Help with SPI Interface with AD5292
I'm trying to communicate with a digtal POT AD5292 and I'm new to SPI and I am having trouble writing to the digital POT.  My code seems to get stuck on the first while(SpiaRegs.SPIFFRX.bit.RXFFST !=1) { }  loop
any help would be much appreciated.
my code is attached.
// FILE:	C1S01710.c
// TITLE:	CyberWand II Software
//  Ver | dd mmm yyyy | Who  | Description of changes
//  XA  | 26 Feb 2012 | S.R. | New File
#include "DSP2833x_Device.h"
//						Prototype statements for functions found within this file.
void Gpio_select(void);
void InitFlash(void);
void ADCconfig(void);
void Setup_ePWM(void);
void spi_xmit(Uint16 a);
void spi_init(void);
interrupt void cpu_timer0_isr(void);
interrupt void adc_isr(void);		 																	// ADC  End of Sequence ISR
extern unsigned int RamfuncsLoadStart;
extern unsigned int RamfuncsLoadEnd;
extern unsigned int RamfuncsRunStart;
extern void InitSysCtrl(void);
extern void InitPieCtrl(void);
extern void InitPieVectTable(void);
extern void InitCpuTimers(void);
extern void ConfigCpuTimer(struct CPUTIMER_VARS *, float, float);
extern void InitAdc(void);
//						Global Variables
unsigned int ADCIN4A;
unsigned int ADCIN5A;
//						main code
void main(void)
	Uint16 sdata;																						// SPI send data
	Uint16 rdata;																						// SPI receive data
	InitSysCtrl();	 																					// Basic Core Initialization
	EALLOW;
	SysCtrlRegs.WDCR = 0x00AF;																			//0x00AF = Enable Watchdog 0x0068 = Disable Watchdog
	EDIS;
	DINT;																								// Disable all interrupts
	memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, &RamfuncsLoadEnd - &RamfuncsLoadStart);				// Setup program to run in flash
	InitFlash();
	#define BUTTON	GpioDataRegs.GPBDAT.bit.GPIO61
	Gpio_select();																						// Setup GPIO's
	Setup_ePWM();																						//Setup ePWM signals
	InitPieCtrl();																						// Basic setup of PIE table; from DSP2833x_PieCtrl.c
	InitPieVectTable();																					// Default ISR's in PIE
	InitAdc();																							// Initialize Analog to Digital converter
	ADCconfig();																						//Configure the ADC
	EALLOW;																								//Enable access to protected register
	PieVectTable.TINT0 = &cpu_timer0_isr;
	PieVectTable.ADCINT = &adc_isr;
	EDIS;																								// Disable access to protected register
	InitCpuTimers();																					// Basic setup CPU Timer0, 1 and 2
	ConfigCpuTimer(&CpuTimer0, 150, 100);																// Initialize Timer0 to 100ms (150 = speed of DSP, 100000 = 100ms, 100 = 100us)
	PieCtrlRegs.PIEIER1.bit.INTx7 = 1;																	// Enable interrupt masks, Timer0 connected to group INT1, Bit7
	PieCtrlRegs.PIEIER1.bit.INTx6 = 1;																	// Enable interrupt masks, ADC connected to group INT1, Bit6
	IER |= 1;																							// Enable interrupt core line 1 (INT 1), modify register IER acc
