS for Mailbox 12
    Uint16 TOS13:1; // 13 TOS for Mailbox 13
    Uint16 TOS14:1; // 14 TOS for Mailbox 14
    Uint16 TOS15:1; // 15 TOS for Mailbox 15
    Uint16 TOS16:1; // 16 TOS for Mailbox 16
    Uint16 TOS17:1; // 17 TOS for Mailbox 17
    Uint16 TOS18:1; // 18 TOS for Mailbox 18
    Uint16 TOS19:1; // 19 TOS for Mailbox 19
    Uint16 TOS20:1; // 20 TOS for Mailbox 20
    Uint16 TOS21:1; // 21 TOS for Mailbox 21
    Uint16 TOS22:1; // 22 TOS for Mailbox 22
    Uint16 TOS23:1; // 23 TOS for Mailbox 23
    Uint16 TOS24:1; // 24 TOS for Mailbox 24
    Uint16 TOS25:1; // 25 TOS for Mailbox 25
    Uint16 TOS26:1; // 26 TOS for Mailbox 26
    Uint16 TOS27:1; // 27 TOS for Mailbox 27
    Uint16 TOS28:1; // 28 TOS for Mailbox 28
    Uint16 TOS29:1; // 29 TOS for Mailbox 29
    Uint16 TOS30:1; // 30 TOS for Mailbox 30
    Uint16 TOS31:1; // 31 TOS for Mailbox 31
    union CANTOS_REG {
    Uint32 all;
    struct CANTOS_BITS bit;
    /* eCAN Control & Status register file */
    struct ECAN_REGS {
    union CANME_REG CANME; // Mailbox Enable
    union CANMD_REG CANMD; // Mailbox Direction
    union CANTRS_REG CANTRS; // Transmit Request Set
    union CANTRR_REG CANTRR; // Transmit Request Reset
    union CANTA_REG CANTA; // Transmit Acknowledge
    union CANAA_REG CANAA; // Abort Acknowledge
    union CANRMP_REG CANRMP; // Received Message Pending
    union CANRML_REG CANRML; // Received Message Lost
    union CANRFP_REG CANRFP; // Remote Frame Pending
    union CANGAM_REG CANGAM; // Global Acceptance Mask
    union CANMC_REG CANMC; // Master Control
    union CANBTC_REG CANBTC; // Bit Timing
    union CANES_REG CANES; // Error Status
    union CANTEC_REG CANTEC; // Transmit Error Counter
    union CANREC_REG CANREC; // Receive Error Counter
    union CANGIF0_REG CANGIF0; // Global Interrupt Flag 0
    union CANGIM_REG CANGIM; // Global Interrupt Mask 0
    union CANGIF1_REG CANGIF1; // Global Interrupt Flag 1
    union CANMIM_REG CANMIM; // Mailbox Interrupt Mask
    union CANMIL_REG CANMIL; // Mailbox Interrupt Level
    union CANOPC_REG CANOPC; // Overwrite Protection Control
    union CANTIOC_REG CANTIOC; // TX I/O Control
    union CANRIOC_REG CANRIOC; // RX I/O Control
    Uint32 CANTSC; // Time-stamp counter
    union CANTOC_REG CANTOC; // Time-out Control
    union CANTOS_REG CANTOS; // Time-out Status
    /* eCAN Mailbox Registers */
    /* eCAN Message ID (MSGID) bit definitions */
    struct CANMSGID_BITS { // bits description
    Uint16 EXTMSGID_L:16; // 0:15
    Uint16 EXTMSGID_H:2; // 16:17
    Uint16 STDMSGID:11; // 18:28
    Uint16 AAM:1; // 29
    Uint16 AME:1; // 30
    Uint16 IDE:1; // 31
    union CANMSGID_REG {
    Uint32 all;
    struct CANMSGID_BITS bit;
    /* eCAN Message Control Field (MSGCTRL) bit definitions */
    struct CANMSGCTRL_BITS { // bits description
    Uint16 DLC:4; // 0:3
    Uint16 RTR:1; // 4
    Uint16 TPL:5; // 12:8
    Uint16 rsvd2:3; // 15:13 reserved
    union CANMSGCTRL_REG {
    Uint32 all;
    struct CANMSGCTRL_BITS bit;
    /* eCAN Message Data Register low (MDR_L) word definitions */
    struct CANMDL_WORDS { // bits description
    Uint16 LOW_WORD:16; // 0:15
    Uint16 HI_WORD:16; // 31:16
    /* eCAN Message Data Register low (MDR_L) byte definitions */
    struct CANMDL_BYTES { // bits description
    Uint16 BYTE3:8; // 31:24
    Uint16 BYTE2:8; // 23:16
    Uint16 BYTE1:8; // 15:8
    Uint16 BYTE0:8; // 7:0
    union CANMDL_REG {
    Uint32 all;
    struct CANMDL_WORDS word;
    struct CANMDL_BYTES byte;
    /* eCAN Message Data Register high (MDR_H) word definitions */
    struct CANMDH_WORDS { // bits description
    /* eCAN Message Data Register low (MDR_H) byte definitions */
    struct CANMDH_BYTES { // bits description
    Uint16 BYTE7:8; // 63:56
    Uint16 BYTE6:8; // 55:48
    Uint16 BYTE5:8; // 47:40
    Uint16 BYTE4:8; // 39:32
    union CANMDH_REG {
    Uint32 all;
    struct CANMDH_WORDS word;
    struct CANMDH_BYTES byte;
    struct MBOX {
    union CANMSGID_REG MSGID;
    union CANMSGCTRL_REG MSGCTRL;
    union CANMDL_REG MDL;
    union CANMDH_REG MDH;
    /* eCAN Mailboxes */
    struct ECAN_MBOXES {
    struct MBOX MBOX0;
    struct MBOX MBOX1;
    struct MBOX MBOX2;
    struct MBOX MBOX3;
    struct MBOX MBOX4;
    struct MBOX MBOX5;
    struct MBOX MBOX6;
    struct MBOX MBOX7;
    struct MBOX MBOX8;
    struct MBOX MBOX9;
    struct MBOX MBOX10;
    struct MBOX MBOX11;
    struct MBOX MBOX12;
    struct MBOX MBOX13;
    struct MBOX MBOX14;
    struct MBOX MBOX15;
    struct MBOX MBOX16;
    struct MBOX MBOX17;
    struct MBOX MBOX18;
    struct MBOX MBOX19;
    struct MBOX MBOX20;
    struct MBOX MBOX21;
    struct MBOX MBOX22;
    struct MBOX MBOX23;
    struct MBOX MBOX24;
    struct MBOX MBOX25;
    struct MBOX MBOX26;
    struct MBOX MBOX27;
    struct MBOX MBOX28;
    struct MBOX MBOX29;
    struct MBOX MBOX30;
    struct MBOX MBOX31;
    /* eCAN Local Acceptance Mask (LAM) bit definitions */
    struct CANLAM_BITS { // bits description
    Uint16 LAM_L:16; // 0:15
    Uint16 LAM_H:13; // 16:28
    Uint16 rsvd1:2; // 29:30 reserved
    Uint16 LAMI:1; // 31
    union CANLAM_REG {
    Uint32 all;
    struct CANLAM_BITS bit;
    /* eCAN Local Acceptance Masks */
    /* eCAN LAM File */
    struct LAM_REGS {
    union CANLAM_REG LAM0;
    union CANLAM_REG LAM1;
    union CANLAM_REG LAM2;
    union CANLAM_REG LAM3;
    union CANLAM_REG LAM4;
    union CANLAM_REG LAM5;
    union CANLAM_REG LAM6;
    union CANLAM_REG LAM7;
    union CANLAM_REG LAM8;
    union CANLAM_REG LAM9;
    union CANLAM_REG LAM10;
    union CANLAM_REG LAM11;
    union CANLAM_REG LAM12;
    union CANLAM_REG LAM13;
    union CANLAM_REG LAM14;
    union CANLAM_REG LAM15;
    union CANLAM_REG LAM16;
    union CANLAM_REG LAM17;
    union CANLAM_REG LAM18;
    union CANLAM_REG LAM19;
    union CANLAM_REG LAM20;
    union CANLAM_REG LAM21;
    union CANLAM_REG LAM22;
    union CANLAM_REG LAM23;
    union CANLAM_REG LAM24;
    union CANLAM_REG LAM25;
    union CANLAM_REG LAM26;
    union CANLAM_REG LAM27;
    union CANLAM_REG LAM28;
    union CANLAM_REG LAM29;
    union CANLAM_REG LAM30;
    union CANLAM_REG LAM31;
    /* Mailbox MOTS File */
    struct MOTS_REGS {
    Uint32 MOTS0;
    Uint32 MOTS1;
    Uint32 MOTS2;
    Uint32 MOTS3;
    Uint32 MOTS4;
    Uint32 MOTS5;
    Uint32 MOTS6;
    Uint32 MOTS7;
    Uint32 MOTS8;
    Uint32 MOTS9;
    Uint32 MOTS10;
    Uint32 MOTS11;
    Uint32 MOTS12;
    Uint32 MOTS13;
    Uint32 MOTS14;
    Uint32 MOTS15;
    Uint32 MOTS16;
    Uint32 MOTS17;
    Uint32 MOTS18;
    Uint32 MOTS19;
    Uint32 MOTS20;
    Uint32 MOTS21;
    Uint32 MOTS22;
    Uint32 MOTS23;
    Uint32 MOTS24;
    Uint32 MOTS25;
    Uint32 MOTS26;
    Uint32 MOTS27;
    Uint32 MOTS28;
    Uint32 MOTS29;
    Uint32 MOTS30;
    Uint32 MOTS31;
    /* Mailbox MOTO File */
    struct MOTO_REGS {
    Uint32 MOTO0;
    Uint32 MOTO1;
    Uint32 MOTO2;
    Uint32 MOTO3;
    Uint32 MOTO4;
    Uint32 MOTO5;
    Uint32 MOTO6;
    Uint32 MOTO7;
    Uint32 MOTO8;
    Uint32 MOTO9;
    Uint32 MOTO10;
    Uint32 MOTO11;
    Uint32 MOTO12;
    Uint32 MOTO13;
    Uint32 MOTO14;
    Uint32 MOTO15;
    Uint32 MOTO16;
    Uint32 MOTO17;
    Uint32 MOTO18;
    Uint32 MOTO19;
    Uint32 MOTO20;
    Uint32 MOTO21;
    Uint32 MOTO22;
    Uint32 MOTO23;
    Uint32 MOTO24;
    Uint32 MOTO25;
    Uint32 MOTO26;
    Uint32 MOTO27;
    Uint32 MOTO28;
    Uint32 MOTO29;
    Uint32 MOTO30;
    Uint32 MOTO31;
    // eCAN External References & Function Declarations:
    extern volatile struct ECAN_REGS ECanaRegs;
    extern volatile struct ECAN_MBOXES ECanaMboxes;
    extern volatile struct LAM_REGS ECanaLAMRegs;
    extern volatile struct MOTO_REGS ECanaMOTORegs;
    extern volatile struct MOTS_REGS ECanaMOTSRegs;
    extern volatile struct ECAN_REGS ECanbRegs;
    extern volatile struct ECAN_MBOXES ECanbMboxes;
    extern volatile struct LAM_REGS ECanbLAMRegs;
    extern volatile struct MOTO_REGS ECanbMOTORegs;
    extern volatile struct MOTS_REGS ECanbMOTSRegs;
    // End of file.
    // Checkin $Date: April 7, 2005 13:47:28 $
    // FILE: DSP280x_ECap.h
    // TITLE: DSP280x Enhanced Capture Module Register Bit Definitions.
    // Capture control register 1 bit definitions */
    struct ECCTL1_BITS { // bits description
    Uint16 CAP1POL:1; // 0 Capture Event 1 Polarity select
    Uint16 CTRRST1:1; // 1 Counter Reset on Capture Event 1
    Uint16 CAP2POL:1; // 2 Capture Event 2 Polarity select
    Uint16 CTRRST2:1; // 3 Counter Reset on Capture Event 2
    Uint16 CAP3POL:1; // 4 Capture Event 3 Polarity select
    Uint16 CTRRST3:1; // 5 Counter Reset on Capture Event 3
    Uint16 CAP4POL:1; // 6 Capture Event 4 Polarity select
    Uint16 CTRRST4:1; // 7 Counter Reset on Capture Event 4
    Uint16 CAPLDEN:1; // 8 Enable Loading CAP1-4 regs on a Cap Event
    Uint16 PRESCALE:5; // 13:9 Event Filter prescale select
    Uint16 FREE_SOFT:2; // 15:14 Emulation mode
    union ECCTL1_REG {
    Uint16 all;
    struct ECCTL1_BITS bit;
    // In V1.1 the STOPVALUE bit field was changed to
    // STOP_WRAP. This correlated to a silicon change from
    // F280x Rev 0 to Rev A.
