Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
I am trying to implement Live firmware update for TMS320F280041 using SCIB port as my SCIA port is already used by other peripherals. I see sci kernel project (flashapi_ex2_sci_kernel) uses SCIA port for live firmware update. As per My initial analysis if i re-configure sci kernel project to use SCIB port instead of SCIA it should work. Can you please let me know any other changes to be made?
I was confused since TRM section 4.6.9 and table 4-28 points to only SCIA port is there any hardware pin changes also required to be made to make sci kernel to work for SCIB port? Can you please shed some light on the same?
Suhail.B
