Other Parts Discussed in Thread: CONTROLSUITE
Hi Expert,
there have an issue when run the example code from the below path, when call this function STL_generateCrc(), the result of gStructCrcResult is all 0 as below showed which does not match the expected value, and the crc check status is fault, could you help take a check if any wrong?
C:\ti\controlSUITE\libs\IEC60730_safety\v4_00_01_00\examples\f2802x
