I am using TMS320F28335. I want to generate two pair of PWM's.
I configured EPWM1 and EPWM2 in cmplementary mode.
I want to generate a duty cycle in such way that complementary of EPWM1A is EPWM2A.
code is given below
Initialization:
// Period = 15000 TBCLK counts
EPwm1Regs.TBPRD = EPWM1_TIMER_TBPRD;
// Set Phase register to zero
EPwm1Regs.TBPHS.half.TBPHS = 0;
// Clock ratio to SYSCLKOUT
EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;
// Symmetrical mode
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;
// Master module
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;
EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW;
// Sync down-stream module
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO;
EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // load on CTR=Zero
EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // load on CTR=Zero
// set actions for EPWM1A
// Set output to high when TBCTR = CMPA while TBCTR incrementing
EPwm1Regs.AQCTLA.bit.CAU = AQ_SET;
EPwm1Regs.AQCTLA.bit.CAD = AQ_CLEAR;
// enable Dead-band module
EPwm1Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
// Active Hi complementary
EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
// FED = 150 TBCLKs
EPwm1Regs.DBFED = 300;
// RED = 150 TBCLKs
EPwm1Regs.DBRED = 300;
// EPWM Module 2 config
EPwm2Regs.TBPRD = EPWM1_TIMER_TBPRD;
EPwm2Regs.TBPHS.half.TBPHS = 0;
EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1;
// Symmetrical mode
EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;
// Slave module
EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE;
EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW;
// sync flow-through
EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // load on CTR=Zero
EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // load on CTR=Zero
// set actions for EPWM2A
EPwm2Regs.AQCTLA.bit.CAU = AQ_SET;
// Set output to Low when TBCTR = CMPA while TBCTR decrementing
EPwm2Regs.AQCTLA.bit.CAD = AQ_CLEAR;
EPwm2Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm2Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
// FED = 150 TBCLKs
EPwm2Regs.DBFED = 300;
// RED = 150 TBCLKs
EPwm2Regs.DBRED = 300;
while(1)
DutyCycle2 = EPWM1_MAX_CMPA - DutyCycle;
EPwm1Regs.CMPA.half.CMPA = DutyCycle; // Set compare A value
EPwm2Regs.CMPA.half.CMPA = DutyCycle2; // Set compare A value
Now I am getting some phase lag between EPWM1A and EPWM2B.
Could any one help me in this regard.
Bhanu Prakash Villuri