    // Capture control register 2 bit definitions */
    struct ECCTL2_BITS { // bits description
    Uint16 CONT_ONESHT:1; // 0 Continuous or one-shot
    Uint16 STOP_WRAP:2; // 2:1 Stop value for one-shot, Wrap for continuous
    Uint16 REARM:1; // 3 One-shot re-arm
    Uint16 TSCTRSTOP:1; // 4 TSCNT counter stop
    Uint16 SYNCI_EN:1; // 5 Counter sync-in select
    Uint16 SYNCO_SEL:2; // 7:6 Sync-out mode
    Uint16 SWSYNC:1; // 8 SW forced counter sync
    Uint16 CAP_APWM:1; // 9 CAP/APWM operating mode select
    Uint16 APWMPOL:1; // 10 APWM output polarity select
    Uint16 rsvd1:5; // 15:11
    union ECCTL2_REG {
    Uint16 all;
    struct ECCTL2_BITS bit;
    // ECAP interrupt enable register bit definitions */
    struct ECEINT_BITS { // bits description
    Uint16 rsvd1:1; // 0 reserved
    Uint16 CEVT1:1; // 1 Capture Event 1 Interrupt Enable
    Uint16 CEVT2:1; // 2 Capture Event 2 Interrupt Enable
    Uint16 CEVT3:1; // 3 Capture Event 3 Interrupt Enable
    Uint16 CEVT4:1; // 4 Capture Event 4 Interrupt Enable
    Uint16 CTROVF:1; // 5 Counter Overflow Interrupt Enable
    Uint16 CTR_EQ_PRD:1; // 6 Period Equal Interrupt Enable
    Uint16 CTR_EQ_CMP:1; // 7 Compare Equal Interrupt Enable
    Uint16 rsvd2:8; // 15:8 reserved
    union ECEINT_REG {
    Uint16 all;
    struct ECEINT_BITS bit;
    // ECAP interrupt flag register bit definitions */
    struct ECFLG_BITS { // bits description
    Uint16 INT:1; // 0 Global Flag
    Uint16 CEVT1:1; // 1 Capture Event 1 Interrupt Flag
    Uint16 CEVT2:1; // 2 Capture Event 2 Interrupt Flag
    Uint16 CEVT3:1; // 3 Capture Event 3 Interrupt Flag
    Uint16 CEVT4:1; // 4 Capture Event 4 Interrupt Flag
    Uint16 CTROVF:1; // 5 Counter Overflow Interrupt Flag
    Uint16 CTR_EQ_PRD:1; // 6 Period Equal Interrupt Flag
    Uint16 CTR_EQ_CMP:1; // 7 Compare Equal Interrupt Flag
    union ECFLG_REG {
    Uint16 all;
    struct ECFLG_BITS bit;
    struct ECAP_REGS {
    Uint32 TSCTR; // Time stamp counter
    Uint32 CTRPHS; // Counter phase
    Uint32 CAP1; // Capture 1
    Uint32 CAP2; // Capture 2
    Uint32 CAP3; // Capture 3
    Uint32 CAP4; // Capture 4
    Uint16 rsvd1[8]; // reserved
    union ECCTL1_REG ECCTL1; // Capture Control Reg 1
    union ECCTL2_REG ECCTL2; // Capture Control Reg 2
    union ECEINT_REG ECEINT; // ECAP interrupt enable
    union ECFLG_REG ECFLG; // ECAP interrupt flags
    union ECFLG_REG ECCLR; // ECAP interrupt clear
    union ECEINT_REG ECFRC; // ECAP interrupt force
    Uint16 rsvd2[6]; // reserved
    // GPI/O External References & Function Declarations:
    extern volatile struct ECAP_REGS ECap1Regs;
    extern volatile struct ECAP_REGS ECap2Regs;
    extern volatile struct ECAP_REGS ECap3Regs;
    extern volatile struct ECAP_REGS ECap4Regs;
    // End of file.
    // TI File $Revision: /main/7 $
    // Checkin $Date: September 9, 2005 13:59:40 $
    // FILE: DSP280x_EPwm.h
    // TITLE: DSP280x Enhanced PWM Module Register Bit Definitions.
    // Time base control register bit definitions */
    struct TBCTL_BITS { // bits description
    Uint16 CTRMODE:2; // 1:0 Counter Mode
    Uint16 PHSEN:1; // 2 Phase load enable
    Uint16 PRDLD:1; // 3 Active period load
    Uint16 SYNCOSEL:2; // 5:4 Sync output select
    Uint16 SWFSYNC:1; // 6 Software force sync pulse
    Uint16 HSPCLKDIV:3; // 9:7 High speed time pre-scale
    Uint16 CLKDIV:3; // 12:10 Timebase clock pre-scale
    Uint16 PHSDIR:1; // 13 Phase Direction
    union TBCTL_REG {
    Uint16 all;
    struct TBCTL_BITS bit;
    // Time base status register bit definitions */
    struct TBSTS_BITS { // bits description
    Uint16 CTRDIR:1; // 0 Counter direction status
    Uint16 SYNCI:1; // 1 External input sync status
    Uint16 CTRMAX:1; // 2 Counter max latched status
    Uint16 rsvd1:13; // 15:3 reserved
    union TBSTS_REG {
    Uint16 all;
    struct TBSTS_BITS bit;
    // Compare control register bit definitions */
    struct CMPCTL_BITS { // bits description
    Uint16 LOADAMODE:2; // 0:1 Active compare A
    Uint16 LOADBMODE:2; // 3:2 Active compare B
    Uint16 SHDWAMODE:1; // 4 Compare A block operating mode
    Uint16 rsvd1:1; // 5 reserved
    Uint16 SHDWBMODE:1; // 6 Compare B block operating mode
    Uint16 rsvd2:1; // 7 reserved
    Uint16 SHDWAFULL:1; // 8 Compare A Shadow registers full Status
    Uint16 SHDWBFULL:1; // 9 Compare B Shadow registers full Status
    Uint16 rsvd3:6; // 15:10 reserved
    union CMPCTL_REG {
    Uint16 all;
    struct CMPCTL_BITS bit;
    // Action qualifier register bit definitions */
    struct AQCTL_BITS { // bits description
    Uint16 ZRO:2; // 1:0 Action Counter = Zero
    Uint16 PRD:2; // 3:2 Action Counter = Period
    Uint16 CAU:2; // 5:4 Action Counter = Compare A up
    Uint16 CAD:2; // 7:6 Action Counter = Compare A down
    Uint16 CBU:2; // 9:8 Action Counter = Compare B up
    Uint16 CBD:2; // 11:10 Action Counter = Compare B down
    Uint16 rsvd:4; // 15:12 reserved
    union AQCTL_REG {
    Uint16 all;
    struct AQCTL_BITS bit;
    // Action qualifier SW force register bit definitions */
    struct AQSFRC_BITS { // bits description
    Uint16 ACTSFA:2; // 1:0 Action when One-time SW Force A invoked
    Uint16 OTSFA:1; // 2 One-time SW Force A output
    Uint16 ACTSFB:2; // 4:3 Action when One-time SW Force B invoked
    Uint16 OTSFB:1; // 5 One-time SW Force A output
    Uint16 RLDCSF:2; // 7:6 Reload from Shadow options
    union AQSFRC_REG {
    Uint16 all;
    struct AQSFRC_BITS bit;
    // Action qualifier continuous SW force register bit definitions */
    struct AQCSFRC_BITS { // bits description
    Uint16 CSFA:2; // 1:0 Continuous Software Force on output A
    Uint16 CSFB:2; // 3:2 Continuous Software Force on output B
    Uint16 rsvd1:12; // 15:4 reserved
    union AQCSFRC_REG {
    Uint16 all;
    struct AQCSFRC_BITS bit;
    // As of version 1.1
    // Changed the MODE bit-field to OUT_MODE
    // Added the bit-field IN_MODE
    // This corresponds to changes in silicon as of F280x devices
    // Rev A silicon.
    // Dead-band generator control register bit definitions
    struct DBCTL_BITS { // bits description
    Uint16 OUT_MODE:2; // 1:0 Dead Band Output Mode Control
    Uint16 POLSEL:2; // 3:2 Polarity Select Control
    Uint16 IN_MODE:2; // 5:4 Dead Band Input Select Mode Control
    Uint16 rsvd1:10; // 15:4 reserved
    union DBCTL_REG {
    Uint16 all;
    struct DBCTL_BITS bit;
    // Trip zone select register bit definitions
    struct TZSEL_BITS { // bits description
    Uint16 CBC1:1; // 0 TZ1 CBC select
    Uint16 CBC2:1; // 1 TZ2 CBC select
    Uint16 CBC3:1; // 2 TZ3 CBC select
    Uint16 CBC4:1; // 3 TZ4 CBC select
    Uint16 CBC5:1; // 4 TZ5 CBC select
    Uint16 CBC6:1; // 5 TZ6 CBC select
    Uint16 rsvd1:2; // 7:6 reserved
    Uint16 OSHT1:1; // 8 One-shot TZ1 select
    Uint16 OSHT2:1; // 9 One-shot TZ2 select
    Uint16 OSHT3:1; // 10 One-shot TZ3 select
    Uint16 OSHT4:1; // 11 One-shot TZ4 select
    Uint16 OSHT5:1; // 12 One-shot TZ5 select
    Uint16 OSHT6:1; // 13 One-shot TZ6 select
    Uint16 rsvd2:2; // 15:14 reserved
    union TZSEL_REG {
    Uint16 all;
    struct TZSEL_BITS bit;
    // Trip zone control register bit definitions */
    struct TZCTL_BITS { // bits description
    Uint16 TZA:2; // 1:0 TZ1 to TZ6 Trip Action On EPWMxA
    Uint16 TZB:2; // 3:2 TZ1 to TZ6 Trip Action On EPWMxB
    Uint16 rsvd:12; // 15:4 reserved
    union TZCTL_REG {
    Uint16 all;
    struct TZCTL_BITS bit;
    struct TZEINT_BITS { // bits description
    Uint16 CBC:1; // 1 Trip Zones Cycle By Cycle Int Enable
    Uint16 OST:1; // 2 Trip Zones One Shot Int Enable
    Uint16 rsvd2:13; // 15:3 reserved
    union TZEINT_REG {
    Uint16 all;
    struct TZEINT_BITS bit;
    // Trip zone flag register bit definitions */
    struct TZFLG_BITS { // bits description
    Uint16 INT:1; // 0 Global status
    union TZFLG_REG {
    Uint16 all;
    struct TZFLG_BITS bit;
    // Trip zone flag clear register bit definitions */
    struct TZCLR_BITS { // bits description
    union TZCLR_REG {
    Uint16 all;
    struct TZCLR_BITS bit;
    // Trip zone flag force register bit definitions */
    struct TZFRC_BITS { // bits description
    union TZFRC_REG {
    Uint16 all;
    struct TZFRC_BITS bit;
    // Event trigger select register bit definitions */
    struct ETSEL_BITS { // bits description
    Uint16 INTSEL:3; // 2:0 EPWMxINTn Select
    Uint16 INTEN:1; // 3 EPWMxINTn Enable
    Uint16 rsvd1:4; // 7:4 reserved
    Uint16 SOCASEL:3; // 10:8 Start of conversion A Select
    Uint16 SOCAEN:1; // 11 Start of conversion A Enable
    Uint16 SOCBSEL:3; // 14:12 Start of conversion B Select
    Uint16 SOCBEN:1; // 15 Start of conversion B Enable
    union ETSEL_REG {
    Uint16 all;
    struct ETSEL_BITS bit;
    // Event trigger pre-scale register bit definitions */
    struct ETPS_BITS { // bits description
    Uint16 INTPRD:2; // 1:0 EPWMxINTn Period Select
    Uint16 INTCNT:2; // 3:2 EPWMxINTn Counter Register
    Uint16 SOCAPRD:2; // 9:8 EPWMxSOCA Period Select
    Uint16 SOCACNT:2; // 11:10 EPWMxSOCA Counter Register
    Uint16 SOCBPRD:2; // 13:12 EPWMxSOCB Period Select
    Uint16 SOCBCNT:2; // 15:14 EPWMxSOCB Counter Register
    union ETPS_REG {
    Uint16 all;
    struct ETPS_BITS bit;
    // Event trigger Flag register bit definitions */
    struct ETFLG_BITS { // bits description
    Uint16 INT:1; // 0 EPWMxINTn Flag
    Uint16 SOCA:1; // 2 EPWMxSOCA Flag
    Uint16 SOCB:1; // 3 EPWMxSOCB Flag
    union ETFLG_REG {
    Uint16 all;
    struct ETFLG_BITS bit;
    // Event trigger Clear register bit definitions */
    struct ETCLR_BITS { // bits description
    Uint16 INT:1; // 0 EPWMxINTn Clear
    Uint16 SOCA:1; // 2 EPWMxSOCA Clear
    Uint16 SOCB:1; // 3 EPWMxSOCB Clear
    union ETCLR_REG {
    Uint16 all;
    struct ETCLR_BITS bit;
    // Event trigger Force register bit definitions */
    struct ETFRC_BITS { // bits description
    Uint16 INT:1; // 0 EPWMxINTn Force
    Uint16 SOCA:1; // 2 EPWMxSOCA Force
    Uint16 SOCB:1; // 3 EPWMxSOCB Force
    union ETFRC_REG {
    Uint16 all;
    struct ETFRC_BITS bit;
    // PWM chopper control register bit definitions */
    struct PCCTL_BITS { // bits description
    Uint16 CHPEN:1; // 0 PWM chopping enable
    Uint16 OSHTWTH:4; // 4:1 One-shot pulse width
    Uint16 CHPFREQ:3; // 7:5 Chopping clock frequency
    Uint16 CHPDUTY:3; // 10:8 Chopping clock Duty cycle
    Uint16 rsvd1:5; // 15:11 reserved
    union PCCTL_REG {
    Uint16 all;
    struct PCCTL_BITS bit;
    struct HRCNFG_BITS { // bits description
    Uint16 EDGMODE:2; // 1:0 Edge Mode select Bits
    Uint16 CTLMODE:1; // 2 Control mode Select Bit
    Uint16 HRLOAD:1; // 3 Shadow mode Select Bit
    union HRCNFG_REG {
    Uint16 all;
    struct HRCNFG_BITS bit;
    struct TBPHS_HRPWM_REG { // bits description
    Uint16 TBPHSHR; // 15:0 Extension register for HRPWM Phase (8 bits)
    Uint16 TBPHS; // 31:16 Phase offset register
    union TBPHS_HRPWM_GROUP {
    Uint32 all;
    struct TBPHS_HRPWM_REG half;
    struct CMPA_HRPWM_REG { // bits description
    Uint16 CMPAHR; // 15:0 Extension register for HRPWM compare (8 bits)
    Uint16 CMPA; // 31:16 Compare A reg
    union CMPA_HRPWM_GROUP {
    Uint32 all;
    struct CMPA_HRPWM_REG half;
    struct EPWM_REGS {
    union TBCTL_REG TBCTL; //
    union TBSTS_REG TBSTS; //
    union TBPHS_HRPWM_GROUP TBPHS; // Union of TBPHS:TBPHSHR
    Uint16 TBCTR; // Counter
    Uint16 TBPRD; // Period register set
    Uint16 rsvd1; //
    union CMPCTL_REG CMPCTL; // Compare control
    union CMPA_HRPWM_GROUP CMPA; // Union of CMPA:CMPAHR
    Uint16 CMPB; // Compare B reg
    union AQCTL_REG AQCTLA; // Action qual output A
    union AQCTL_REG AQCTLB; // Action qual output B
    union AQSFRC_REG AQSFRC; // Action qual SW force
    union AQCSFRC_REG AQCSFRC; // Action qualifier continuous SW force
    union DBCTL_REG DBCTL; // Dead-band control
    Uint16 DBRED; // Dead-band rising edge delay
    Uint16 DBFED; // Dead-band falling edge delay
    union TZSEL_REG TZSEL; // Trip zone select
    Uint16 rsvd2;
    union TZCTL_REG TZCTL; // Trip zone control
    union TZEINT_REG TZEINT; // Trip zone interrupt enable
    union TZFLG_REG TZFLG; // Trip zone interrupt flags
    union TZCLR_REG TZCLR; // Trip zone clear
    union TZFRC_REG TZFRC; // Trip zone force interrupt
    union ETSEL_REG ETSEL; // Event trigger selection
    union ETPS_REG ETPS; // Event trigger pre-scaler
    union ETFLG_REG ETFLG; // Event trigger flags
    union ETCLR_REG ETCLR; // Event trigger clear
    union ETFRC_REG ETFRC; // Event trigger force
    union PCCTL_REG PCCTL; // PWM chopper control
    Uint16 rsvd3; //
    union HRCNFG_REG HRCNFG; // HRPWM Config Reg
    // External References & Function Declarations:
    extern volatile struct EPWM_REGS EPwm1Regs;
    extern volatile struct EPWM_REGS EPwm2Regs;
    extern volatile struct EPWM_REGS EPwm3Regs;
    extern volatile struct EPWM_REGS EPwm4Regs;
    extern volatile struct EPWM_REGS EPwm5Regs;
    extern volatile struct EPWM_REGS EPwm6Regs;
    // End of file.