	EINT;																								// Enable control interrupts
	ERTM;																								// Enable debug interrupts
	CpuTimer0Regs.TCR.bit.TSS = 0;																		// Start Timer0 Interrupt
	sdata = 0x1802;																						// Send Control Register info to AD5292, Enable update of RDAC
	GpioDataRegs.GPBSET.bit.GPIO57 = 1;
	spi_xmit(sdata);																					// Transmit data
	while(SpiaRegs.SPIFFRX.bit.RXFFST !=1) { } 															// Wait until data is received
	GpioDataRegs.GPBCLEAR.bit.GPIO57 = 1;
	rdata = SpiaRegs.SPIRXBUF;																			// Read sent back data
	//if(rdata != sdata) 																				// Check against sent data
	//sdata++;
	sdata = 0x0500;																						// Set wiper position of AD5292 to 1/4 scale (256)
	spi_xmit(sdata);
	int LargeStone_PWM = 0;
	double LargeStone;
	while(1)
		while(CpuTimer0.InterruptCount == 0);
		CpuTimer0.InterruptCount = 0;
		AdcRegs.ADCTRL2.bit.SOC_SEQ1 = 1;																// Start ADC conversion
		EALLOW;
		SysCtrlRegs.WDKEY = 0x55;																		// service WD #1
		EDIS;
		LargeStone = ADCIN4A*9.2025;
		LargeStone += 0.5;
		LargeStone_PWM = (int)LargeStone;
		EPwm1Regs.CMPA.half.CMPA = LargeStone_PWM;														// Update Duty Cycle based on ADCIN4A
//						End of main code
//						Timer 0 (100ms)
void cpu_timer0_isr()
	CpuTimer0.InterruptCount++;
	GpioDataRegs.GPBTOGGLE.bit.GPIO39 = 1;
	EALLOW;
	SysCtrlRegs.WDKEY = 0xAA;																			// service WD #2
	EDIS;
	PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
//						End Timer 0 (100ms)
//						ADC Interrupt
	ADCIN4A = AdcMirror.ADCRESULT0;
	ADCIN5A = AdcMirror.ADCRESULT1;
	AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1;																	//Reset ADC Seq 1
	AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;																	//Clear interrupt flag ADC Seq 1
//						End of ADC Interrupt
//						GPIO Setup
	EALLOW;
	GpioCtrlRegs.GPAMUX1.all = 0;																		// GPIO0  ... GPIO15 = General Purpose I/O
	GpioCtrlRegs.GPAMUX1.bit.GPIO0  = 1;																// Set GPIO 0  as EPWM1A (PWM for R1 of 4046 Chip)
	//GpioCtrlRegs.GPAMUX1.bit.GPIO1  = 1;																// Set GPIO 1  as EPWM1B (PWM for AGC_START_LEVEL)(not used)
	GpioCtrlRegs.GPAMUX1.bit.GPIO2  = 1;																// Set GPIO 2  as EPWM2A (PWM for R2 of 4046 Chip)
	GpioCtrlRegs.GPAMUX1.bit.GPIO3  = 1;																// Set GPIO 3  as EPWM2B (PWM for AGC_MIN_LEVEL_PWM)
	GpioCtrlRegs.GPAMUX1.bit.GPIO4  = 1;																// Set GPIO 4  as EPWM3A (PWM for PHASE_COMND_PWM)
	GpioCtrlRegs.GPAMUX1.bit.GPIO6  = 1;																// Set GPIO 6  as EPWM4A (PWM for DIG_FREQ_PWM)
	GpioCtrlRegs.GPAMUX1.bit.GPIO8  = 1;																// Set GPIO 8  as EPWM5A (PWM for AGC_COMMAND_PWM)
	GpioCtrlRegs.GPAMUX1.bit.GPIO10 = 1;																// Set GPIO 10 as EPWM6A (PWM for DIG_AGC_PWM)
	GpioCtrlRegs.GPAMUX2.all = 0;																		// GPIO16 ... GPIO31 = General Purpose I/O
	GpioCtrlRegs.GPBMUX1.all = 0;																		// GPIO32 ... GPIO47 = General Purpose I/O
