Compiler/TMS320F28069M: Redirect SCI to STDIN
Part Number: TMS320F28069M
I've done a lot of searching and have found solutions to remap STDOUT to UART but modifying the code in a similar way to try and accommodate STDIN hasn't been successful. I'm using the low level driver functions found in the Example_2806xLaunchPadDemo (sci_io.h, sci_io.c), and it works for using printf(). How can I add functionality to get input using scanf()?
Here's the code that adds the device. Those functions are defined in the sci_io.c file.
//! \brief  Contains the various functions related to the serial
//!         communications interface (SCI) object
//  Group:          C2000
//  Target Device:  TMS320F2802x
//  (C) Copyright 2012, Texas Instruments, Inc.
// $TI Release: F2806x Support Library v2.03.00.00 $
// $Release Date: Sun Mar 25 13:24:47 CDT 2018 $
// $Copyright:
// Copyright (C) 2009-2018 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include <stdio.h>
#include <file.h>
#include <stdint.h>
#include <stdbool.h>
#include "DSP28x_Project.h"
#include "sci_io.h"
// Defines
// Globals
uint16_t deviceOpen = 0;
// Functions
// SCI_open -
int SCI_open(const char * path, unsigned flags, int llv_fd)
    if(deviceOpen)
        return (-1);
    else
        deviceOpen = 1;
        return (1);
// SCI_close -
int SCI_close(int dev_fd)
    if((dev_fd != 1) || (!deviceOpen))
        return (-1);
    else
        deviceOpen = 0;
        return (0);
// SCI_read -
int SCI_read(int dev_fd, char * buf, unsigned count)
    uint16_t readCount = 0;
    uint16_t * bufPtr = (uint16_t *) buf;
    if(count == 0)
        return (0);
    while((readCount < count) && SciaRegs.SCIRXST.bit.RXRDY)
        *bufPtr = SciaRegs.SCIRXBUF.all;
        readCount++;
        bufPtr++;
    return (readCount);
// SCI_write -
int SCI_write(int dev_fd, const char * buf, unsigned count)
    uint16_t writeCount = 0;
    if(count == 0)
        return (0);
    while(writeCount < count)
        while(!SciaRegs.SCICTL2.bit.TXRDY);
        SciaRegs.SCITXBUF = *bufPtr;
        writeCount++;
        bufPtr++;
    return (writeCount);
// SCI_lseek -
off_t SCI_lseek(int dev_fd, off_t offset, int origin)
    return (0);
// SCI_unlink -
int SCI_unlink(const char * path)
    return (0);
// SCI_rename -
int SCI_rename(const char * old_name, const char * new_name)
    return (0);
// End of File