    // Checkin $Date: April 8, 2005 12:39:38 $
    // FILE: DSP280x_EQep.h
    // TITLE: DSP280x Enhanced Quadrature Encoder Pulse Module
    // Register Bit Definitions.
    // Capture decoder control register bit definitions */
    struct QDECCTL_BITS { // bits description
    Uint16 rsvd1:5; // 4:0 reserved
    Uint16 QSP:1; // 5 QEPS input polarity
    Uint16 QIP:1; // 6 QEPI input polarity
    Uint16 QBP:1; // 7 QEPB input polarity
    Uint16 QAP:1; // 8 QEPA input polarity
    Uint16 IGATE:1; // 9 Index pulse gating option
    Uint16 SWAP:1; // 10 CLK/DIR signal source for Position Counter
    Uint16 XCR:1; // 11 External clock rate
    Uint16 SPSEL:1; // 12 Sync output pin select
    Uint16 SOEN:1; // 13 Enable position compare sync
    Uint16 QSRC:2; // 15:14 Position counter source
    union QDECCTL_REG {
    Uint16 all;
    struct QDECCTL_BITS bit;
    // QEP control register bit definitions */
    struct QEPCTL_BITS { // bits description
    Uint16 WDE:1; // 0 QEP watchdog enable
    Uint16 UTE:1; // 1 QEP unit timer enable
    Uint16 QCLM:1; // 2 QEP capture latch mode
    Uint16 QPEN:1; // 3 Quadrature position counter enable
    Uint16 IEL:2; // 5:4 Index event latch
    Uint16 SEL:1; // 6 Strobe event latch
    Uint16 SWI:1; // 7 Software init position counter
    Uint16 IEI:2; // 9:8 Index event init of position count
    Uint16 SEI:2; // 11:10 Strobe event init
    Uint16 PCRM:2; // 13:12 Position counter reset
    union QEPCTL_REG {
    Uint16 all;
    struct QEPCTL_BITS bit;
    // Quadrature capture control register bit definitions */
    struct QCAPCTL_BITS { // bits description
    Uint16 UPPS:4; // 3:0 Unit position pre-scale
    Uint16 CCPS:3; // 6:4 QEP capture timer pre-scale
    Uint16 rsvd1:8; // 14:7 reserved
    Uint16 CEN:1; // 15 Enable QEP capture
    union QCAPCTL_REG {
    Uint16 all;
    struct QCAPCTL_BITS bit;
    // Position compare control register bit definitions */
    struct QPOSCTL_BITS { // bits description
    Uint16 PCSPW:12; // 11:0 Position compare sync pulse width
    Uint16 PCE:1; // 12 Position compare enable/disable
    Uint16 PCPOL:1; // 13 Polarity of sync output
    Uint16 PCLOAD:1; // 14 Position compare of shadow load
    Uint16 PCSHDW:1; // 15 Position compare shadow enable
    union QPOSCTL_REG {
    Uint16 all;
    struct QPOSCTL_BITS bit;
    // QEP interrupt control register bit definitions */
    struct QEINT_BITS { // bits description
    Uint16 PCE:1; // 1 Position counter error
    Uint16 QPE:1; // 2 Quadrature phase error
    Uint16 QDC:1; // 3 Quadrature dir change
    Uint16 WTO:1; // 4 Watchdog timeout
    Uint16 PCU:1; // 5 Position counter underflow
    Uint16 PCO:1; // 6 Position counter overflow
    Uint16 PCR:1; // 7 Position compare ready
    Uint16 PCM:1; // 8 Position compare match
    Uint16 SEL:1; // 9 Strobe event latch
    Uint16 IEL:1; // 10 Event latch
    Uint16 UTO:1; // 11 Unit timeout
    union QEINT_REG {
    Uint16 all;
    struct QEINT_BITS bit;
    // QEP interrupt status register bit definitions */
    struct QFLG_BITS { // bits description
    Uint16 INT:1; // 0 Global interrupt
    Uint16 PHE:1; // 2 Quadrature phase error
    union QFLG_REG {
    Uint16 all;
    struct QFLG_BITS bit;
    // QEP interrupt force register bit definitions */
    struct QFRC_BITS { // bits description
    Uint16 reserved:1; // 0 Reserved
    union QFRC_REG {
    Uint16 all;
    struct QFRC_BITS bit;
    // V1.1 Added UPEVNT (bit 7) This reflects changes
    // made as of F280x Rev A devices
    // QEP status register bit definitions */
    struct QEPSTS_BITS { // bits description
    Uint16 PCEF:1; // 0 Position counter error
    Uint16 FIMF:1; // 1 First index marker
    Uint16 CDEF:1; // 2 Capture direction error
    Uint16 COEF:1; // 3 Capture overflow error
    Uint16 QDLF:1; // 4 QEP direction latch
    Uint16 QDF:1; // 5 Quadrature direction
    Uint16 FIDF:1; // 6 Direction on first index marker
    Uint16 UPEVNT:1; // 7 Unit position event flag
    union QEPSTS_REG {
    Uint16 all;
    struct QEPSTS_BITS bit;
    struct EQEP_REGS {
    Uint32 QPOSCNT; // Position counter
    Uint32 QPOSINIT; // Position counter init
    Uint32 QPOSMAX; // Maximum position count
    Uint32 QPOSCMP; // Position compare
    Uint32 QPOSILAT; // Index position latch
    Uint32 QPOSSLAT; // Strobe position latch
    Uint32 QPOSLAT; // Position latch
    Uint32 QUTMR; // Unit timer
    Uint32 QUPRD; // Unit period
    Uint16 QWDTMR; // QEP watchdog timer
    Uint16 QWDPRD; // QEP watchdog period
    union QDECCTL_REG QDECCTL; // Quadrature decoder control
    union QEPCTL_REG QEPCTL; // QEP control
    union QCAPCTL_REG QCAPCTL; // Quadrature capture control
    union QPOSCTL_REG QPOSCTL; // Position compare control
    union QEINT_REG QEINT; // QEP interrupt control
    union QFLG_REG QFLG; // QEP interrupt flag
    union QFLG_REG QCLR; // QEP interrupt clear
    union QFRC_REG QFRC; // QEP interrupt force
    union QEPSTS_REG QEPSTS; // QEP status
    Uint16 QCTMR; // QEP capture timer
    Uint16 QCPRD; // QEP capture period
    Uint16 QCTMRLAT; // QEP capture latch
    Uint16 QCPRDLAT; // QEP capture period latch
    Uint16 rsvd1[30]; // reserved
    extern volatile struct EQEP_REGS EQep1Regs;
    extern volatile struct EQEP_REGS EQep2Regs;
    // End of file.
    // Checkin $Date: April 24, 2006 12:51:13 $
    // FILE: DSP280x_Gpio.h
    // TITLE: DSP280x General Purpose I/O Definitions.