	GpioCtrlRegs.GPBMUX2.all = 0;																		// GPIO48 ... GPIO63 = General Purpose I/O
	GpioCtrlRegs.GPBMUX2.bit.GPIO54 = 1;																// Set GPIO54 as SPISIMOA
	GpioCtrlRegs.GPBMUX2.bit.GPIO55 = 1;																// Set GPIO55 as SPISOMIA
	GpioCtrlRegs.GPBMUX2.bit.GPIO56 = 1;																// Set GPIO56 as SPICLKA
	GpioCtrlRegs.GPBMUX2.bit.GPIO57 = 1;																// Set GPIO57 as SPISTEA
	GpioCtrlRegs.GPCMUX1.all = 0;																		// GPIO64 ... GPIO79 = General Purpose I/O
	GpioCtrlRegs.GPCMUX2.all = 0;																		// GPIO80 ... GPIO87 = General Purpose I/O
	GpioCtrlRegs.GPADIR.all = 0;																		// GPIO0  ... GPIO31 as inputs
	GpioCtrlRegs.GPADIR.bit.GPIO11 = 1;																	// Set GPIO 11 as output (SYS_ON_3.3)
	GpioCtrlRegs.GPADIR.bit.GPIO12 = 1;																	// Set GPIO 12 as output (WD_BONE)
	GpioCtrlRegs.GPADIR.bit.GPIO22 = 1;																	// Set GPIO 22 as output (ANA_OR_DIG_AGC)
	GpioCtrlRegs.GPADIR.bit.GPIO23 = 1;																	// Set GPIO 23 as output (ANA_OR_DIG_FREQ)
	GpioCtrlRegs.GPBDIR.all = 0;																		// GPIO32 ... GPIO63 as inputs
	/* LED Nets not used, needed more lines so J28A is being used
	GpioCtrlRegs.GPBDIR.bit.GPIO40 = 1;																	// Set GPIO 40 as output (LED1)
	GpioCtrlRegs.GPBDIR.bit.GPIO41 = 1;																	// Set GPIO 41 as output (LED2)
	GpioCtrlRegs.GPBDIR.bit.GPIO42 = 1;																	// Set GPIO 42 as output (LED3)
	GpioCtrlRegs.GPBDIR.bit.GPIO43 = 1;																	// Set GPIO 43 as output (LED4)
	GpioCtrlRegs.GPBDIR.bit.GPIO44 = 1;																	// Set GPIO 44 as output (LED5)
	GpioCtrlRegs.GPBDIR.bit.GPIO45 = 1;																	// Set GPIO 45 as output (LED6)
	GpioCtrlRegs.GPBDIR.bit.GPIO46 = 1;																	// Set GPIO 46 as output (LED7)
	GpioCtrlRegs.GPBDIR.bit.GPIO47 = 1;																	// Set GPIO 47 as output (LED8)
	GpioCtrlRegs.GPBDIR.bit.GPIO52 = 1;																	// Set GPIO 52 as output (DSP_RESET_PA)
	GpioCtrlRegs.GPBDIR.bit.GPIO58 = 1;																	// Set GPIO 58 as output (DSP_40KHz_ON)(not used on power board C1E01608)
	GpioCtrlRegs.GPBDIR.bit.GPIO59 = 1;																	// Set GPIO 59 as output (DSP_20KHz_ON)(not used on power board C1E01608)
	GpioCtrlRegs.GPBDIR.bit.GPIO61 = 1;																	// Set GPIO 61 as output (USB_PROG)
	GpioCtrlRegs.GPBDIR.bit.GPIO37 = 1;																	// Test point for debugging
	GpioCtrlRegs.GPBDIR.bit.GPIO39 = 1;																	// Test point for debugging
	GpioCtrlRegs.GPCDIR.all = 0;																		// GPIO64 ... GPIO87 as inputs
	GpioCtrlRegs.GPCDIR.bit.GPIO64 = 1;																	// Set GPIO 64 as output (TRCON RED)(Possible Detect Bad Transducer)
	GpioCtrlRegs.GPCDIR.bit.GPIO65 = 1;																	// Set GPIO 65 as output (TRCON GRN)(Transducer Connected)
																										// Clear both GPIO 64 and 65 (TRCON RED & TRCON GRN) for Transducer Not Connected (yellow)
