Part Number: C2000-GANG
program problem: The output electricity can reach 4A. It can burn the PCB. Nomal electricity is about 0.5A
=== C2000-GANG Self test results ( Friday, November 20, 2020, 19:41:33 ) === Adapter SN ------: 19110057 Hardware --------: C2K : 01.04 Access key ------: C2000 - Gang Programmer Silicon Number --: CE36 B46F 2000 0C00 API Firmware ----: C2K-Gang AC28: 01.01.02.00 BOOT Firmware ---: G430BOOT B430: 01.00.02.00 GUI Software ----: C2000-Gang-GUI G28x: 01.01.02.00 DLL Software ----: C2000-Gang-DLL D280: 01.01.02.00 ================ Test results ============= No. name parameter limits result status 1: Data Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 2: Data Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK << 3: Data Bus (D-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK << 4: Data Bus (D-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK << 5: Data Bus (D-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK << 6: Data Bus (D-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK << 7: Data Bus (D-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK << 8: Data Bus (D-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK << 9: Data Bus (D-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK << 10: Data Bus (D-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK << 11: Data-2 Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 12: Data-2 Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK << 13: Data-2 Bus (D2-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK << 14: Data-2 Bus (D2-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK << 15: Data-2 Bus (D2-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK << 16: Data-2 Bus (D2-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK << 17: Data-2 Bus (D2-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK << 18: Data-2 Bus (D2-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK << 19: Data-2 Bus (D2-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK << 20: Data-2 Bus (D2-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK << 21: Vcc Target-1 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.02 V ... >> OK << 22: Vcc Target-2 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 23: Vcc Target-3 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 24: Vcc Target-4 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 25: Vcc Target-5 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 26: Vcc Target-6 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 27: Vcc Target-7 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 28: Vcc Target-8 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 29: Translators VT (OFF) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 30: Translators VT (ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 3.21 V ... >> OK << 31: Vpp Voltage-in 10.00 V ( 8.00 to 12.00) Result: 10.28 V ... >> OK << 32: Vpp Voltage 7.00 V ( 6.50 to 7.30) Result: 6.87 V ... >> OK << 33: Internal Vcc-3.3V 3.30 V ( 3.20 to 3.40) Result: 3.30 V ... >> OK << 34: Vcc Target-1 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 3.30 V ... >> OK << 35: Vcc Target-2 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 3.30 V ... >> OK << 36: Vcc Target-3 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 1.61 V ... >> ERROR << 37: Vcc Target-4 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 1.60 V ... >> ERROR << 38: Vcc Target-5 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 1.62 V ... >> ERROR << 39: Vcc Target-6 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 0.03 V ... >> ERROR << 40: Vcc Target-7 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 1.68 V ... >> ERROR << 41: Vcc Target-8 (ALL ON 3.3V) 3.30 V ( 3.10 to 3.50) Result: 3.32 V ... >> OK << 42: Vcc discharge (250ms)Target-1 3.30 V ( 0.30 to 1.50) Result: 0.79 V ... >> OK << 43: Vcc discharge (250ms)Target-2 3.30 V ( 0.30 to 1.50) Result: 0.72 V ... >> OK << 44: Vcc discharge (250ms)Target-3 3.30 V ( 0.30 to 1.50) Result: 0.29 V ... >> ERROR << 45: Vcc discharge (250ms)Target-4 3.30 V ( 0.30 to 1.50) Result: 0.29 V ... >> ERROR << 46: Vcc discharge (250ms)Target-5 3.30 V ( 0.30 to 1.50) Result: 0.31 V ... >> OK << 47: Vcc discharge (250ms)Target-6 3.30 V ( 0.30 to 1.50) Result: 0.01 V ... >> ERROR << 48: Vcc discharge (250ms)Target-7 3.30 V ( 0.30 to 1.50) Result: 0.48 V ... >> OK << 49: Vcc discharge (250ms)Target-8 3.30 V ( 0.30 to 1.50) Result: 0.73 V ... >> OK << 50: Vcc Target-1 ( #1 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.30 V ... >> OK << 51: Vcc Target-2 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 52: Vcc Target-3 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 53: Vcc Target-4 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 54: Vcc Target-5 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 55: Vcc Target-6 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 56: Vcc Target-7 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 57: Vcc Target-8 ( #1 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 58: Vcc Target-1 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 59: Vcc Target-2 ( #2 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.30 V ... >> OK << 60: Vcc Target-3 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 61: Vcc Target-4 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 62: Vcc Target-5 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 63: Vcc Target-6 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 64: Vcc Target-7 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 65: Vcc Target-8 ( #2 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 66: Vcc Target-1 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 67: Vcc Target-2 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 68: Vcc Target-3 ( #3 ON ) 0.00 V ( 3.10 to 3.50) Result: 1.66 V ... >> ERROR << 69: Vcc Target-4 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 70: Vcc Target-5 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 71: Vcc Target-6 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 72: Vcc Target-7 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 73: Vcc Target-8 ( #3 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 74: Vcc Target-1 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 75: Vcc Target-2 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 76: Vcc Target-3 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 77: Vcc Target-4 ( #4 ON ) 0.00 V ( 3.10 to 3.50) Result: 1.66 V ... >> ERROR << 78: Vcc Target-5 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 79: Vcc Target-6 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 80: Vcc Target-7 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 81: Vcc Target-8 ( #4 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 82: Vcc Target-1 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 83: Vcc Target-2 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 84: Vcc Target-3 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 85: Vcc Target-4 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 86: Vcc Target-5 ( #5 ON ) 0.00 V ( 3.10 to 3.50) Result: 1.66 V ... >> ERROR << 87: Vcc Target-6 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 