    // $TI Release: DSP280x, DSP2801x Header Files V1.41 $
    // $Release Date: August 7th, 2006 $
    // GPIO A control register bit definitions */
    struct GPACTRL_BITS { // bits description
    Uint16 QUALPRD0:8; // 7:0 Qual period
    Uint16 QUALPRD1:8; // 15:8 Qual period
    Uint16 QUALPRD2:8; // 23:16 Qual period
    Uint16 QUALPRD3:8; // 31:24 Qual period
    union GPACTRL_REG {
    Uint32 all;
    struct GPACTRL_BITS bit;
    // GPIO B control register bit definitions */
    struct GPBCTRL_BITS { // bits description
    union GPBCTRL_REG {
    Uint32 all;
    struct GPBCTRL_BITS bit;
    // GPIO A Qual/MUX select register bit definitions */
    struct GPA1_BITS { // bits description
    Uint16 GPIO0:2; // 1:0 GPIO0
    Uint16 GPIO1:2; // 3:2 GPIO1
    Uint16 GPIO2:2; // 5:4 GPIO2
    Uint16 GPIO3:2; // 7:6 GPIO3
    Uint16 GPIO4:2; // 9:8 GPIO4
    Uint16 GPIO5:2; // 11:10 GPIO5
    Uint16 GPIO6:2; // 13:12 GPIO6
    Uint16 GPIO7:2; // 15:14 GPIO7
    Uint16 GPIO8:2; // 17:16 GPIO8
    Uint16 GPIO9:2; // 19:18 GPIO9
    Uint16 GPIO10:2; // 21:20 GPIO10
    Uint16 GPIO11:2; // 23:22 GPIO11
    Uint16 GPIO12:2; // 25:24 GPIO12
    Uint16 GPIO13:2; // 27:26 GPIO13
    Uint16 GPIO14:2; // 29:28 GPIO14
    Uint16 GPIO15:2; // 31:30 GPIO15
    struct GPA2_BITS { // bits description
    Uint16 GPIO16:2; // 1:0 GPIO16
    Uint16 GPIO17:2; // 3:2 GPIO17
    Uint16 GPIO18:2; // 5:4 GPIO18
    Uint16 GPIO19:2; // 7:6 GPIO19
    Uint16 GPIO20:2; // 9:8 GPIO20
    Uint16 GPIO21:2; // 11:10 GPIO21
    Uint16 GPIO22:2; // 13:12 GPIO22
    Uint16 GPIO23:2; // 15:14 GPIO23
    Uint16 GPIO24:2; // 17:16 GPIO24
    Uint16 GPIO25:2; // 19:18 GPIO25
    Uint16 GPIO26:2; // 21:20 GPIO26
    Uint16 GPIO27:2; // 23:22 GPIO27
    Uint16 GPIO28:2; // 25:24 GPIO28
    Uint16 GPIO29:2; // 27:26 GPIO29
    Uint16 GPIO30:2; // 29:28 GPIO30
    Uint16 GPIO31:2; // 31:30 GPIO31
    struct GPB1_BITS { // bits description
    Uint16 GPIO32:2; // 1:0 GPIO32
    Uint16 GPIO33:2; // 3:2 GPIO33
    Uint16 GPIO34:2; // 5:4 GPIO34
    struct GPB2_BITS { // bits description
    Uint16 rsvd1:16; // 15:0 reserved
    union GPA1_REG {
    Uint32 all;
    struct GPA1_BITS bit;
    union GPA2_REG {
    Uint32 all;
    struct GPA2_BITS bit;
    union GPB1_REG {
    Uint32 all;
    struct GPB1_BITS bit;
    union GPB2_REG {
    Uint32 all;
    struct GPB2_BITS bit;
    // GPIO A DIR/TOGGLE/SET/CLEAR register bit definitions */
    struct GPADAT_BITS { // bits description
    Uint16 GPIO0:1; // 0 GPIO0
    Uint16 GPIO1:1; // 1 GPIO1
    Uint16 GPIO2:1; // 2 GPIO2
    Uint16 GPIO3:1; // 3 GPIO3
    Uint16 GPIO4:1; // 4 GPIO4
    Uint16 GPIO5:1; // 5 GPIO5
    Uint16 GPIO6:1; // 6 GPIO6
    Uint16 GPIO7:1; // 7 GPIO7
    Uint16 GPIO8:1; // 8 GPIO8
    Uint16 GPIO9:1; // 9 GPIO9
    Uint16 GPIO10:1; // 10 GPIO10
    Uint16 GPIO11:1; // 11 GPIO11
    Uint16 GPIO12:1; // 12 GPIO12
    Uint16 GPIO13:1; // 13 GPIO13
    Uint16 GPIO14:1; // 14 GPIO14
    Uint16 GPIO15:1; // 15 GPIO15
    Uint16 GPIO16:1; // 16 GPIO16
    Uint16 GPIO17:1; // 17 GPIO17
    Uint16 GPIO18:1; // 18 GPIO18
    Uint16 GPIO19:1; // 19 GPIO19
    Uint16 GPIO20:1; // 20 GPIO20
    Uint16 GPIO21:1; // 21 GPIO21
    Uint16 GPIO22:1; // 22 GPIO22
    Uint16 GPIO23:1; // 23 GPIO23
    Uint16 GPIO24:1; // 24 GPIO24
    Uint16 GPIO25:1; // 25 GPIO25
    Uint16 GPIO26:1; // 26 GPIO26
    Uint16 GPIO27:1; // 27 GPIO27
    Uint16 GPIO28:1; // 28 GPIO28
    Uint16 GPIO29:1; // 29 GPIO29
    Uint16 GPIO30:1; // 30 GPIO30
    Uint16 GPIO31:1; // 31 GPIO31
    struct GPBDAT_BITS { // bits description
    Uint16 GPIO32:1; // 0 GPIO32
    Uint16 GPIO33:1; // 1 GPIO33
    Uint16 GPIO34:1; // 2 GPIO34
    union GPADAT_REG {
    Uint32 all;
    struct GPADAT_BITS bit;
    union GPBDAT_REG {
    Uint32 all;
    struct GPBDAT_BITS bit;
    // GPIO35 is an internal pin that is not pinned out
    // for HALT low power mode, enable the internal pull-up
    // to avoid extran current draw from this pin.
    struct GPBPUD_BITS { // bits description
    Uint16 GPIO35:1; // 3 GPIO35
    union GPBPUD_REG {
    Uint32 all;
    struct GPBPUD_BITS bit;
    // GPIO XINT1/XINT2/XNMI select register bit definitions */
    struct GPIOXINT_BITS { // bits description
    Uint16 GPIOSEL:5; // 4:0 Select GPIO interrupt input source
    Uint16 rsvd1:11; // 15:5 reserved
    union GPIOXINT_REG {
    Uint16 all;
    struct GPIOXINT_BITS bit;
    struct GPIO_CTRL_REGS {
    union GPACTRL_REG GPACTRL; // GPIO A Control Register (GPIO0 to 31)
    union GPA1_REG GPAQSEL1; // GPIO A Qualifier Select 1 Register (GPIO0 to 15)
    union GPA2_REG GPAQSEL2; // GPIO A Qualifier Select 2 Register (GPIO16 to 31)
    union GPA1_REG GPAMUX1; // GPIO A Mux 1 Register (GPIO0 to 15)
    union GPA2_REG GPAMUX2; // GPIO A Mux 2 Register (GPIO16 to 31)
    union GPADAT_REG GPADIR; // GPIO A Direction Register (GPIO0 to 31)
    union GPADAT_REG GPAPUD; // GPIO A Pull Up Disable Register (GPIO0 to 31)
    Uint32 rsvd1;
    union GPBCTRL_REG GPBCTRL; // GPIO B Control Register (GPIO32 to 63)
    union GPB1_REG GPBQSEL1; // GPIO B Qualifier Select 1 Register (GPIO32 to 47)
    union GPB2_REG GPBQSEL2; // GPIO B Qualifier Select 2 Register (GPIO48 to 63)
    union GPB1_REG GPBMUX1; // GPIO B Mux 1 Register (GPIO32 to 47)
    union GPB2_REG GPBMUX2; // GPIO B Mux 2 Register (GPIO48 to 63)
    union GPBDAT_REG GPBDIR; // GPIO B Direction Register (GPIO32 to 63)
    union GPBPUD_REG GPBPUD; // GPIO B Pull Up Disable Register (GPIO32 to 63)
    Uint16 rsvd2[33];
    struct GPIO_DATA_REGS {
    union GPADAT_REG GPADAT; // GPIO Data Register (GPIO0 to 31)
    union GPADAT_REG GPASET; // GPIO Data Set Register (GPIO0 to 31)
    union GPADAT_REG GPACLEAR; // GPIO Data Clear Register (GPIO0 to 31)
    union GPADAT_REG GPATOGGLE; // GPIO Data Toggle Register (GPIO0 to 31)
    union GPBPUD_REG GPBDAT; // GPIO Data Register (GPIO32 to 63)
    union GPBDAT_REG GPBSET; // GPIO Data Set Register (GPIO32 to 63)
    union GPBDAT_REG GPBCLEAR; // GPIO Data Clear Register (GPIO32 to 63)
    union GPBDAT_REG GPBTOGGLE; // GPIO Data Toggle Register (GPIO32 to 63)
    Uint16 rsvd1[16];
    struct GPIO_INT_REGS {
    union GPIOXINT_REG GPIOXINT1SEL; // XINT1 GPIO Input Selection
    union GPIOXINT_REG GPIOXINT2SEL; // XINT2 GPIO Input Selection
    union GPIOXINT_REG GPIOXNMISEL; // XNMI_XINT13 GPIO Input Selection
    Uint16 rsvd2[5];
    union GPADAT_REG GPIOLPMSEL; // Low power modes GP I/O input select
    extern volatile struct GPIO_CTRL_REGS GpioCtrlRegs;
    extern volatile struct GPIO_DATA_REGS GpioDataRegs;
    extern volatile struct GPIO_INT_REGS GpioIntRegs;
    // End of file.
    // TI File $Revision: /main/2 $
    // Checkin $Date: December 2, 2004 13:43:02 $
    // FILE: DSP280x_I2c.h
    // I2C interrupt vector register bit definitions */
    struct I2CISRC_BITS { // bits description
    Uint16 INTCODE:3; // 2:0 Interrupt code
    union I2CISRC_REG {
    Uint16 all;
    struct I2CISRC_BITS bit;
    // I2C interrupt mask register bit definitions */
    struct I2CIER_BITS { // bits description
    Uint16 AL:1; // 0 Arbitration lost interrupt
    Uint16 NACK:1; // 1 No ack interrupt
    Uint16 ARDY:1; // 2 Register access ready interrupt
    Uint16 RRDY:1; // 3 Recieve data ready interrupt
    Uint16 XRDY:1; // 4 Transmit data ready interrupt
    Uint16 SCD:1; // 5 Stop condition detection
    Uint16 AAS:1; // 6 Address as slave
    Uint16 rsvd:9; // 15:7 reserved
    union I2CIER_REG {
    Uint16 all;
    struct I2CIER_BITS bit;
    // I2C status register bit definitions */
    struct I2CSTR_BITS { // bits description
    Uint16 AD0:1; // 8 Address Zero
    Uint16 AAS:1; // 9 Address as slave
    Uint16 XSMT:1; // 10 XMIT shift empty
    Uint16 RSFULL:1; // 11 Recieve shift full
    Uint16 BB:1; // 12 Bus busy
    Uint16 NACKSNT:1; // 13 A no ack sent
    Uint16 SDIR:1; // 14 Slave direction
    Uint16 rsvd2:1; // 15 reserved
    union I2CSTR_REG {
    Uint16 all;
    struct I2CSTR_BITS bit;
    // I2C mode control register bit definitions */
    struct I2CMDR_BITS { // bits description
    Uint16 BC:3; // 2:0 Bit count
    Uint16 FDF:1; // 3 Free data format
    Uint16 STB:1; // 4 Start byte
    Uint16 IRS:1; // 5 I2C Reset not
    Uint16 DLB:1; // 6 Digital loopback
    Uint16 RM:1; // 7 Repeat mode
    Uint16 XA:1; // 8 Expand address
    Uint16 TRX:1; // 9 Transmitter/reciever
    Uint16 MST:1; // 10 Master/slave
    Uint16 STP:1; // 11 Stop condition
    Uint16 rsvd1:1; // 12 reserved
    Uint16 STT:1; // 13 Start condition
    Uint16 FREE:1; // 14 Emulation mode
    Uint16 NACKMOD:1; // 15 No Ack mode
    union I2CMDR_REG {
    Uint16 all;
    struct I2CMDR_BITS bit;
    // I2C pre-scaler register bit definitions */
    struct I2CPSC_BITS { // bits description
    Uint16 IPSC:8; // 7:0 pre-scaler
    Uint16 rsvd1:8; // 15:8 reserved
    union I2CPSC_REG {
    Uint16 all;
    struct I2CPSC_BITS bit;
    // TX FIFO control register bit definitions */
    struct I2CFFTX_BITS { // bits description
    Uint16 TXFFIL:5; // 4:0 FIFO interrupt level
    Uint16 TXFFIENA:1; // 5 FIFO interrupt enable/disable
    Uint16 TXFFINTCLR:1; // 6 FIFO clear
    Uint16 TXFFINT:1; // 7 FIFO interrupt flag
    Uint16 TXFFST:5; // 12:8 FIFO level status
    Uint16 TXFFRST:1; // 13 FIFO reset
    Uint16 I2CFFEN:1; // 14 enable/disable TX & RX FIFOs
    Uint16 rsvd1:1; // 15 reserved
    union I2CFFTX_REG {
    Uint16 all;
    struct I2CFFTX_BITS bit;
    // RX FIFO control register bit definitions */
    struct I2CFFRX_BITS { // bits description
    Uint16 RXFFIL:5; // 4:0 FIFO interrupt level
    Uint16 RXFFIENA:1; // 5 FIFO interrupt enable/disable
    Uint16 RXFFINTCLR:1; // 6 FIFO clear
    Uint16 RXFFINT:1; // 7 FIFO interrupt flag
    Uint16 RXFFST:5; // 12:8 FIFO level
    Uint16 RXFFRST:1; // 13 FIFO reset
    Uint16 rsvd1:2; // 15:14 reserved
    union I2CFFRX_REG {
    Uint16 all;
    struct I2CFFRX_BITS bit;
    struct I2C_REGS {
    Uint16 I2COAR; // Own address register
    union I2CIER_REG I2CIER; // Interrupt enable
    union I2CSTR_REG I2CSTR; // Interrupt status
    Uint16 I2CCLKL; // Clock divider low
    Uint16 I2CCLKH; // Clock divider high
    Uint16 I2CCNT; // Data count
    Uint16 I2CDRR; // Data recieve
    Uint16 I2CSAR; // Slave address
    Uint16 I2CDXR; // Data transmit
    union I2CMDR_REG I2CMDR; // Mode
    union I2CISRC_REG I2CISRC; // Interrupt source
    Uint16 rsvd1; // reserved
    union I2CPSC_REG I2CPSC; // Pre-scaler
    Uint16 rsvd2[19]; // reserved
    union I2CFFTX_REG I2CFFTX; // Transmit FIFO
    union I2CFFRX_REG I2CFFRX; // Recieve FIFO
    extern volatile struct I2C_REGS I2caRegs;
    // End of file.
    // Checkin $Date: August 2, 2006 14:35:45 $
    // FILE: DSP280x_PieCtrl.h
    // TITLE: DSP280x Device PIE Control Register Definitions.