	GpioCtrlRegs.GPCDIR.bit.GPIO66 = 1;																	// Set GPIO 66 as output (CHKPRB WHT) Check Probe White Light
	GpioCtrlRegs.GPCDIR.bit.GPIO67 = 1;																	// Set GPIO 67 as output (CHKPRB RED) Check Probe Error (Red) Light
	GpioCtrlRegs.GPCDIR.bit.GPIO68 = 1;																	// Set GPIO 68 as output (FTSW WHT) Footswitch Not Connected White Light
	GpioCtrlRegs.GPCDIR.bit.GPIO69 = 1;																	// Set GPIO 69 as output (FTSW GRN) Footswitch Connected Green Light
	GpioCtrlRegs.GPCDIR.bit.GPIO70 = 1;																	// Set GPIO 70 as output (LGSTN WHT) Large Stone Not Activated White Light
	GpioCtrlRegs.GPCDIR.bit.GPIO71 = 1;																	// Set GPIO 71 as output (LGSTN GRN) Large Stone Activated Green Light
	GpioCtrlRegs.GPCDIR.bit.GPIO72 = 1;																	// Set GPIO 72 as output (SMSTN WHT) Small Stone Not Activated White Light
	GpioCtrlRegs.GPCDIR.bit.GPIO73 = 1;																	// Set GPIO 73 as output (SMSTN GRN) Small Stone Activated Green Light
	GpioCtrlRegs.GPCDIR.bit.GPIO74 = 1;																	// Set GPIO 74 as output (ERROR WHT) Error Not Active White Light
	GpioCtrlRegs.GPCDIR.bit.GPIO75 = 1;																	// Set GPIO 75 as output (ERROR RED) Error Active Red Light
	GpioCtrlRegs.GPCDIR.bit.GPIO76 = 1;																	// Set GPIO 76 as output (LBLS WHT) White Light for Labels (Always On)
	GpioCtrlRegs.GPCDIR.bit.GPIO80 = 1;																	// Set GPIO 80 as output (LED9)
	EDIS;
//						End of GPIO Setup
//						Setup ePWM
	//ePWM1A Setup - Sets PWM for R1 on 4046 Chip
	EPwm1Regs.TBCTL.bit.CLKDIV = 0;																		// CLKDIV = /1    ->default
	EPwm1Regs.TBCTL.bit.HSPCLKDIV = 1;																	// HSPCLKDIV = /2 ->default
	EPwm1Regs.TBCTL.bit.CTRMODE = 2;																	// Count up/down mode
	EPwm1Regs.TBPRD = 37500;																			// 1 Khz - PWM Signal  = TBPRD = .5*fsysclockout/(fpwm*CLKDIV*HSPCLKDIV)
																										// TBPRD = .5*150e6/(1e3*1*2), CLKDIV and HSPCLKDIV are the divisor numbers
	EPwm1Regs.AQCTLA.all = 0x0060;																		// Set ePWM1A on CMPA up
																										// Clear ePWM1A on CMPA down.
	EPwm1Regs.CMPA.half.CMPA = 0;																		// 100% duty cycle first
	//ePWM2A Setup - Sets PWM for R2 on 4046 Chip
	EPwm2Regs.TBCTL.bit.CLKDIV = 0;																		// CLKDIV = /1    ->default
	EPwm2Regs.TBCTL.bit.HSPCLKDIV = 1;																	// HSPCLKDIV = /2 ->default
	EPwm2Regs.TBCTL.bit.CTRMODE = 2;																	// Count up/down mode
	EPwm2Regs.TBPRD = 37500;																			// 1 Khz - PWM Signal  = TBPRD = .5*fsysclockout/(fpwm*CLKDIV*HSPCLKDIV)
	EPwm2Regs.AQCTLA.all = 0x0060;																		// Set ePWM2A on CMPA up
																										// Clear ePWM2A on CMPA down.
	EPwm2Regs.CMPA.half.CMPA = 18750;																	// 50% duty cycle first
	//ePWM2B Setup - Sets PWM for AGC Min Level
	EPwm2Regs.AQCTLB.all = 0x0600;																		// Set ePWM2B on CMPB up
																										// Clear ePWMBA on CMPB down.