88: Vcc Target-7 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 89: Vcc Target-8 ( #5 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 90: Vcc Target-1 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 91: Vcc Target-2 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 92: Vcc Target-3 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 93: Vcc Target-4 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 94: Vcc Target-5 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 95: Vcc Target-6 ( #6 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.02 V ... >> ERROR << 96: Vcc Target-7 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 97: Vcc Target-8 ( #6 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 98: Vcc Target-1 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 99: Vcc Target-2 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 100: Vcc Target-3 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 101: Vcc Target-4 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 102: Vcc Target-5 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 103: Vcc Target-6 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 104: Vcc Target-7 ( #7 ON ) 0.00 V ( 3.10 to 3.50) Result: 1.66 V ... >> ERROR << 105: Vcc Target-8 ( #7 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 106: Vcc Target-1 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.17 V ... >> OK << 107: Vcc Target-2 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 108: Vcc Target-3 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 109: Vcc Target-4 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 110: Vcc Target-5 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 111: Vcc Target-6 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 112: Vcc Target-7 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.16 V ... >> OK << 113: Vcc Target-8 ( #8 ON ) 3.30 V ( 3.10 to 3.50) Result: 3.32 V ... >> OK << 114: SD Power OFF 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 115: SD Power ON 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 116: SD Discharge - delay 2ms 0x0010 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 117: SD Discharge - delay 50ms 0x0010 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 118: BSL RX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 119: BSL RX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 120: BSL RX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 121: BSL RX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 122: BSL RX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 123: BSL RX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 124: BSL RX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 125: BSL RX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 126: BSL TX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 127: BSL TX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 128: BSL TX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 129: BSL TX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 130: BSL TX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 131: BSL TX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 132: BSL TX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 133: BSL TX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 134: TDI bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 135: TDI bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 136: TDI bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 137: TDI bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 138: TDI bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 139: TDI bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 140: TDI bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 141: TDI bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 142: TDIO Tx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 143: TDIO Tx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 144: TDIO Tx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 145: TDIO Tx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 146: TDIO Tx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 147: TDIO Tx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 148: TDIO Tx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 149: TDIO Tx-bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 150: TDIO Tx-Rx (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 151: TDIO Tx-Rx (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 152: TDIO Tx-Rx (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 153: TDIO Tx-Rx (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 154: TDIO Tx-Rx (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 155: TDIO Tx-Rx (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 156: TDIO Tx-Rx (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 157: TDIO Tx-Rx (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 158: TDIO Rx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 159: TDIO Rx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 160: TDIO Rx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 161: TDIO Rx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 162: TDIO Rx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 163: TDIO Rx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 164: TDIO Rx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 165: TDIO Rx-bus (#84 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 166: TMS bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK << 167: TMS bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 168: TMS bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 169: TMS bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 170: TMS bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 171: TMS bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 172: TMS bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 173: TMS bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 174: TMS bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 175: TMS bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 176: RST bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK << 177: RST bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 178: RST bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 179: RST bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 180: RST bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 181: RST bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 182: RST bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 183: RST bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 184: RST bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 185: RST bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 186: Keys buffer (All pull-up) 0x001F (0x001F - 0x001F) Result: 0x1F ... >> OK << 187: Access to LCD RAM (0xAA) 0x00AA (0x00AA - 0x00AA) Result: 0xAA ... >> OK << 188: Access to LCD RAM (0x99) 0x0099 (0x0099 - 0x0099) Result: 0x99 ... >> OK << 189: Image Flash Access (get ID) 0x0002 (0x0001 - 0x0003) Result: 0x03 ... >> OK << ============== Finished ================================= * Test failed!! 13 error(s). =========================================================