    // PIE Control Register Bit Definitions:
    // PIECTRL: Register bit definitions:
    struct PIECTRL_BITS { // bits description
    Uint16 ENPIE:1; // 0 Enable PIE block
    Uint16 PIEVECT:15; // 15:1 Fetched vector address
    union PIECTRL_REG {
    Uint16 all;
    struct PIECTRL_BITS bit;
    // PIEIER: Register bit definitions:
    struct PIEIER_BITS { // bits description
    Uint16 INTx1:1; // 0 INTx.1
    Uint16 INTx2:1; // 1 INTx.2
    Uint16 INTx3:1; // 2 INTx.3
    Uint16 INTx4:1; // 3 INTx.4
    Uint16 INTx5:1; // 4 INTx.5
    Uint16 INTx6:1; // 5 INTx.6
    Uint16 INTx7:1; // 6 INTx.7
    Uint16 INTx8:1; // 7 INTx.8
    Uint16 rsvd:8; // 15:8 reserved
    union PIEIER_REG {
    Uint16 all;
    struct PIEIER_BITS bit;
    // PIEIFR: Register bit definitions:
    struct PIEIFR_BITS { // bits description
    union PIEIFR_REG {
    Uint16 all;
    struct PIEIFR_BITS bit;
    // PIEACK: Register bit definitions:
    struct PIEACK_BITS { // bits description
    Uint16 ACK1:1; // 0 Acknowledge PIE interrupt group 1
    Uint16 ACK2:1; // 1 Acknowledge PIE interrupt group 2
    Uint16 ACK3:1; // 2 Acknowledge PIE interrupt group 3
    Uint16 ACK4:1; // 3 Acknowledge PIE interrupt group 4
    Uint16 ACK5:1; // 4 Acknowledge PIE interrupt group 5
    Uint16 ACK6:1; // 5 Acknowledge PIE interrupt group 6
    Uint16 ACK7:1; // 6 Acknowledge PIE interrupt group 7
    Uint16 ACK8:1; // 7 Acknowledge PIE interrupt group 8
    Uint16 ACK9:1; // 8 Acknowledge PIE interrupt group 9
    Uint16 ACK10:1; // 9 Acknowledge PIE interrupt group 10
    Uint16 ACK11:1; // 10 Acknowledge PIE interrupt group 11
    Uint16 ACK12:1; // 11 Acknowledge PIE interrupt group 12
    union PIEACK_REG {
    Uint16 all;
    struct PIEACK_BITS bit;
    // PIE Control Register File:
    struct PIE_CTRL_REGS {
    union PIECTRL_REG PIECTRL; // PIE control register
    union PIEACK_REG PIEACK; // PIE acknowledge
    union PIEIER_REG PIEIER1; // PIE INT1 IER register
    union PIEIFR_REG PIEIFR1; // PIE INT1 IFR register
    union PIEIER_REG PIEIER2; // PIE INT2 IER register
    union PIEIFR_REG PIEIFR2; // PIE INT2 IFR register
    union PIEIER_REG PIEIER3; // PIE INT3 IER register
    union PIEIFR_REG PIEIFR3; // PIE INT3 IFR register
    union PIEIER_REG PIEIER4; // PIE INT4 IER register
    union PIEIFR_REG PIEIFR4; // PIE INT4 IFR register
    union PIEIER_REG PIEIER5; // PIE INT5 IER register
    union PIEIFR_REG PIEIFR5; // PIE INT5 IFR register
    union PIEIER_REG PIEIER6; // PIE INT6 IER register
    union PIEIFR_REG PIEIFR6; // PIE INT6 IFR register
    union PIEIER_REG PIEIER7; // PIE INT7 IER register
    union PIEIFR_REG PIEIFR7; // PIE INT7 IFR register
    union PIEIER_REG PIEIER8; // PIE INT8 IER register
    union PIEIFR_REG PIEIFR8; // PIE INT8 IFR register
    union PIEIER_REG PIEIER9; // PIE INT9 IER register
    union PIEIFR_REG PIEIFR9; // PIE INT9 IFR register
    union PIEIER_REG PIEIER10; // PIE INT10 IER register
    union PIEIFR_REG PIEIFR10; // PIE INT10 IFR register
    union PIEIER_REG PIEIER11; // PIE INT11 IER register
    union PIEIFR_REG PIEIFR11; // PIE INT11 IFR register
    union PIEIER_REG PIEIER12; // PIE INT12 IER register
    union PIEIFR_REG PIEIFR12; // PIE INT12 IFR register
    // PIE Control Registers External References & Function Declarations:
    extern volatile struct PIE_CTRL_REGS PieCtrlRegs;
    // End of file.
    // TI File $Revision: /main/1 $
    // Checkin $Date: December 1, 2004 12:31:56 $
    // FILE: DSP280x_PieVect.h
    // TITLE: DSP280x Devices PIE Vector Table Definitions.
    // PIE Interrupt Vector Table Definition:
    // Create a user type called PINT (pointer to interrupt):
    typedef interrupt void(*PINT)(void);
    // Define Vector Table:
    struct PIE_VECT_TABLE {
    // Reset is never fetched from this table.
    // It will always be fetched from 0x3FFFC0 in
    // boot ROM
    PINT PIE1_RESERVED;
    PINT PIE2_RESERVED;
    PINT PIE3_RESERVED;
    PINT PIE4_RESERVED;
    PINT PIE5_RESERVED;
    PINT PIE6_RESERVED;
    PINT PIE7_RESERVED;
    PINT PIE8_RESERVED;
    PINT PIE9_RESERVED;
    PINT PIE10_RESERVED;
    PINT PIE11_RESERVED;
    PINT PIE12_RESERVED;
    PINT PIE13_RESERVED;
    // Non-Peripheral Interrupts:
    PINT XINT13; // XINT13
    PINT TINT2; // CPU-Timer2
    PINT DATALOG; // Datalogging interrupt
    PINT RTOSINT; // RTOS interrupt
    PINT EMUINT; // Emulation interrupt
    PINT XNMI; // Non-maskable interrupt
    PINT ILLEGAL; // Illegal operation TRAP
    PINT USER1; // User Defined trap 1
    PINT USER2; // User Defined trap 2
    PINT USER3; // User Defined trap 3
    PINT USER4; // User Defined trap 4
    PINT USER5; // User Defined trap 5
    PINT USER6; // User Defined trap 6
    PINT USER7; // User Defined trap 7
    PINT USER8; // User Defined trap 8
    PINT USER9; // User Defined trap 9
    PINT USER10; // User Defined trap 10
    PINT USER11; // User Defined trap 11
    PINT USER12; // User Defined trap 12
    // Group 1 PIE Peripheral Vectors:
    PINT SEQ1INT;
    PINT SEQ2INT;
    PINT rsvd1_3;
    PINT XINT1;
    PINT XINT2;
    PINT ADCINT; // ADC
    PINT TINT0; // Timer 0
    PINT WAKEINT; // WD
    // Group 2 PIE Peripheral Vectors:
    PINT EPWM1_TZINT; // EPWM-1
    PINT EPWM2_TZINT; // EPWM-2
    PINT EPWM3_TZINT; // EPWM-3
    PINT EPWM4_TZINT; // EPWM-4
    PINT EPWM5_TZINT; // EPWM-5
    PINT EPWM6_TZINT; // EPWM-6
    PINT rsvd2_7;
    PINT rsvd2_8;
    // Group 3 PIE Peripheral Vectors:
    PINT EPWM1_INT; // EPWM-1
    PINT EPWM2_INT; // EPWM-2
    PINT EPWM3_INT; // EPWM-3
    PINT EPWM4_INT; // EPWM-4
    PINT EPWM5_INT; // EPWM-5
    PINT EPWM6_INT; // EPWM-6
    PINT rsvd3_7;
    PINT rsvd3_8;
    // Group 4 PIE Peripheral Vectors:
    PINT ECAP1_INT; // ECAP-1
    PINT ECAP2_INT; // ECAP-2
    PINT ECAP3_INT; // ECAP-3
    PINT ECAP4_INT; // ECAP-4
    PINT rsvd4_5;
    PINT rsvd4_6;
    PINT rsvd4_7;
    PINT rsvd4_8;
    // Group 5 PIE Peripheral Vectors:
    PINT EQEP1_INT; // EQEP-1
    PINT EQEP2_INT; // EQEP-2
    PINT rsvd5_3;
    PINT rsvd5_4;
    PINT rsvd5_5;
    PINT rsvd5_6;
    PINT rsvd5_7;
    PINT rsvd5_8;
    // Group 6 PIE Peripheral Vectors:
    PINT SPIRXINTA; // SPI-A
    PINT SPITXINTA; // SPI-A
    PINT SPIRXINTB; // SPI-B
    PINT SPITXINTB; // SPI-B
    PINT SPIRXINTC; // SPI-C
    PINT SPITXINTC; // SPI-C
    PINT SPIRXINTD; // SPI-D
    PINT SPITXINTD; // SPI-D
    // Group 7 PIE Peripheral Vectors:
    PINT rsvd7_1;
    PINT rsvd7_2;
    PINT rsvd7_3;
    PINT rsvd7_4;
    PINT rsvd7_5;
    PINT rsvd7_6;
    PINT rsvd7_7;
    PINT rsvd7_8;
    // Group 8 PIE Peripheral Vectors:
    PINT I2CINT1A; // I2C-A
    PINT I2CINT2A; // I2C-A
    PINT rsvd8_3;
    PINT rsvd8_4;
    PINT rsvd8_5;
    PINT rsvd8_6;
    PINT rsvd8_7;
    PINT rsvd8_8;
    // Group 9 PIE Peripheral Vectors:
    PINT SCIRXINTA; // SCI-A
    PINT SCITXINTA; // SCI-A
    PINT SCIRXINTB; // SCI-B
    PINT SCITXINTB; // SCI-B
    PINT ECAN0INTA; // eCAN-A
    PINT ECAN1INTA; // eCAN-A
    PINT ECAN0INTB; // eCAN-B
    PINT ECAN1INTB; // eCAN-B
    // Group 10 PIE Peripheral Vectors:
    PINT rsvd10_1;
    PINT rsvd10_2;
    PINT rsvd10_3;
    PINT rsvd10_4;
    PINT rsvd10_5;
    PINT rsvd10_6;
    PINT rsvd10_7;
    PINT rsvd10_8;
    // Group 11 PIE Peripheral Vectors:
    PINT rsvd11_1;
    PINT rsvd11_2;
    PINT rsvd11_3;
    PINT rsvd11_4;
    PINT rsvd11_5;
    PINT rsvd11_6;
    PINT rsvd11_7;
    PINT rsvd11_8;
    // Group 12 PIE Peripheral Vectors:
    PINT rsvd12_1;
    PINT rsvd12_2;
    PINT rsvd12_3;
    PINT rsvd12_4;
    PINT rsvd12_5;
    PINT rsvd12_6;
    PINT rsvd12_7;
    PINT rsvd12_8;
    // PIE Interrupt Vector Table External References & Function Declarations:
    extern struct PIE_VECT_TABLE PieVectTable;
    // End of file.
    // Checkin $Date: April 18, 2005 09:43:45 $
    // FILE: DSP280x_Spi.h
    // TITLE: DSP280x Device SPI Register Definitions.
    // SPI Individual Register Bit Definitions:
    // SPI FIFO Transmit register bit definitions:
    struct SPIFFTX_BITS { // bit description
    Uint16 TXFFIL:5; // 4:0 Interrupt level
    Uint16 TXFFIENA:1; // 5 Interrupt enable
    Uint16 TXFFINTCLR:1; // 6 Clear INT flag
    Uint16 TXFFINT:1; // 7 INT flag
    Uint16 TXFFST:5; // 12:8 FIFO status
    Uint16 TXFIFO:1; // 13 FIFO reset
    Uint16 SPIFFENA:1; // 14 Enhancement enable
    Uint16 SPIRST:1; // 15 Reset SPI
    union SPIFFTX_REG {
    Uint16 all;
    struct SPIFFTX_BITS bit;
    // SPI FIFO recieve register bit definitions:
    struct SPIFFRX_BITS { // bits description
    Uint16 RXFFIL:5; // 4:0 Interrupt level
    Uint16 RXFFIENA:1; // 5 Interrupt enable
    Uint16 RXFFINTCLR:1; // 6 Clear INT flag
    Uint16 RXFFINT:1; // 7 INT flag
    Uint16 RXFFST:5; // 12:8 FIFO status
    Uint16 RXFIFORESET:1; // 13 FIFO reset
    Uint16 RXFFOVFCLR:1; // 14 Clear overflow
    Uint16 RXFFOVF:1; // 15 FIFO overflow
    union SPIFFRX_REG {
    Uint16 all;
    struct SPIFFRX_BITS bit;
    // SPI FIFO control register bit definitions:
    struct SPIFFCT_BITS { // bits description
    Uint16 TXDLY:8; // 7:0 FIFO transmit delay
    union SPIFFCT_REG {
    Uint16 all;
    struct SPIFFCT_BITS bit;
    // SPI configuration register bit definitions:
    struct SPICCR_BITS { // bits description
    Uint16 SPICHAR:4; // 3:0 Character length control
    Uint16 SPILBK:1; // 4 Loop-back enable/disable
    Uint16 CLKPOLARITY:1; // 6 Clock polarity
    Uint16 SPISWRESET:1; // 7 SPI SW Reset
    union SPICCR_REG {
    Uint16 all;
    struct SPICCR_BITS bit;
    // SPI operation control register bit definitions:
    struct SPICTL_BITS { // bits description
    Uint16 SPIINTENA:1; // 0 Interrupt enable
    Uint16 TALK:1; // 1 Master/Slave transmit enable
    Uint16 MASTER_SLAVE:1; // 2 Network control mode
    Uint16 CLK_PHASE:1; // 3 Clock phase select
    Uint16 OVERRUNINTENA:1; // 4 Overrun interrupt enable
    Uint16 rsvd:11; // 15:5 reserved
    union SPICTL_REG {
    Uint16 all;
    struct SPICTL_BITS bit;
    // SPI status register bit definitions:
    struct SPISTS_BITS { // bits description
    Uint16 BUFFULL_FLAG:1; // 5 SPI transmit buffer full flag
    Uint16 INT_FLAG:1; // 6 SPI interrupt flag
    Uint16 OVERRUN_FLAG:1; // 7 SPI reciever overrun flag
    union SPISTS_REG {
    Uint16 all;
    struct SPISTS_BITS bit;
    // SPI priority control register bit definitions:
    struct SPIPRI_BITS { // bits description
    Uint16 rsvd1:4; // 3:0 reserved
    Uint16 FREE:1; // 4 Free emulation mode control
    Uint16 SOFT:1; // 5 Soft emulation mode control
    Uint16 PRIORITY:1; // 6 Interrupt priority select
    Uint16 rsvd2:9; // 15:7 reserved
    union SPIPRI_REG {
    Uint16 all;
    struct SPIPRI_BITS bit;
    // SPI Register File:
    struct SPI_REGS {
    union SPICCR_REG SPICCR; // Configuration register
    union SPICTL_REG SPICTL; // Operation control register
    union SPISTS_REG SPISTS; // Status register
    Uint16 SPIBRR; // Baud Rate
    Uint16 rsvd2; // reserved
    Uint16 SPIRXEMU; // Emulation buffer
    Uint16 SPIRXBUF; // Serial input buffer
    Uint16 SPITXBUF; // Serial output buffer
    Uint16 SPIDAT; // Serial data
    union SPIFFTX_REG SPIFFTX; // FIFO transmit register
    union SPIFFRX_REG SPIFFRX; // FIFO recieve register
    union SPIFFCT_REG SPIFFCT; // FIFO control register
    Uint16 rsvd3[2]; // reserved
    union SPIPRI_REG SPIPRI; // FIFO Priority control
    // SPI External References & Function Declarations:
    extern volatile struct SPI_REGS SpiaRegs;
    extern volatile struct SPI_REGS SpibRegs;
    extern volatile struct SPI_REGS SpicRegs;
    extern volatile struct SPI_REGS SpidRegs;
    // End of file.