	EPwm2Regs.CMPB = 18750;																				// 50% duty cycle first
	//ePWM3A Setup - Sets PWM for Phase Command
	EPwm3Regs.TBCTL.bit.CLKDIV = 0;																		// CLKDIV = /1    ->default
	EPwm3Regs.TBCTL.bit.HSPCLKDIV = 1;																	// HSPCLKDIV = /2 ->default
	EPwm3Regs.TBCTL.bit.CTRMODE = 2;																	// Count up/down mode
	EPwm3Regs.TBPRD = 37500;																			// 1 Khz - PWM Signal  = TBPRD = .5*fsysclockout/(fpwm*CLKDIV*HSPCLKDIV)
	EPwm3Regs.AQCTLA.all = 0x0060;																		// Set ePWM3A on CMPA up
																										// Clear ePWM3A on CMPA down.
	EPwm3Regs.CMPA.half.CMPA = 18750;																	// 50% duty cycle first
	//ePWM4A Setup - Sets PWM for Digital Frequency
	EPwm4Regs.TBCTL.bit.CLKDIV = 0;																		// CLKDIV = /1    ->default
	EPwm4Regs.TBCTL.bit.HSPCLKDIV = 1;																	// HSPCLKDIV = /2 ->default
	EPwm4Regs.TBCTL.bit.CTRMODE = 2;																	// Count up/down mode
	EPwm4Regs.TBPRD = 37500;																			// 1 Khz - PWM Signal  = TBPRD = .5*fsysclockout/(fpwm*CLKDIV*HSPCLKDIV)
	EPwm4Regs.AQCTLA.all = 0x0060;																		// Set ePWM4A on CMPA up
																										// Clear ePWM4A on CMPA down.
	EPwm4Regs.CMPA.half.CMPA = 18750;																	// 500% duty cycle first
	//ePWM5A Setup - Sets PWM for AGC Command
	EPwm5Regs.TBCTL.bit.CLKDIV = 0;																		// CLKDIV = /1    ->default
	EPwm5Regs.TBCTL.bit.HSPCLKDIV = 1;																	// HSPCLKDIV = /2 ->default
	EPwm5Regs.TBCTL.bit.CTRMODE = 2;																	// Count up/down mode
	EPwm5Regs.TBPRD = 37500;																			// 1 Khz - PWM Signal  = TBPRD = .5*fsysclockout/(fpwm*CLKDIV*HSPCLKDIV)
	EPwm5Regs.AQCTLA.all = 0x0060;																		// Set ePWM5A on CMPA up
																										// Clear ePWM5A on CMPA down.
	EPwm5Regs.CMPA.half.CMPA = 18750;																	// 50% duty cycle first
	//ePWM6A Setup - Sets PWM for AGC Command
	EPwm6Regs.TBCTL.bit.CLKDIV = 0;																		// CLKDIV = /1    ->default
	EPwm6Regs.TBCTL.bit.HSPCLKDIV = 1;																	// HSPCLKDIV = /2 ->default
	EPwm6Regs.TBCTL.bit.CTRMODE = 2;																	// Count up/down mode
	EPwm6Regs.TBPRD = 37500;																			// 1 Khz - PWM Signal  = TBPRD = .5*fsysclockout/(fpwm*CLKDIV*HSPCLKDIV)
	EPwm6Regs.AQCTLA.all = 0x0060;																		// Set ePWM6A on CMPA up
																										// Clear ePWM6A on CMPA down.
