I want to create two PWMs on ePWM1 that work in updown mode (I need updown mode because I want to add software deadtime). PWMs are inverted, so when one is high, the other one is low and vice versa. Now, my error is the following: When using updown mode, I can't change duty cycle of one PWM over a certain threshold (around 62%) and I can't lower the other PWM under around 37%. Also, freq of both PWMs is bad, it gets lowered. I can't get the needed duty cycle even if I put duty cycle lower than 62%. So if I want 50% on both PWMs, I will get like 40% on one and like 60% on the other, with freq being 1.7k instead of 2.5k on both. Now, if I use up mode, everything works fine, but I need updown mode. I'm measuring using oscilloscope. Here's my code:
#include "epwm_device.h" interrupt void isr_epwm2(void) { PieCtrlRegs.PIEACK.bit.ACK3 = 1; EPwm2Regs.ETCLR.bit.INT = 1; EPwm2Regs.ETCLR.bit.SOCA = 1; } void init_epwm() { EALLOW; CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 0; //reset PWM1 DevCfgRegs.SOFTPRES2.bit.EPWM1 = 1; DevCfgRegs.SOFTPRES2.bit.EPWM1 = 0; //reset PWM2 DevCfgRegs.SOFTPRES2.bit.EPWM2 = 1; DevCfgRegs.SOFTPRES2.bit.EPWM2 = 0; EDIS; //konfiguracija ePWM1 //podesi takt ePWM modula EPwm1Regs.TBCTL.bit.CLKDIV = 0; //delilac takta 1 //pauziraj PWM tokom pauze u debagovanju EPwm1Regs.TBCTL.bit.FREE_SOFT = 0; //pocetni smer brojanja na gore EPwm1Regs.TBCTL.bit.PHSDIR = START_COUNT_UP; //omoguci TBPHS registar EPwm1Regs.TBCTL.bit.PHSEN = 1; //simetricni PWM (up-down count mode) EPwm1Regs.TBCTL.bit.CTRMODE = CTR_UPDOWN; //pocetna faza 0, period 10000 taktova EPwm1Regs.TBPHS.all = EPWM1_PHASE; EPwm1Regs.TBPRD = EPWM1_PERIOD; //podesi compare registre //registar A mora biti veci za 1000 zbog mrtvog vremena EPwm1Regs.CMPA.bit.CMPA = EPWM1_CMPA; EPwm1Regs.CMPB.bit.CMPB = EPWM1_CMPB; //kanal A - na uzlaznoj ivici HIGH, na silaznoj LOW //kanal B - suprotno EPwm1Regs.AQCTLA.bit.CAU = AQ_HIGH; EPwm1Regs.AQCTLA.bit.CAD = AQ_LOW; EPwm1Regs.AQCTLB.bit.CBU = AQ_LOW; EPwm1Regs.AQCTLB.bit.CBD = AQ_HIGH; // konfiguracija EPWM2 EPwm2Regs.TBCTL.bit.CLKDIV = 0; // delilac takta 1 EPwm2Regs.TBCTL.bit.FREE_SOFT = 0; // blokiraj tokom debug pauze EPwm2Regs.TBCTL.bit.PHSDIR = START_COUNT_DOWN; // pocetna faza na gore EPwm2Regs.TBCTL.bit.PHSEN = 1; // omoguci registar faze EPwm2Regs.TBCTL.bit.CTRMODE = CTR_UP; // up count mod // pocetna faza 0, period 10000 taktova EPwm2Regs.TBPHS.all = EPWM2_PHASE; EPwm2Regs.TBPRD = EPWM2_PERIOD; // pusti ADC1 SOC na svakom maksimumu brojaca EPwm2Regs.ETSEL.bit.SOCAEN = 1; // ukljuci SOC A EPwm2Regs.ETSEL.bit.SOCASEL = 1; // na svaku nulu EPwm2Regs.ETPS.bit.SOCAPRD = 1; // prekid da resetuje flagove EPwm2Regs.ETSEL.bit.INTEN = 1; // ukljuci EPWM2INT EPwm2Regs.ETSEL.bit.INTSEL = 1; // na svaku nulu EPwm2Regs.ETPS.bit.INTPRD = 1; // debug EPwm2Regs.AQCTLA.bit.ZRO = AQ_TOGGLE; // toggle na nulu //pustanje kloka na PWMove EALLOW; CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 1; EDIS; }