    // Checkin $Date: December 1, 2004 12:31:58 $
    // FILE: DSP280x_Sci.h
    // TITLE: DSP280x Device SCI Register Definitions.
    // SCI Individual Register Bit Definitions
    // SCICCR communication control register bit definitions:
    struct SCICCR_BITS { // bit description
    Uint16 SCICHAR:3; // 2:0 Character length control
    Uint16 ADDRIDLE_MODE:1; // 3 ADDR/IDLE Mode control
    Uint16 LOOPBKENA:1; // 4 Loop Back enable
    Uint16 PARITYENA:1; // 5 Parity enable
    Uint16 PARITY:1; // 6 Even or Odd Parity
    Uint16 STOPBITS:1; // 7 Number of Stop Bits
    union SCICCR_REG {
    Uint16 all;
    struct SCICCR_BITS bit;
    // SCICTL1 control register 1 bit definitions:
    struct SCICTL1_BITS { // bit description
    Uint16 RXENA:1; // 0 SCI receiver enable
    Uint16 TXENA:1; // 1 SCI transmitter enable
    Uint16 SLEEP:1; // 2 SCI sleep
    Uint16 TXWAKE:1; // 3 Transmitter wakeup method
    Uint16 rsvd:1; // 4 reserved
    Uint16 SWRESET:1; // 5 Software reset
    Uint16 RXERRINTENA:1; // 6 Recieve interrupt enable
    Uint16 rsvd1:9; // 15:7 reserved
    union SCICTL1_REG {
    Uint16 all;
    struct SCICTL1_BITS bit;
    // SCICTL2 control register 2 bit definitions:
    struct SCICTL2_BITS { // bit description
    Uint16 TXINTENA:1; // 0 Transmit interrupt enable
    Uint16 RXBKINTENA:1; // 1 Receiver-buffer break enable
    Uint16 rsvd:4; // 5:2 reserved
    Uint16 TXEMPTY:1; // 6 Transmitter empty flag
    Uint16 TXRDY:1; // 7 Transmitter ready flag
    union SCICTL2_REG {
    Uint16 all;
    struct SCICTL2_BITS bit;
    // SCIRXST Receiver status register bit definitions:
    struct SCIRXST_BITS { // bit description
    Uint16 rsvd:1; // 0 reserved
    Uint16 RXWAKE:1; // 1 Receiver wakeup detect flag
    Uint16 PE:1; // 2 Parity error flag
    Uint16 OE:1; // 3 Overrun error flag
    Uint16 FE:1; // 4 Framing error flag
    Uint16 BRKDT:1; // 5 Break-detect flag
    Uint16 RXRDY:1; // 6 Receiver ready flag
    Uint16 RXERROR:1; // 7 Receiver error flag
    union SCIRXST_REG {
    Uint16 all;
    struct SCIRXST_BITS bit;
    // SCIRXBUF Receiver Data Buffer with FIFO bit definitions:
    struct SCIRXBUF_BITS { // bits description
    Uint16 RXDT:8; // 7:0 Receive word
    Uint16 rsvd:6; // 13:8 reserved
    Uint16 SCIFFPE:1; // 14 SCI PE error in FIFO mode
    Uint16 SCIFFFE:1; // 15 SCI FE error in FIFO mode
    union SCIRXBUF_REG {
    Uint16 all;
    struct SCIRXBUF_BITS bit;
    // SCIPRI Priority control register bit definitions:
    struct SCIPRI_BITS { // bit description
    Uint16 rsvd:3; // 2:0 reserved
    Uint16 FREE:1; // 3 Free emulation suspend mode
    Uint16 SOFT:1; // 4 Soft emulation suspend mode
    union SCIPRI_REG {
    Uint16 all;
    struct SCIPRI_BITS bit;
    // SCI FIFO Transmit register bit definitions:
    struct SCIFFTX_BITS { // bit description
    Uint16 TXFIFOXRESET:1; // 13 FIFO reset
    Uint16 SCIFFENA:1; // 14 Enhancement enable
    Uint16 SCIRST:1; // 15 SCI reset rx/tx channels
    union SCIFFTX_REG {
    Uint16 all;
    struct SCIFFTX_BITS bit;
    // SCI FIFO recieve register bit definitions:
    struct SCIFFRX_BITS { // bits description
    Uint16 RXFFOVRCLR:1; // 14 Clear overflow
    union SCIFFRX_REG {
    Uint16 all;
    struct SCIFFRX_BITS bit;
    // SCI FIFO control register bit definitions:
    struct SCIFFCT_BITS { // bits description
    Uint16 FFTXDLY:8; // 7:0 FIFO transmit delay
    Uint16 rsvd:5; // 12:8 reserved
    Uint16 CDC:1; // 13 Auto baud mode enable
    Uint16 ABDCLR:1; // 14 Auto baud clear
    Uint16 ABD:1; // 15 Auto baud detect
    union SCIFFCT_REG {
    Uint16 all;
    struct SCIFFCT_BITS bit;
    // SCI Register File:
    struct SCI_REGS {
    union SCICCR_REG SCICCR; // Communications control register
    union SCICTL1_REG SCICTL1; // Control register 1
    Uint16 SCIHBAUD; // Baud rate (high) register
    Uint16 SCILBAUD; // Baud rate (low) register
    union SCICTL2_REG SCICTL2; // Control register 2
    union SCIRXST_REG SCIRXST; // Recieve status register
    Uint16 SCIRXEMU; // Recieve emulation buffer register
    union SCIRXBUF_REG SCIRXBUF; // Recieve data buffer
    Uint16 SCITXBUF; // Transmit data buffer
    union SCIFFTX_REG SCIFFTX; // FIFO transmit register
    union SCIFFRX_REG SCIFFRX; // FIFO recieve register
    union SCIFFCT_REG SCIFFCT; // FIFO control register
    Uint16 rsvd3; // reserved
    union SCIPRI_REG SCIPRI; // FIFO Priority control
    // SCI External References & Function Declarations:
    extern volatile struct SCI_REGS SciaRegs;
    extern volatile struct SCI_REGS ScibRegs;
    // End of file.
    // TI File $Revision: /main/3 $
    // Checkin $Date: September 8, 2005 14:50:32 $
    // FILE: DSP280x_SysCtrl.h
    // TITLE: DSP280x Device System Control Register Definitions.
    // System Control Individual Register Bit Definitions:
    // XCLKOUT Control
    struct XCLK_BITS { // bits description
    Uint16 XCLKOUTDIV:2; // 1:0 XCLKOUT Divide Ratio
    Uint16 XCLKOUTDAT:1; // 2 Status of XCLKOUT
    Uint16 X1DAT:1; // 3 Output of the oscillator cell
    Uint16 XCLKINDAT:1; // 4 Status of the XCLKIN pin
    Uint16 X1CNT:4; // 11:8 4-bit counter
    Uint16 XCLKINCNT:4; // 15:12 4-bit counter
    union XCLK_REG {
    Uint16 all;
    struct XCLK_BITS bit;
    // PLL Status Register
    struct PLLSTS_BITS { // bits description
    Uint16 PLLLOCKS:1; // 0 PLL lock status
    Uint16 CLKINDIV:1; // 1 CLKIN div by 2
    Uint16 PLLOFF:1; // 2 PLL off bit
    Uint16 MCLKSTS:1; // 3 Missing clock status bit
    Uint16 MCLKCLR:1; // 4 Missing clock clear bit
    Uint16 OSCOFF:1; // 5 Oscillator clock off
    Uint16 MCLKOFF:1; // 6 Missing clock detect
    union PLLSTS_REG {
    Uint16 all;
    struct PLLSTS_BITS bit;
    // High speed peripheral clock register bit definitions:
    struct HISPCP_BITS { // bits description
    Uint16 HSPCLK:3; // 2:0 Rate relative to SYSCLKOUT
    union HISPCP_REG {
    Uint16 all;
    struct HISPCP_BITS bit;
    // Low speed peripheral clock register bit definitions:
    struct LOSPCP_BITS { // bits description
    Uint16 LSPCLK:3; // 2:0 Rate relative to SYSCLKOUT
    union LOSPCP_REG {
    Uint16 all;
    struct LOSPCP_BITS bit;
    // Peripheral clock control register 0 bit definitions:
    struct PCLKCR0_BITS { // bits description
    Uint16 rsvd1:2; // 1:0 reserved
    Uint16 TBCLKSYNC:1; // 2 EWPM Module TBCLK enable/sync
    Uint16 ADCENCLK:1; // 3 Enable high speed clk to ADC
    Uint16 I2CAENCLK:1; // 4 Enable SYSCLKOUT to I2C-A
    Uint16 rsvd2:1; // 5 reserved
    Uint16 SPICENCLK:1; // 6 Enable low speed clk to SPI-C
    Uint16 SPIDENCLK:1; // 7 Enable low speed clk to SPI-D
    Uint16 SPIAENCLK:1; // 8 Enable low speed clk to SPI-A
    Uint16 SPIBENCLK:1; // 9 Enable low speed clk to SPI-B
    Uint16 SCIAENCLK:1; // 10 Enable low speed clk to SCI-A
    Uint16 SCIBENCLK:1; // 11 Enable low speed clk to SCI-B
    Uint16 rsvd3:2; // 13:12 reserved
    Uint16 ECANAENCLK:1; // 14 Enable system clk to eCAN-A
    Uint16 ECANBENCLK:1; // 15 Enable system clk to eCAN-B
    union PCLKCR0_REG {
    Uint16 all;
    struct PCLKCR0_BITS bit;
    // Peripheral clock control register 1 bit definitions:
    struct PCLKCR1_BITS { // bits description
    Uint16 EPWM1ENCLK:1; // 0 Enable SYSCLKOUT to EPWM1
    Uint16 EPWM2ENCLK:1; // 1 Enable SYSCLKOUT to EPWM2
    Uint16 EPWM3ENCLK:1; // 2 Enable SYSCLKOUT to EPWM3
    Uint16 EPWM4ENCLK:1; // 3 Enable SYSCLKOUT to EPWM4
    Uint16 EPWM5ENCLK:1; // 4 Enable SYSCLKOUT to EPWM5
    Uint16 EPWM6ENCLK:1; // 5 Enable SYSCLKOUT to EPWM6
    Uint16 ECAP1ENCLK:1; // 8 Enable SYSCLKOUT to ECAP1
    Uint16 ECAP2ENCLK:1; // 9 Enable SYSCLKOUT to ECAP2
    Uint16 ECAP3ENCLK:1; // 10 Enable SYSCLKOUT to ECAP3
    Uint16 ECAP4ENCLK:1; // 11 Enable SYSCLKOUT to ECAP4
    Uint16 rsvd2:2; // 13:12 reserved
    Uint16 EQEP1ENCLK:1; // 11 Enable SYSCLKOUT to EQEP1
    Uint16 EQEP2ENCLK:1; // 11 Enable SYSCLKOUT to EQEP2
    union PCLKCR1_REG {
    Uint16 all;
    struct PCLKCR1_BITS bit;
    // PLL control register bit definitions:
    struct PLLCR_BITS { // bits description
    Uint16 DIV:4; // 3:0 Set clock ratio for the PLL
    union PLLCR_REG {
    Uint16 all;
    struct PLLCR_BITS bit;
    // Low Power Mode 0 control register bit definitions:
    struct LPMCR0_BITS { // bits description
    Uint16 LPM:2; // 1:0 Set the low power mode
    Uint16 QUALSTDBY:6; // 7:2 Qualification
    Uint16 rsvd1:7; // 14:8 reserved
    Uint16 WDINTE:1; // 15 Enables WD to wake the device from STANDBY
    union LPMCR0_REG {
    Uint16 all;
    struct LPMCR0_BITS bit;
    // System Control Register File:
    // System control and status register bit definitions:
    struct SCSR_BITS { // bits description
    Uint16 WDOVERRIDE:1; // 0 Allow watchdog disable
    Uint16 WDENINT:1; // 1 Enable/disable WD interrupt
    Uint16 rsvd1:14; // 15:2 reserved
    union SCSR_REG {
    Uint16 all;
    struct SCSR_BITS bit;
    struct SYS_CTRL_REGS {
    union XCLK_REG XCLK; // 0
    union PLLSTS_REG PLLSTS; // 1
    Uint16 rsvd1[8]; // 2-9
    union HISPCP_REG HISPCP; // 10: High-speed peripheral clock pre-scaler
    union LOSPCP_REG LOSPCP; // 11: Low-speed peripheral clock pre-scaler
    union PCLKCR0_REG PCLKCR0; // 12: Peripheral clock control register
    union PCLKCR1_REG PCLKCR1; // 13: Peripheral clock control register
    union LPMCR0_REG LPMCR0; // 14: Low-power mode control register 0
    Uint16 rsvd2; // 15: reserved
    Uint16 rsvd3; // 16: reserved
    union PLLCR_REG PLLCR; // 17: PLL control register
    // No bit definitions are defined for SCSR because
    // a read-modify-write instruction can clear the WDOVERRIDE bit
    //lkj20100210_Check
    // Uint16 SCSR; // 18: System control and status register
    union SCSR_REG SCSR; // 18: System control and status register
    Uint16 WDCNTR; // 19: WD counter register
    Uint16 rsvd4; // 20
    Uint16 WDKEY; // 21: WD reset key register
    Uint16 rsvd5[3]; // 22-24
    // No bit definitions are defined for WDCR because
    // the proper value must be written to the WDCHK field
    // whenever writing to this register.