	EPwm6Regs.CMPA.half.CMPA = 18750;																	// 50% duty cycle first
//						End ePWM Setup
//						ADC Config
void ADCconfig()
	AdcRegs.ADCTRL1.all = 0;
	AdcRegs.ADCTRL1.bit.ACQ_PS = 7;																		// 8 x ADC-Clock
	AdcRegs.ADCTRL1.bit.SEQ_CASC = 1; 																	// 0 = Dual Sequencer Mode, 1 = cascaded sequencer
	AdcRegs.ADCTRL1.bit.CPS = 0;																		// divide by 1
	AdcRegs.ADCTRL1.bit.CONT_RUN = 0; 																	// Single Run Mode
	AdcRegs.ADCTRL2.all = 0;
	AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1 = 1;																// Enable SEQ1 interrupt
	//AdcRegs.ADCTRL2.bit.EPWM_SOCA_SEQ1 = 1; 															// Start by ePWM trigger - use software start instead
	AdcRegs.ADCTRL2.bit.INT_MOD_SEQ1 = 0;																// Interrupt after every EOS (end of sequency)
	AdcRegs.ADCTRL3.bit.ADCCLKPS = 6;																	// ADC clock: FCLK = HSPCLK / 2 * ADCCLKPS
																										// HSPCLK = 150MHz (see DSP2833x_SysCtrl.c)
																										// FCLK = 12.5 MHz
	AdcRegs.ADCMAXCONV.all = 1;																			// Two conversions from Sequencer 1 (Number of conversions minus 1)
	AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 4;																// ADCINA4 - Temp ADC in for AGC adjustment (large stone)
	AdcRegs.ADCCHSELSEQ1.bit.CONV01 = 5;																// ADCINA5 - Temp ADC in for AGC adjustment (small stone)
	/*Can't use because all ePWM units are being used
	EPwm2Regs.TBCTL.bit.CLKDIV = 0;																		// Divide by 1
	EPwm2Regs.TBCTL.bit.FREE_SOFT = 2;																	// Ignore emulation suspend
	EPwm2Regs.TBCTL.bit.HSPCLKDIV = 0;																	// Divide by 1
	EPwm2Regs.TBCTL.bit.SWFSYNC = 0;																	// No action
	EPwm2Regs.TBCTL.bit.SYNCOSEL = 3;																	// Sync out disabled
	EPwm2Regs.TBCTL.bit.PHSEN = 0;																		// No phase
	EPwm2Regs.TBCTL.bit.PRDLD = 0;																		// Load on CTR = 0
	EPwm2Regs.TBCTL.bit.CTRMODE = 0;																	// Count up mode
	EPwm2Regs.TBPRD = 2999;																				// TBPRD = Tpwm/(HSPCLKDIV * CLKDIV * Tsysclk) = 50e3/(1*1*150e3^-1)
	EPwm2Regs.ETPS.all = 0;																				// Clear all bits
	EPwm2Regs.ETPS.bit.SOCAPRD = 1;																		// Enable SOCA on first event
	EPwm2Regs.ETSEL.bit.SOCAEN = 1;																		// Enable SOCA
	EPwm2Regs.ETSEL.bit.SOCASEL = 2;																	// Generate SOCA on PRD event
//						End ADC Config
//						SPI Init
void spi_init()
	SpiaRegs.SPICCR.all =0x004F;	             // Reset on, falling edge, 16-bit char bits
	SpiaRegs.SPICTL.all =0x0006;    		     // Enable master mode, normal phase,
                                                 // enable talk, and SPI int disabled.
	SpiaRegs.SPIBRR =0x007F;
    SpiaRegs.SPICCR.all =0x00CF;		         // Relinquish SPI from Reset
    SpiaRegs.SPIPRI.bit.FREE = 1;                // Set so breakpoints don't disturb xmission
//						End SPI Init
//						SPI Transmit
    SpiaRegs.SPITXBUF=a;
//						End SPI Transmit
    I do not see  the FIFO's initialization statements anywhere in your code.
    void spi_fifo_init()
    // Initialize SPI FIFO registers
        SpiaRegs.SPIFFTX.all=0xE040;
        SpiaRegs.SPIFFRX.all=0x2044;
        SpiaRegs.SPIFFCT.all=0x0;
    Just like example code.
    hamid
  • I tried adding spi_fifo_init to my code but it did not seem to make a difference for me.
    I'm really new to spi and not even sure how to debug it.
