Part Number: DRV8301-69M-KIT
Other Parts Discussed in Thread: MOTORWARE
How do I get the motor running with this board?
Please download motorware at the link below which has many example projects to support this kit, and follow the lab guide to understand these lab projects to get the motor running.
http://www.ti.com/tool/motorware
You can find the related documentation in the folder below that includes the detailed operation instruction you want.
\motorware\motorware_1_01_00_18\docs\boards\control
Can you tell me how to get my motor running? I press the start button, but the motor does not turn. Please help..
Please take a look at the guide as mentioned above, you need to load the related code into the controller on the board.
I have looked at it, but I still dont understand. Please help. How do I get the start button working? Can you tell me the page in the document that I can find the information? Thank you.
There is no project that supports starting the motor using the start button, you have to run the motor in CCS or with GUI as the guide. Or you add a function to run the start with the button by yourself.
You might have a look at the links below that should answer your question.
https://e2e.ti.com/support/microcontrollers/c2000/f/171/p/439825/1577467
https://e2e.ti.com/support/microcontrollers/c2000/f/171/t/441848
https://e2e.ti.com/support/microcontrollers/c2000/f/171/p/305125/1066067