    Uint16 WDCR; // 25: WD timer control register
    Uint16 rsvd6[6]; // 26-31
    /* CSM Registers */
    /* CSM Status & Control register bit definitions */
    struct CSMSCR_BITS { // bit description
    Uint16 SECURE:1; // 0 Secure flag
    Uint16 rsvd1:14; // 14-1 reserved
    Uint16 FORCESEC:1; // 15 Force Secure control bit
    /* Allow access to the bit fields or entire register */
    union CSMSCR_REG {
    Uint16 all;
    struct CSMSCR_BITS bit;
    /* CSM Register File */
    struct CSM_REGS {
    Uint16 KEY0; // KEY reg bits 15-0
    Uint16 KEY1; // KEY reg bits 31-16
    Uint16 KEY2; // KEY reg bits 47-32
    Uint16 KEY3; // KEY reg bits 63-48
    Uint16 KEY4; // KEY reg bits 79-64
    Uint16 KEY5; // KEY reg bits 95-80
    Uint16 KEY6; // KEY reg bits 111-96
    Uint16 KEY7; // KEY reg bits 127-112
    Uint16 rsvd4; // reserved
    Uint16 rsvd5; // reserved
    Uint16 rsvd6; // reserved
    Uint16 rsvd7; // reserved
    union CSMSCR_REG CSMSCR; // CSM Status & Control register
    /* Password locations */
    struct CSM_PWL {
    Uint16 PSWD0; // PSWD bits 15-0
    Uint16 PSWD1; // PSWD bits 31-16
    Uint16 PSWD2; // PSWD bits 47-32
    Uint16 PSWD3; // PSWD bits 63-48
    Uint16 PSWD4; // PSWD bits 79-64
    Uint16 PSWD5; // PSWD bits 95-80
    Uint16 PSWD6; // PSWD bits 111-96
    Uint16 PSWD7; // PSWD bits 127-112
    /* Flash Registers */
    /* Flash Option Register bit definitions */
    struct FOPT_BITS { // bit description
    Uint16 ENPIPE:1; // 0 Enable Pipeline Mode
    Uint16 rsvd:15; // 1-15 reserved
    union FOPT_REG {
    Uint16 all;
    struct FOPT_BITS bit;
    /* Flash Power Modes Register bit definitions */
    struct FPWR_BITS { // bit description
    Uint16 PWR:2; // 0-1 Power Mode bits
    Uint16 rsvd:14; // 2-15 reserved
    union FPWR_REG {
    Uint16 all;
    struct FPWR_BITS bit;
    /* Flash Status Register bit definitions */
    struct FSTATUS_BITS { // bit description
    Uint16 PWRS:2; // 0-1 Power Mode Status bits
    Uint16 STDBYWAITS:1; // 2 Bank/Pump Sleep to Standby Wait Counter Status bits
    Uint16 ACTIVEWAITS:1; // 3 Bank/Pump Standby to Active Wait Counter Status bits
    Uint16 rsvd1:4; // 4-7 reserved
    Uint16 V3STAT:1; // 8 VDD3V Status Latch bit
    Uint16 rsvd2:7; // 9-15 reserved
    union FSTATUS_REG {
    Uint16 all;
    struct FSTATUS_BITS bit;
    /* Flash Sleep to Standby Wait Counter Register bit definitions */
    struct FSTDBYWAIT_BITS { // bit description
    Uint16 STDBYWAIT:9; // 0-8 Bank/Pump Sleep to Standby Wait Count bits
    Uint16 rsvd:7; // 9-15 reserved
    union FSTDBYWAIT_REG {
    Uint16 all;
    struct FSTDBYWAIT_BITS bit;
    /* Flash Standby to Active Wait Counter Register bit definitions */
    struct FACTIVEWAIT_BITS { // bit description
    Uint16 ACTIVEWAIT:9; // 0-8 Bank/Pump Standby to Active Wait Count bits
    union FACTIVEWAIT_REG {
    Uint16 all;
    struct FACTIVEWAIT_BITS bit;
    /* Bank Read Access Wait State Register bit definitions */
    struct FBANKWAIT_BITS { // bit description
    Uint16 RANDWAIT:4; // 0-3 Flash Random Read Wait State bits
    Uint16 PAGEWAIT:4; // 8-11 Flash Paged Read Wait State bits
    Uint16 rsvd2:4; // 12-15 reserved
    union FBANKWAIT_REG {
    Uint16 all;
    struct FBANKWAIT_BITS bit;
    /* OTP Read Access Wait State Register bit definitions */
    struct FOTPWAIT_BITS { // bit description
    Uint16 OTPWAIT:5; // 0-4 OTP Read Wait State bits
    Uint16 rsvd:11; // 5-15 reserved
    union FOTPWAIT_REG {
    Uint16 all;
    struct FOTPWAIT_BITS bit;
    struct FLASH_REGS {
    union FOPT_REG FOPT; // Option Register
    union FPWR_REG FPWR; // Power Modes Register
    union FSTATUS_REG FSTATUS; // Status Register
    union FSTDBYWAIT_REG FSTDBYWAIT; // Pump/Bank Sleep to Standby Wait State Register
    union FACTIVEWAIT_REG FACTIVEWAIT; // Pump/Bank Standby to Active Wait State Register
    union FBANKWAIT_REG FBANKWAIT; // Bank Read Access Wait State Register
    union FOTPWAIT_REG FOTPWAIT; // OTP Read Access Wait State Register
    // System Control External References & Function Declarations:
    extern volatile struct SYS_CTRL_REGS SysCtrlRegs;
    extern volatile struct CSM_REGS CsmRegs;
    extern volatile struct CSM_PWL CsmPwl;
    extern volatile struct FLASH_REGS FlashRegs;
    // End of file.
    // Checkin $Date: December 1, 2004 12:32:06 $
    // FILE: DSP280x_XIntrupt.h
    // TITLE: DSP280x Device External Interrupt Register Definitions.
    struct XINTCR_BITS {
    Uint16 ENABLE:1; // 0 enable/disable
    Uint16 rsvd1:1; // 1 reserved
    Uint16 POLARITY:2; // 3:2 pos/neg, both triggered
    Uint16 rsvd2:12; //15:4 reserved
    union XINTCR_REG {
    Uint16 all;
    struct XINTCR_BITS bit;
    struct XNMICR_BITS {
    Uint16 SELECT:1; // 1 Timer 1 or XNMI connected to INT13
    Uint16 POLARITY:2; // 3:2 pos/neg, or both triggered
    Uint16 rsvd2:12; // 15:4 reserved
    union XNMICR_REG {
    Uint16 all;
    struct XNMICR_BITS bit;
    // External Interrupt Register File:
    struct XINTRUPT_REGS {
    union XINTCR_REG XINT1CR;
    union XINTCR_REG XINT2CR;
    Uint16 rsvd1[5];
    union XNMICR_REG XNMICR;
    Uint16 XINT1CTR;
    Uint16 XINT2CTR;
    Uint16 rsvd[5];
    Uint16 XNMICTR;
    // External Interrupt References & Function Declarations:
    extern volatile struct XINTRUPT_REGS XIntruptRegs;
    // End of file.
    // End of file.
    //#include "Compile.H"
    // 2004.04.19 KKY
    // 2004.04.19 KKY
    // 2004.12.30 KKY
    typedef int Int16;
    // 2004.04.19 KKY
    typedef int Int16;
    typedef long Int32;
    typedef unsigned int Uint16;
    typedef unsigned long Uint32;
    typedef unsigned char Uint8;
    typedef unsigned BOOL;
    typedef unsigned char BYTE;
    typedef unsigned int WORD;
    typedef unsigned long LONG;
    typedef char SBYTE;
    typedef short SWORD;
    typedef long SLONG;
    typedef BYTE *pBYTE;
    typedef WORD *pWORD;
    // 2020.07.28 LEW - start
    //typedef int int16; // Include(TI) DSP280x_Devices.h¿¡ Á¤ÀǍ
    typedef unsigned int uint16;
    //typedef long int32; // Include(TI) DSP280x_Devices.h¿¡ Á¤ÀǍ
    typedef unsigned long uint32;
    typedef long long int64;
    typedef unsigned long long uint64;
    // 2020.07.28 LEW - end
    int64 i64tmp1;
    int32 mult(int32 x, uint16 alpha)
    i64tmp1 = (int64)(x) * (int32)alpha;
    return (int32)(i64tmp1>>16);
    I got the same result with 18.1.7 compiler.
    The desired result is -100000, but I got 65436000.
    I think -100 is converted to 65436 before multiplication.
    But I want signed multiplication so, x has to be sign-extended.
    And I verified there is no problem when x is positive.
    Thank you.
  • You show two sets of compiler options ...
    EUN WOO LEE82 said:
    ["Compiler" Settings: "Debug"]
    Options=-pds9 -fr"$(Proj_dir)\Debug" -fs"$(Proj_dir)\Debug" -i"$(Proj_dir)\Include(TI)" -d"_DEBUG" -d"LARGE_MODEL" -ml -mt -v28
    ["Compiler" Settings: "Release"]
    Options=-o3 -fr"$(Proj_dir)\Release" -i"$(Proj_dir)\Include(TI)" -d"LARGE_MODEL" -ml -v28
    Each one corresponds to a different build configuration for your project in CCS 3.3.  When you see the problem, which build options get used?
    Thanks and regards,
    -George
    Sorry I keep bothering you by omitting some information.
    I used the "Debug" option.
    And, I examined the assembly code.
    I don't know why I get the wrong result yet.
    The value of parameter x in the stack seems to be wrong when the x is negative.