    My SYNC line is GPIO57 and I original had it set as SPISTEA but I couldn't control it so I changed it to a GPIO and I set it low before I send data and then set it high when done.  This did not seem to accomplish anything though
    I can not seem to get a SCLK signal either, when monitoring the signal all I get is a high signal
    Attached is updated code with schematic.
    void spi_fifo_init(void);
    //						Global Variables
    //						main code
    void main(void)
    	#define FSW_DETECT		GpioDataRegs.GPADAT.bit.GPIO9
    	#define PHASE1			GpioDataRegs.GPADAT.bit.GPIO24
    	#define PHASE2			GpioDataRegs.GPADAT.bit.GPIO25
    	#define HSW_LARGE		GpioDataRegs.GPADAT.bit.GPIO26
    	#define HSW_SMALL		GpioDataRegs.GPADAT.bit.GPIO27
    	#define FSW_LARGE		GpioDataRegs.GPBDAT.bit.GPIO32
    	#define FSW_SMALL		GpioDataRegs.GPBDAT.bit.GPIO33
    	#define HSW_DETECT		GpioDataRegs.GPCDAT.bit.GPIO81
    	#define ERROR			GpioDataRegs.GPBDAT.bit.GPIO60
    	/*#define WD_BONE_ON		GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define WD_BONE_OFF		GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define SYS_ON_ON		GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define SYS_ON_OFF		GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define ANA_FREQ		GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define DIG_FREQ		GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define DSP_S_S_ON		GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define DSP_S_S_OFF		GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define DSP_RESET_PA	GpioDataRegs.GPATOGGLE.bit.GPIO12 	= 1
    	#define USB_PROG_ON		GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define USB_PROG_OFF	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define TRCON_RED_ON	GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define TRCON_RED_OFF	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	double LargeStone;
    	EALLOW;
    	EDIS;
    	InitFlash();
    	Setup_ePWM();																						// Setup ePWM signals
    	//while(SpiaRegs.SPIFFRX.bit.RXFFST !=1) { } 															// Wait until data is received
    	//sdata++;
    	spi_xmit(sdata);
    	while(1)
    		EALLOW;
    		EDIS;
    		LargeStone += 0.5;
    //						End of main code
    //						Timer 0 (100ms)
    	EALLOW;
    	EDIS;
    //						ADC Interrupt
    //						GPIO Setup
    	EALLOW;
    	//GpioCtrlRegs.GPBMUX2.bit.GPIO57 = 1;																// Set GPIO57 as SPISTEA
    	GpioCtrlRegs.GPBDIR.bit.GPIO57 = 1;
    	EDIS;
    //						Setup ePWM1A
    //						ADC Config
    void ADCconfig()
    																										// FCLK = 12.5 MHz
    //						End ADC Config
    //						SPI Init
    void spi_init()
    //						End SPI Init
    //						SPI FIFO Init
    //						End SPI FIFO Init
    //						SPI Transmit
    //						End SPI Transmit
  • Your code doesn't  call spi_init and spi_fifo_init.
    Stephen
    Let's take one step at a time. Please make sure you are calling both initialization routines within your main DSP controller  (spi.init() and spi_fifo_init() ).
    I looked at your schematic, it is connected correctly,But you might as well make sure that your initialization routine correctly initializes the AD5292 ports for SPI functionality, otherwise your port will function as a regular GPIO.
    Hamid
  • well that is embarrassing, it seems that did it or at least gets me started
    thanks!
  • So I think I am successfully writing to the AD5292 because I can see that SpiaRegs.SPITXBUF gets populated with my values and I'm also getting data back in the SpiaRegs.SPIRXBUF register but the wiper does not seem to move from the half scale position.
    I've tried following the example in the AD5292 datasheet Table 12 of page 23 of 32 and these are my results.  rdata is a variable I set to SpiaRegs.SPIRXBUF in the spi_xmit() function.  I'm not sure why it is different then SpiaRegs.SPIRXBUF outside of the function.  I've attached my code.  Any help would be much appreciated. Thanks.
