Hello InstaSPIN users,
The scaling variables in user.h are critical and I don't think we have given enough proper guidance for how to choose these values the best.
With that in mind I've put together a spreadsheet that should help you make the best choices.
This is an alpha version I just put together today. It will change. Hopefuly we get a version of this into the MotorWare _12 release at the end of this month. That's IF we get good feedback.
So give it a try. Simply fill in all the cells in YELLOW and you should get guidance from the cells in GREEN. I've also added a section on designing the filter pole for your own Hardware.
Please ask for clarity when required and give feedback for improvement.
Note that the latest spreadsheet will be towards the bottom of the thread. Removing older versions to avoid confusion.