    // caller
    MOVL ACC,@_lx ; |558|
    MOVW DP,#_wAlphaHPFTest
    MOVZ AR4,@_wAlphaHPFTest ; |558|
    LCR #_mult ; |558|
    // callee
    ;* TMS320C2000 C/C++ Codegen PC v4.1.3 *
    ;* Date/Time created: Wed Jul 29 16:11:03 2020 *
    .compiler_opts --mem_model:code=flat --mem_model:data=large --silicon_version=28
    FP .set XAR2
    DW$CU .dwtag DW_TAG_compile_unit
    .dwattr DW$CU, DW_AT_name("test1.c")
    .dwattr DW$CU, DW_AT_producer("TMS320C2000 C/C++ Codegen PC v4.1.3 Copyright (c) 1996-2006 Texas Instruments Incorporated")
    .dwattr DW$CU, DW_AT_stmt_list(0x00)
    .dwattr DW$CU, DW_AT_TI_VERSION(0x01)
    .global _i64tmp1
    _i64tmp1: .usect ".ebss",4,1,1
    DW$1 .dwtag DW_TAG_variable, DW_AT_name("i64tmp1"), DW_AT_symbol_name("_i64tmp1")
    .dwattr DW$1, DW_AT_location[DW_OP_addr _i64tmp1]
    .dwattr DW$1, DW_AT_type(*DW$T$22)
    .dwattr DW$1, DW_AT_external(0x01)
    ; C:\Program Files (x86)\Texas Instruments\C2000 Code Generation Tools 4.1.3\bin\ac2000.exe -@C:\Users\ewlee\AppData\Local\Temp\TI30412
    .sect ".text"
    .global _mult
    DW$2 .dwtag DW_TAG_subprogram, DW_AT_name("mult"), DW_AT_symbol_name("_mult")
    .dwattr DW$2, DW_AT_low_pc(_mult)
    .dwattr DW$2, DW_AT_high_pc(0x00)
    .dwattr DW$2, DW_AT_begin_file("test1.c")
    .dwattr DW$2, DW_AT_begin_line(0x05)
    .dwattr DW$2, DW_AT_begin_column(0x07)
    .dwattr DW$2, DW_AT_frame_base[DW_OP_breg20 -10]
    .dwattr DW$2, DW_AT_skeletal(0x01)
    .dwpsn "test1.c",6,1
    ;* FNAME: _mult FR SIZE: 8 *
    ;* FUNCTION ENVIRONMENT *
    ;* FUNCTION PROPERTIES *
    ;* 0 Parameter, 3 Auto, 0 SOE *
    _mult:
    ;* AL assigned to _x
    DW$3 .dwtag DW_TAG_formal_parameter, DW_AT_name("x"), DW_AT_symbol_name("_x")
    .dwattr DW$3, DW_AT_type(*DW$T$20)
    .dwattr DW$3, DW_AT_location[DW_OP_reg0]
    ;* AR4 assigned to _alpha
    DW$4 .dwtag DW_TAG_formal_parameter, DW_AT_name("alpha"), DW_AT_symbol_name("_alpha")
    .dwattr DW$4, DW_AT_type(*DW$T$19)
    .dwattr DW$4, DW_AT_location[DW_OP_reg12]
    ADDB SP,#8
    MOV *-SP[7],AR4 ; |6| : *(SP-7) = AR4 = alpha, parameter passed by register
    MOVL *-SP[6],ACC ; |6| : *(SP-6) = ACC = x, parameter passed by register, *(SP-5) is also used. little endian
    MOVZ AR6,*-SP[7] ; AR6 = alpha
    MOVW DP,#_i64tmp1
    MOVL XT,XAR6 ; |7| : XT = alpha (32bit)
    IMPYL P,XT,ACC ; |7| : IMPYL = Signed 32 x 32-bit multiply, Lower Half, P = (XT * ACC)&0xFFFFFFFF
    MOVL @_i64tmp1,P ; |7|
    QMPYL ACC,XT,ACC ; |7| : QMPYL = Signed 32 x 32-bit multiply, Upper Half
    MOVL @_i64tmp1+2,ACC ; |7|
    MOVL P,@_i64tmp1 ; |8|
    ASR64 ACC:P,16 ; |8|
    MOVL ACC,P ; |8|
    SUBB SP,#8 ; |8|
    .dwpsn "test1.c",9,1
    LRETR
    ; return occurs
    .dwattr DW$2, DW_AT_end_file("test1.c")
    .dwattr DW$2, DW_AT_end_line(0x09)
    .dwattr DW$2, DW_AT_end_column(0x01)
    .dwendtag DW$2
    ;* TYPE INFORMATION *
    DW$T$19 .dwtag DW_TAG_typedef, DW_AT_name("uint16"), DW_AT_type(*DW$T$11)
    .dwattr DW$T$19, DW_AT_language(DW_LANG_C)
    DW$T$20 .dwtag DW_TAG_typedef, DW_AT_name("int32"), DW_AT_type(*DW$T$12)
    .dwattr DW$T$20, DW_AT_language(DW_LANG_C)
    DW$T$21 .dwtag DW_TAG_subroutine_type, DW_AT_type(*DW$T$20)
    .dwattr DW$T$21, DW_AT_language(DW_LANG_C)
    DW$5 .dwtag DW_TAG_formal_parameter, DW_AT_type(*DW$T$20)
    DW$6 .dwtag DW_TAG_formal_parameter, DW_AT_type(*DW$T$19)
    .dwendtag DW$T$21
    DW$T$22 .dwtag DW_TAG_typedef, DW_AT_name("int64"), DW_AT_type(*DW$T$14)
    .dwattr DW$T$22, DW_AT_language(DW_LANG_C)
    DW$T$11 .dwtag DW_TAG_base_type, DW_AT_name("unsigned int")
    .dwattr DW$T$11, DW_AT_encoding(DW_ATE_unsigned)
    .dwattr DW$T$11, DW_AT_byte_size(0x01)
    DW$T$12 .dwtag DW_TAG_base_type, DW_AT_name("long")
    .dwattr DW$T$12, DW_AT_encoding(DW_ATE_signed)
    .dwattr DW$T$12, DW_AT_byte_size(0x02)
    DW$T$14 .dwtag DW_TAG_base_type, DW_AT_name("long long")
    .dwattr DW$T$14, DW_AT_encoding(DW_ATE_signed)
    .dwattr DW$T$14, DW_AT_byte_size(0x04)
    .dwattr DW$2, DW_AT_external(0x01)
    .dwattr DW$2, DW_AT_type(*DW$T$20)
    .dwattr DW$CU, DW_AT_language(DW_LANG_C)
    ;* DWARF REGISTER MAP *
    DW$7 .dwtag DW_TAG_assign_register, DW_AT_name("AL")
    .dwattr DW$7, DW_AT_location[DW_OP_reg0]
    DW$8 .dwtag DW_TAG_assign_register, DW_AT_name("AH")
    .dwattr DW$8, DW_AT_location[DW_OP_reg1]
    DW$9 .dwtag DW_TAG_assign_register, DW_AT_name("PL")
    .dwattr DW$9, DW_AT_location[DW_OP_reg2]
    DW$10 .dwtag DW_TAG_assign_register, DW_AT_name("PH")
    .dwattr DW$10, DW_AT_location[DW_OP_reg3]
    DW$11 .dwtag DW_TAG_assign_register, DW_AT_name("AR0")
    .dwattr DW$11, DW_AT_location[DW_OP_reg4]
    DW$12 .dwtag DW_TAG_assign_register, DW_AT_name("XAR0")
    .dwattr DW$12, DW_AT_location[DW_OP_reg5]
    DW$13 .dwtag DW_TAG_assign_register, DW_AT_name("AR1")
    .dwattr DW$13, DW_AT_location[DW_OP_reg6]
    DW$14 .dwtag DW_TAG_assign_register, DW_AT_name("XAR1")
    .dwattr DW$14, DW_AT_location[DW_OP_reg7]
    DW$15 .dwtag DW_TAG_assign_register, DW_AT_name("AR2")
    .dwattr DW$15, DW_AT_location[DW_OP_reg8]
    DW$16 .dwtag DW_TAG_assign_register, DW_AT_name("XAR2")
    .dwattr DW$16, DW_AT_location[DW_OP_reg9]
    DW$17 .dwtag DW_TAG_assign_register, DW_AT_name("AR3")
    .dwattr DW$17, DW_AT_location[DW_OP_reg10]
    DW$18 .dwtag DW_TAG_assign_register, DW_AT_name("XAR3")
    .dwattr DW$18, DW_AT_location[DW_OP_reg11]
    DW$19 .dwtag DW_TAG_assign_register, DW_AT_name("AR4")
    .dwattr DW$19, DW_AT_location[DW_OP_reg12]
    DW$20 .dwtag DW_TAG_assign_register, DW_AT_name("XAR4")
    .dwattr DW$20, DW_AT_location[DW_OP_reg13]
    DW$21 .dwtag DW_TAG_assign_register, DW_AT_name("AR5")
    .dwattr DW$21, DW_AT_location[DW_OP_reg14]
    DW$22 .dwtag DW_TAG_assign_register, DW_AT_name("XAR5")
    .dwattr DW$22, DW_AT_location[DW_OP_reg15]
    DW$23 .dwtag DW_TAG_assign_register, DW_AT_name("AR6")
    .dwattr DW$23, DW_AT_location[DW_OP_reg16]
    DW$24 .dwtag DW_TAG_assign_register, DW_AT_name("XAR6")
    .dwattr DW$24, DW_AT_location[DW_OP_reg17]
    DW$25 .dwtag DW_TAG_assign_register, DW_AT_name("AR7")
    .dwattr DW$25, DW_AT_location[DW_OP_reg18]
    DW$26 .dwtag DW_TAG_assign_register, DW_AT_name("XAR7")
    .dwattr DW$26, DW_AT_location[DW_OP_reg19]
    DW$27 .dwtag DW_TAG_assign_register, DW_AT_name("SP")
    .dwattr DW$27, DW_AT_location[DW_OP_reg20]
    DW$28 .dwtag DW_TAG_assign_register, DW_AT_name("XT")
    .dwattr DW$28, DW_AT_location[DW_OP_reg21]
    DW$29 .dwtag DW_TAG_assign_register, DW_AT_name("T")
    .dwattr DW$29, DW_AT_location[DW_OP_reg22]
    DW$30 .dwtag DW_TAG_assign_register, DW_AT_name("ST0")
    .dwattr DW$30, DW_AT_location[DW_OP_reg23]
    DW$31 .dwtag DW_TAG_assign_register, DW_AT_name("ST1")
    .dwattr DW$31, DW_AT_location[DW_OP_reg24]
    DW$32 .dwtag DW_TAG_assign_register, DW_AT_name("PC")
    .dwattr DW$32, DW_AT_location[DW_OP_reg25]
    DW$33 .dwtag DW_TAG_assign_register, DW_AT_name("RPC")
    .dwattr DW$33, DW_AT_location[DW_OP_reg26]
    DW$34 .dwtag DW_TAG_assign_register, DW_AT_name("FP")
    .dwattr DW$34, DW_AT_location[DW_OP_reg27]
    DW$35 .dwtag DW_TAG_assign_register, DW_AT_name("DP")
    .dwattr DW$35, DW_AT_location[DW_OP_reg28]
    DW$36 .dwtag DW_TAG_assign_register, DW_AT_name("SXM")
    .dwattr DW$36, DW_AT_location[DW_OP_reg29]
    DW$37 .dwtag DW_TAG_assign_register, DW_AT_name("PM")
    .dwattr DW$37, DW_AT_location[DW_OP_reg30]
    DW$38 .dwtag DW_TAG_assign_register, DW_AT_name("OVM")
    .dwattr DW$38, DW_AT_location[DW_OP_reg31]
    DW$39 .dwtag DW_TAG_assign_register, DW_AT_name("PAGE0")
    .dwattr DW$39, DW_AT_location[DW_OP_regx 0x20]
    DW$40 .dwtag DW_TAG_assign_register, DW_AT_name("AMODE")
    .dwattr DW$40, DW_AT_location[DW_OP_regx 0x21]
    DW$41 .dwtag DW_TAG_assign_register, DW_AT_name("IFR")
    .dwattr DW$41, DW_AT_location[DW_OP_regx 0x22]
    DW$42 .dwtag DW_TAG_assign_register, DW_AT_name("IER")
    .dwattr DW$42, DW_AT_location[DW_OP_regx 0x23]
    DW$43 .dwtag DW_TAG_assign_register, DW_AT_name("IER")
    .dwattr DW$43, DW_AT_location[DW_OP_regx 0x24]
    DW$44 .dwtag DW_TAG_assign_register, DW_AT_name("PSEUDO")
    .dwattr DW$44, DW_AT_location[DW_OP_regx 0x25]
    DW$45 .dwtag DW_TAG_assign_register, DW_AT_name("PSEUDOH")
    .dwattr DW$45, DW_AT_location[DW_OP_regx 0x26]
    DW$46 .dwtag DW_TAG_assign_register, DW_AT_name("VOL")
    .dwattr DW$46, DW_AT_location[DW_OP_regx 0x27]
    DW$47 .dwtag DW_TAG_assign_register, DW_AT_name("CIE_RETA")
    .dwattr DW$47, DW_AT_location[DW_OP_regx 0x28]
    .dwendtag DW$CU
    Thank you.
  • Unfortunately, I am unable to reproduce the problem.  For the call to this function ...
    EUN WOO LEE82 said:
    int64 i64tmp1;
    When things go wrong, what are the values of x and alpha?  What final value should the function return?  What does it return instead?
    Thanks and regards,
    -George
    I provided the value of x and alpha in the previous post.
    x is -100 and alpha is 1000.
    The result, the value of i64tmp1, is 65436000.
    The correct value I think is -100000.
    Please note that i64tmp1 is 64bit variable.
    For example, when the address of i64tmp1 is 100, the last address of i64tmp1 is 103. When I tested, the value at th address 101:100 is 65436000 and 103:102 is zero.
    I think the value of upper half of i64tmp1 should not be zero, because ip64tmp1 is minus value.
    Did you use the same compiler version 4.1.3?
    Thank you.
  • I apologize for the delay.
    Unfortunately, I remain unable to reproduce the problem.  The function call mult(-100, 1000) returns -2, and i64tmp1 is assigned -100000.
    I will ask the C2000 experts for additional help with this thread.
    Thanks and regards,
    -George
    Can you send full project so that we can try to reproduce the issue over here? I just sent friend-request. It has my email address if you want to send offline.
    There was some mistakes in the test.
    My development environment is not straightforward, so the value of the first parameter is assigned to 65436 not -100.
    This is because the tool I use supports only 16-bit assignment for the 32-bit variable.
    I'm sorry and thank you for your time and support.