    DIN SDO_theoretical SDO_actual rdata
    0x1803 0xXXXX 0x1803 0x0800
    0x0500 0x1803 0x0500 0x1803
    0x0800 0x0500 0x0800 0x0500
    0x0C00 0x0100 0x0C00 0x0800
    0x1C00 0x0C00 0x1C00 0x0C00
    0x0000 0x000X 0x0000 0x1C00
    // FILE:	C1S01710.c
    //void InitFlash(void);
    //extern unsigned int RamfuncsLoadStart;
    //extern unsigned int RamfuncsLoadEnd;
    //extern unsigned int RamfuncsRunStart;
    //						Global Variables
    //						main code
    void main(void)
    	#define DSP_RESET_PA_H	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define DSP_RESET_PA_L	GpioDataRegs.GPACLEAR.bit.GPIO12	= 1
    	#define TRCON_GRN_ON	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define TRCON_GRN_OFF	GpioDataRegs.GPACLEAR.bit.GPIO12	= 1
    	#define CHKPRB_WHT_ON	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define CHKPRB_WHT_OFF	GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define CHKPRB_RED_ON	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define CHKPRB_RED_OFF	GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define FSW_WHT_ON		GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define FSW_WHT_OFF		GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define FSW_GRN_ON		GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define FSW_GRN_OFF		GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define LGSTN_WHT_ON	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define LGSTN_WHT_OFF	GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define LGSTN_GRN_ON	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define LGSTN_GRN_OFF	GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define SMSTN_WHT_ON	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define SMSTN_WHT_OFF	GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define SMSTN_GRN_ON	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define SMSTN_GRN_OFF	GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define ERROR_WHT_ON	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define ERROR_WHT_OFF	GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define ERROR_RED_ON	GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define ERROR_RED_OFF	GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	#define LBLS_WHT_ON		GpioDataRegs.GPASET.bit.GPIO12 		= 1
    	#define LBLS_WHT_OFF	GpioDataRegs.GPACLEAR.bit.GPIO12 	= 1
    	double LargeStone;
    	//Uint16 sdata;
    	EALLOW;
    	EDIS;
    	//memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, &RamfuncsLoadEnd - &RamfuncsLoadStart);				// Setup program to run in flash
    	//InitFlash();
    	spi_init();
    	spi_fifo_init();
    	spi_xmit(0x1803);
    	spi_xmit(0x0500);
    	spi_xmit(0x0800);
    	spi_xmit(0x0C00);
    	spi_xmit(0x1C00);
    	spi_xmit(0x0000);
    	int count = 1;
    	while(1)
    		EALLOW;
    		EDIS;
    		if (!HSW_LARGE & count==1)
    			count = 0;
    			spi_xmit(0x1802);
    			spi_xmit(0x0600);
    			spi_xmit(0x0800);
    		else if (HSW_LARGE & !count)
    			count = 1;
    			spi_xmit(0x1802);
    			spi_xmit(0x0500);
    			spi_xmit(0x0800);
    		LargeStone += 0.5;
    //						End of main code
    //						Timer 0 (100ms)
    	EALLOW;
    	EDIS;
    //						ADC Interrupt
    //						GPIO Setup
    	EALLOW;
    	//GpioCtrlRegs.GPAQSEL1.bit.GPIO11 = 2;
    	//GpioCtrlRegs.GPACTRL.bit.QUALPRD1 = 2;
    	EDIS;
    //						Setup ePWM1A
    //						ADC Config
    void ADCconfig()
    																										// FCLK = 12.5 MHz
    //						End ADC Config
    //						SPI Init
    void spi_init()
        // Enable talk, and SPI int disabled.
    //						End SPI Init
    //						SPI FIFO Init
    //						SPI Transmit
    	SpiaRegs.SPITXBUF=a;																				// Send data to SPI device
    	rdata = SpiaRegs.SPIRXBUF;																			// Set rdata to Receive buffer (SDO)
    //						End SPI Transmit
  • I've captured the wave forms on an oscilloscope of the six commands.  CH 1 is the SYNC~ line, CH 2 is SCLK, and CH 3 is DIN.
  • So it turns for AD5292 the data needs to be clock in on the rising edge.  However the data sheet says falling edge. I made the following changes to the SpiaRegs.SPICCR register and all seems well!!!
    to:      SpiaRegs.SPICCR.all =0x000F; //rising edge
